Hehe, why is it, the more I look at Marc's car, the more I'm convinced he wasn't running it at 1350g... with all that lead on the chassis, and loads on the cells, there's no chance I count 95g odd of weight...
Viktor's looks more believable, looks like only 30g, which given I've got 20g on mine at that limit, I can believe
Wilck's batteries are loaded about 50grs on the bottom side...seen at ETS
Jilles, may i know why you mount your wing further back during the Thailand Electric On Road Championship 2009, is it because the traction not so good ???
In the Euros 2010 warm-up race most people run much heavier cars as they were optimised for the 1400 limit using sorex 28, our last inside seasons official tires. The Xenon set, seen first time on the race day, was about 28 gr heavier. This brought the weight up for all.
Also the TRF team was around 1435-1440 gr in the inspection.
Hi Jilles, i just saw that the track has changed for TITC in feb.
Do you know which direction the track is, and what hotels are people planning to stay at.
Bradd Vercoe
Feral Racing Batteries
Windsor Hobby and Racing Centre
unit 21/64 Drummond St
South Windsor
Ph. 02 4577 3166
Congratulations with your off-road contract.
It seems you want to get all there is with RC cars, I hope that you
beat Brian Mayfield and Atsusi Hara in the future.(fair and squire off course)
I took that pic and i know there is another cut on the front of the topdeck, just where that steering alubrace scruw hole is, but shadow just fade that place..
Racingfactory.fi -> GM - LRP - Futaba - Tamiya Mini - Tamiya 415MSX MRE - Tamiya 416 WE
finally..JGH will come to Jakarta, Indonesia (about 4 hours flight from Bangkok) to race Modified & Stock Class in our National Year End Race on 28-29 Nov...
any one want to joint???
TRF 416 WE - S9351 Volac - SP 4.5 MRE
M 05 Pro - S9550 - GTX - Lightly Tuned
12 R 5 - S9650 - VFS 1 Masami - Peak Racing 11T
Oli,
I haven't talk with the TRF guys about the ETS race. But I'm sure they used superglue on the sidewall.
Sometimes a softer car also helps to avoid traction roll as Stilo explains.
Stephtruc,
This trick was the trick we use in Hungary last year with the ETS race.
Tony was so fast whole weekend and after the qualifications he explained he used 7 and 6 droop.
On sunday I tried this and my car was much easier to drive and less traction roll.
Ed,
I have measured this sometimes on the camber gauges and it was about 25 degree.
I use normally just enough lock that the steering blocks stil has little play till it touch the casterblock.
Mark,
I did not attend the ETS serie in Germany. I actually don't know the new weight rule.
In Thailand we have 1400gr. minimum weight. This is the same as it was with 5 cell so I put all the extra weight to reach 1400 gr on the lipo side. This is a good balance. I suggest when there is a 1350 minimum weight to install the Lipo pack a little bit more outside of the chassis, about 5mm.
Dameetz, QWCL,
Thanks. I still ran the 416WE version at that race. At this moment I'm building the 416X. At the race I used Lipo and 4.0T motor from Orion.
Gearing 8.6 Power program on the nosram 2!
Kschu,
Yes, I normally mount my wing as far as legal(10mm behind the rear bumper).
Besercoe,
This is right. The TITC will be at RC Addict. Very nice location, about 8km east from RCS. Don't know much about hotel in that area.
Jonest,
Yes, the new motor mount fits the previous 416's.
TRF 416 UK,
Try to use some arm sweep in the front. D - B blocks
t4m1y4niac,
Do you know anything about the rules next week? What tyres? What motor for stock? Minimum weight?
See you next week!
Jilles
p.s. Does anyone know how to change the Thread name to:
"ask" Jilles Groskamp Tamiya 416(WE/X), Team Orion Motors
