Old 04-04-2010, 09:35 AM   #1756
Send a message via ICQ to MattW
Personally, I wouldn't bother with anything other than the plastic blocks if you're running on rubber tyres.
The alloy ones give you some adjustment for sure, but for robber tyres, the std plastic blocks are fine - and a fair chunk lighter than the alloy ones.
I'm not sure I saw any of the UK team run alloy blocks last year.
I haven't had a set of alloy ones on my car since the day I got plastic ones for my pre prod car.
MattW is offline   Reply With Quote
Old 04-04-2010, 10:28 AM   #1757
Jochim_18's Avatar
I like the Alloy blocks better just the fact you can fine tune the car more. I'm not saying you go out get one but it's my personal preference to have it on my car.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 04-04-2010, 10:53 AM   #1758
Kenny L's Avatar
Trader Rating: 16 (100%+)
I always run the alloy ones on my car just for the weight right now my lp gear up no weight weighs in at 1380 with alloy blocks and tir axles
Team Tekin, Ko Propo America
Kenny L is offline   Reply With Quote
Old 04-04-2010, 11:33 AM   #1759
I prefer the alloy too. More fine tuning with the spacers.
crabsteer is offline   Reply With Quote
Old 04-04-2010, 01:28 PM   #1760
Racer X's Avatar
I use the alloy blocks too. The very small weight difference makes almost no difference, but the ability to change and fine tune the different settings in invaluable. Also, you can finish a race with a bent screw but not a broken block.
Schumacher Mi6
Speed Passion Motors and ESCs
Integy
SpeedWorld Raceway Roseville CA.
Racer X is offline   Reply With Quote
Old 04-04-2010, 02:22 PM   #1761
skypilot's Avatar
Trader Rating: 14 (100%+)
I'm thinking because the not everyone in the world racing on the same type of asphalt,tarmac, or whatever you call where your from, and not everyone uses the same tire on carpet, (spec tire) you may or may not need the extra adjustment, for me, i need a lot of rear toe, and the with extra washers the plastics are put in a blind and a tap of the pipe or a hit from another driver will and has snapped them. oh sure i could ream them out to relieve the stress, but that also makes them weaker. I will say, as far as i can remember I've never changed kickup or anti squat.
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 04-04-2010, 02:45 PM   #1762
The Bear's Avatar
anyone within striking distance to Jackson NJ, on the 24th of April they are having a huge race on a worlds class track... should be some amazing racing..
Sponsors for 2013 - NoVak / Team Scream / liquidrc.com
The Bear is offline   Reply With Quote
Old 04-04-2010, 03:16 PM   #1763
Not sure if you guys realize this, but you can accomplish the only adjustments you really would need with another set of the plastic ones if necessary. They screw into the bulkheads 1mm higher in the rear. The pins are the same front to back so the rear blocks are 1mm lower.
You can achieve a lower front pin by using the rear ones in the front.
You can achieve antidive/kickup by running a rear block and a front block.
You can do the same with anti squat and pro squat.
The pins are 8mm from the bottom of the chassis stock front and rear. So far with the car we've never really had to change it other than using antidive every now and then, which you can achieve as I mentioned with the stock blocks. Always end up with flat pins at 8mm.
Possibile front pin 7-8mm along with antidive/kickup possibilities.
Possible rear pin 8-9mm along with antisquat/prosquat possibilities.
JoelV is offline   Reply With Quote
Old 04-04-2010, 03:23 PM   #1764
I'll be there Casey.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 04-05-2010, 01:27 PM   #1765
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
Thanks for the help saturday. Awesome awesome.
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 04-05-2010, 06:44 PM   #1766
Jochim_18's Avatar
I see your are still running schuie...
Old 04-06-2010, 07:48 AM   #1767
Dusttt's Avatar
Trader Rating: 118 (100%+)
So the blocks break before the arms? I will order the blocks but am a little confused as to which arms to order for spares. The ones on the assemebled pro kit just say CF so should I order short medium flex? Or?
I see that the ones labled graphite on Amain are C/F but should I get short or long? I would think that if I am looking for some extra rear traction I could run the stiff ones in front and the flex ones in the rear.
Dusttt is offline   Reply With Quote
Old 04-06-2010, 08:09 AM   #1768
There was a run of blocks in the first kits of the mi4lp that were made using a different material. It has since gone back to the original material. Unless you have one of the first batch mi4lp kits you should not have any problems with the stock blocks.
Old 04-06-2010, 08:35 AM   #1769
Dusttt's Avatar
So I hate to sound stupid but have no Idea which arms are even on the stock LP car. Which are best?
Old 04-06-2010, 08:53 AM   #1770
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
the short-c/f arms come with the lp.
u3549 front
u3550 rear
the short arms are way stronger because the webbing is beefed up. i would call any of the standard length arms obsolete at this point. they'll run fine, but they are brittle unless you run the medium flex versions, which have tons of flex.
stick with the above. if you're breaking them, you can go with the short-med flex versions.
u3551 front
u3552 rear
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Hot Bodies Cyclone Frank McKinney Electric On-Road 19761 10-14-2016 03:50 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 07:38 PM
2009 SEQ Onroad Interclub LOSI123 Australian Racing 348 01-06-2010 10:08 AM
Racecraft TC Challange 2 Kylelim Singapore R/C Racers 82 08-01-2009 12:07 AM
Schumacher Mi3/3.5 parts and roller!!! Eastcoast13.5 R/C Items: For Sale/Trade 21 07-19-2009 01:15 PM
Opinions on TC's hippie Electric On-Road 58 07-08-2009 10:14 PM
