Old 02-10-2010, 04:35 PM   #1576
GSM Storm's Avatar
Trader Rating: 112 (100%+)
Originally Posted by Danny-b23 View Post
If the rear is just hanging on, I would also try taking some droop out of the rear.
I was thinking about that as well, the mod guys in our team are running 4 on the huddy gauge, with this new speedy it is like driving a slow mod car
Thanks again Danny
Regards
Gary
Driver Gazza
Offroad - RC10 B64 (soon)
Vintage - Kyosho Tomahawk
Fantom Racing, JConcepts, Ace Hobbies/Reedy,
WTF, Plaig Bearings.
GSM Storm is offline   Reply With Quote
Old 02-10-2010, 05:15 PM   #1577
AdrianM's Avatar
Thanks again Danny
Regards
Gary
What tires are you running?
How many runs do you have on them? Most tires are only good for 3-6 runs (except Take Off RP30's and RP36's, they last twice as long). They will all start to push after that.
How are you applying traction compound and what are you using?
Are you using tire warmers?
Sedan setups are kinda complicated because one adjustment may have one effect on power and the opposite off power.
Is your son's understeer happening when he lifts to enter corners or when he is rolling on the throttle? Less front droop can help an on power push. This reduces the weight transfer to the rear on power.
Adrian Martinez
Old 02-10-2010, 05:53 PM   #1578
GSM Storm's Avatar
Tires - Sorex 36R, inserts B-Med 3 runs at the start
Traction Compound - Buggy Grip 2 at night
Tires warmers - Yes 50deg C, track temp 30deg C
Under steer is mid corner to exit at full throttle more or less, it turns in ok.
Using the Tekin speedy now the car is faster at the top end, it allways had a bit of a push with the SPX but now he is having trouble keeping a tight line.
Regards
Gary
Driver Gazza
Old 02-10-2010, 09:31 PM   #1579
AdrianM's Avatar
Regards
Gary
Hmm, you probably need to shed rear traction to let your spool yank the car where you point it.
Try to get the car to ride on its nose more. Run white springs front and rear. 35wt oil front at rear. 3 hole 1.2mm hole pistons front and rear. Thin sway bars front and rear. It may sound totally backwards but try leaning you rear shocks in all the way on the rear shock tower. We found that you get more rear rotation by doing this.
Also, buggy grip give a ton of steering early in the race but seems to fade later. Try Trinity Tire Tweak instead. Use the buggy grip to wipe off the tires before you run.
Adrian Martinez
Old 02-11-2010, 09:31 AM   #1580
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by STLNLST View Post
No...that was a black car with a couple of purple pieces on it Yep this will be #3.
Ohhhh. Alright I got yah now.
To many cars
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 02-11-2010, 02:13 PM   #1581
ByteStream's Avatar
Default Some Questions ..
With a new Mi4LP box stock with Lipo is the chassis balanced? If not, how much weight is approximately added? Was thinking that the optional battery brace might be a good way to add weight to the Lipo side if needed.
Does the optional battery brace, truely secure the battery or is tape still needed?
I've read that there has been some issues with bent drive shafts, has this been addressed with the Mi4LP?
Are there any other parts on the Mi4LP that tend to break/bend more than others?
What is everyones's impressions of the box stock kit on carpet/rubber?
ByteStream is offline   Reply With Quote
Old 02-11-2010, 02:36 PM   #1582
Racer X's Avatar
Balancing the car is achieved by moving the motor in or out as needed. The motor mount is actually a clamp that tightens around the motor to secure it. If one side of the car is heaver than the other, loosen up the clamp and adjust the weight.
As for the battery brace, I have always used tape so I can't help you with that.
Hit anything hard enough and it will either break or bend. I have broken one drive shaft, but I probably helped it break.
Nothing unusual breaks...I always have spare arms and caster blocks. Early cars had a problem with the hinge pin mounts, but that was quickly corrected...I have always run the alloy ones so I didn't have any problem. You will need extra shims for changing the set up and either the P-Dub or Parma bumper...and spare 64 pitch gears (if you choose to run 64 pitch).
Other than the alloy hinge pin mounts and 64 pitch gears, my car is box stock and (IMHO) probably the best car out today...strong, very tunable and FAST. Probably the best car since the A2. Hope that helps...
Schumacher Mi6
Speed Passion Motors and ESCs
Integy
SpeedWorld Raceway Roseville CA.
Racer X is offline   Reply With Quote
Old 02-11-2010, 02:57 PM   #1583
The car is balanced, i mount option 1 transmision, (right hand pulley), and without weight add is perfect balanced, i have some titanium parts, screws, balls, ...and the total weight are 1340g, with AMB transponder in front of battery.
I donīt have any issue with outdrives, are one of the best, and i run with mod motors and Lipos, but the belts are not the best to run mod motors.
I broke original pivot blocks, i put all news and donīt broke anymore.
Is very easy and fast to work in it, and the shocks are very high quality.
In the track, is a car more easy to drive, with certain tendency to understeer, the rear are more planted, and very smooth transmision, all litle changes in the setup are quite noticeable, great car.
Greetings, Luis C.
## NOSRAM ## YOKOMO BD5W ## BMI DB12RR+ ##
luic is offline   Reply With Quote
Old 02-12-2010, 10:12 AM   #1584
jcan240sx's Avatar
Default Feedback
Originally Posted by turbodog View Post
I didn't race a Superior yesterday but am there almost every month, look for the big white trailer, if you need some help we'll get you going in the right direction.
Who can we go to to for anodizing if we are not black?
I am assuming you mean help with the schumacher mi4. Also if you are running the schumacher how are you doing against the otehr cars.
jcan240sx is offline   Reply With Quote
Old 02-14-2010, 02:41 PM   #1585
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
Selling my MI4lp and a new in box car. lots of parts in my stock. PM me for details..
-Mike Owen
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 02-14-2010, 07:08 PM   #1586
STLNLST's Avatar
Trader Rating: 19 (100%+)
-Mike Owen
Why.....you getting out the hobby? BOR isn't that bad
STLNLST is offline   Reply With Quote
Old 02-14-2010, 07:20 PM   #1587
Ohh heck no! Just making my 4th car switch since early august. I drive 5 hours just to club race at speedworld. Im never leaving this hobby
Old 02-15-2010, 07:20 AM   #1588
ByteStream's Avatar
Default Mi4LP Carpet/Rubber
Anyone running the Mi4lp on carpet/rubber box stock or close to it have any feedback? likes/dislikes? compared to other kits in the market, T3 specifically?
Old 02-15-2010, 07:36 AM   #1589
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
it's good. i prefer the original mi4 chassis because we don't need to get down below 1420g and it gives us the cell cutouts for counterweight. our cars are stock, and have been fairly good all season in stock/superstock.
i like the durability, the resistance to tweak, and most of all, the originality.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 02-15-2010, 07:41 AM   #1590
The Bear's Avatar
Hey guys (and Goetz)
really picking up the pace with my MI4. I'm going to post my setup soon, but I've been running 17.5 Rubber at Madness (full size track) and have to say that it is the easiest to drive, fastest car I've had yet.
Love this car.
Casey
p.s. (and Goetz) because we are all a bunch of guys.... Goetz is a Maaan...
Sponsors for 2013 - NoVak / Team Scream / liquidrc.com
The Bear is offline   Reply With Quote
Hot Bodies Cyclone Frank McKinney Electric On-Road 19761 10-14-2016 03:50 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 07:38 PM
2009 SEQ Onroad Interclub LOSI123 Australian Racing 348 01-06-2010 10:08 AM
Racecraft TC Challange 2 Kylelim Singapore R/C Racers 82 08-01-2009 12:07 AM
Schumacher Mi3/3.5 parts and roller!!! Eastcoast13.5 R/C Items: For Sale/Trade 21 07-19-2009 01:15 PM
Opinions on TC's hippie Electric On-Road 58 07-08-2009 10:14 PM
