"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors >
Old 04-20-2010, 12:12 AM
  #1021
vadersing's Avatar
Default Poor traction on concrete
Hi Jilles
I will be racing my 416 on a temporary concrete surface track with very poor traction.
I am using the standard set up from the user manual, which worked well on high traction asphalt.
Could you recommend a set up please (camber, droop, shock oil, springs etc)? And which Tamiya tire works well on a dusty concrete surface?
vadersing is offline
Old 04-21-2010, 04:56 AM
  #1022
Hi Jilles
I believe I'm right in thinking you're still running KO radio gear??
I'm after a new servo for my 416 - most probably a low profile type. What do you use, and what would you recommend?
Oli
Bigger Brother is offline
Old 04-21-2010, 10:37 PM
  #1023
Akudou's Avatar
Default Mr Jilles
Hello Mr Jilles, you have PM. Thank you very much.
Akudou is offline
Old 04-22-2010, 03:11 AM
  #1024
JGH
Joel - Normally I never run drag brake running stock motors. It will heat up the motor more and stock motors have already a lot of drag brake itself.
I have tested the mini with long wheelbase back to back with medium and I find on most conditions the medium wheelbase is the faster one.
Vadersing - I recommend the following changes to change while running on low grip surface.
- Camber, little less, 1 degree
- Kick up rear, this helps on power traction, 1mm/0mm
- less droop, more uptravel, try 5mm/4mm
- more toe-in
- 30W shock oil, with soft springs
For tyres I recommend soft type such as Sorex 24R, Pit Shimizu wet tyres.
From Tamiya you even can try the rally tyres from the DB03R.
Also use soft sponge inserts instead of molded inserts.
Oli- Yes, I use KO radio gear. I have been using the 2367 KO servo for a long time in my TC. I like the 2367 as it is strong and powerfull. The 2413 low profile is a good option, but I feel with 2367 I have more consistant steering.
Jilles
JGH is offline
Old 04-22-2010, 03:27 AM
  #1025
CLK@racing's Avatar
Jilles,
How different will you setup your car if you are to run stock, say 11.5 compared to modified.
Springs, shock oil, roll center, downstop etc.
Thank you.
CLK
P.S. Hope you are fine at Bangkok, looking at the news, situation is not getting any better. though the media tend to sensationalise issues.
CLK@racing is offline
Old 04-22-2010, 06:05 AM
  #1026
musti72's Avatar
Hi Jilles,
I watched your pro tips on youtube, and I have a question. I see that you use sticky Tamiya Hard grease between diff outdrive and the diff plates, but that grease is hard to find. I already have tamiya AW grease, which is also very sticky, so can I use that grease there?
musti72 is offline
Old 04-22-2010, 08:19 AM
  #1027
Barry White's Avatar
Jilles
Hi. Have U tried the alu casing or is it to rigid/heavy?
Barry White is offline
Old 04-22-2010, 11:09 AM
  #1028
Jilles
Cheers for the info. I've had a (?)2343 for about 4 years now with no issues, so hence me wanting to stick with KO.
Oli
Old 04-22-2010, 01:38 PM
  #1029
Hi Jilles, I have a WE. I see some have flipped the belts to move electronics more to centerline. Should I do this? If so, ball diff located higher to clear the chassis? Have you tried a gear diff in the rear? Thanks again.
rccartips is offline
Old 04-23-2010, 11:06 AM
  #1030
energydrink's Avatar
Hi Jilles . My local track isnt allowing tire sauce . how would you change your setup to compensate from being able to run additive, to not being able . This is on asphalt sprayed with soda . Thanks .
energydrink is offline
Old 04-23-2010, 06:03 PM
  #1031
Akudou's Avatar
Default Mr Jilles
Hello Mr Jilles, please check your inbox for another pm.. Thanks
Akudou is offline
Old 04-25-2010, 07:22 PM
  #1032
geeunit1014's Avatar
Trader Rating: 14 (100%+)
Jilles, I have a question:
Im very happy with the way my car is handling, it does have a slight understeer, but it makes the car consistent in the low to medium grip parking lot we race in. The problem I have is that the car is wearing a "death ring" (ie heavy wear on the inside bead of the tire) on the left front tire. Other guys running the same tires dont have this same problem. Anything you would suggest changing? If it was a bgi race I wouldnt care, but since its just club racing id like to get more than 1 weekend out of a set of tires My setup is attached below
File Type: pdf
geeunit1014 is offline
Old 04-25-2010, 08:07 PM
  #1033
vadersing's Avatar
Thanks for the tips, Jilles.
What do you mean by 'kick up rear'?
- more toe-in
Jilles
Old 04-26-2010, 02:30 PM
  #1034
20967's Avatar
Hello Jilles
Enrico Cardani from Italy and I want some info to get a better setup in my/our 416x.
So, when I ran indoors, and copying your setup, everything went well; now in our Racing Club in Milan when Solaris tires are imposed (before with medium insert and hard now) we have a lots of troubles.
Here my/our problems:
The track has an asphalt abrasive, not smooth without bumpy with medium/low grip surface; the category is powered by 10.5.
The cars use much internal tire (front and rear) and after 4/5 rounds are destroyed; the car have a lots of slipping; sometimes seems to drive on ice.
The guys that use the same setup with LRP or Novak 10.5 motor and a body similar to LTCR Protoform have a good balance, other with same setup and Mazda 6 or Mazda 6 Speed Protoform powered by SpeedPassion V3 10.5 or Lipotek 10.5 have many troubles.
I send two setups:
The first setup it’s relative at the race start; the second at the end race without better balance.
Can you give us some Help?
Attached Thumbnails "Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors-vedano-2a-.jpg   "Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors-vedano-2b-.jpg
20967 is offline
Old 04-26-2010, 03:32 PM
  #1035
CraigM's Avatar
Trader Rating: 34 (100%+)
also known as antisquat. The spacings he refers to (1mm/0mm) are the numbers of spacers to add under the rear suspension blocks
CraigM is offline
