Carpet Racer
Carpet Racer
Howdy guys I'm new into the whole world of RC's... Currently I only own 1/8 off road nitros.. I'm looking into getting into the 1/10 AWD touring cars... I would like a good decent brusless rtr platform to tinker around with until I can afford an XrayT2009.... I'd appreciate some good guidence on this please...
Ive been looking at the HPI sprint 2 Flux as an rtr and the losi JRX-S... but I'm not sure so any help would be great...
Thanks,
Alex
Thanks,
Alex
Hi mate, if funds are limited, I would have a look at one of the new breed of 200mm pan cars. I have a BMI chassis and it runs brilliantly. I know that you are intrested in TC's but after running mine around our local track, loads of people came over to see what was under the shell, and then really suprised to see it was a pan car with 'only' a 4 cell pack in it! It outran the TC's with ease as well!! By getting one of these chassis's, that would save you a fair bit for your brushless setup, etc. Food for though, cheers!
You can't go wrong with a 200mm Pan Car. These cars have been gaining massive popularity recently because of ease in setting these cars up and how much fun they are to drive. They cost a bit less than touring cars as well.
You should look into a car that accepts 2s LiPo battery packs such as the Darkside, CRC Gen X 10, Corally CCT, and the BMI 10R with LiPo plate. 2s LiPo and 17.5/21.5 comboes are popping up all over the place recently for both indoor and outdoor. 4-cell NiMH packs are becoming "passe" nowadays.
i am for sure running a 2 cell lipo indoors.... some somthing in the 10.5 turn motor.... also whats a pan car? 190mm is the restriction on car length in the competitive racing in-which i want to compete in...
Alex
Alex
the 190mm is related to the width. you want to race in 10th Electic Touring Car. Try speed passion motor/esc combo, should save you some pennies. 10th Pan is a new class, 200mm width and rear wheel drive. Look in the For Sale section on this forum and you'll probbly find a nice bit of kit. There's hardly any brushless rtr packages atm, your better off paying seperately. If you do want a RTR package, i recommend the Cyclone RTR's decent cars, good setup and great start to TC's. With your xray in mind, the Cyclone isn't that different, so you will be able to take most of the things you learned from the cyclone to the xray. Hope this helps...
Even though you're budget minded, dont go with a RTR setup like the Cyclone S. Buy a good used high end chassis instead. Cyclone TC's are better since they have the aluminum parts on there already that will save you loads of broken plastic/graphite parts down the road.
Because you'll end up spending all this money on a RTR only to want more. And you'll lose in on your investment as a lot of these RTR dont have good resale at all. I learned that the hard way. So did my wallet...
So I'd say a used chassis, a lipo, lipo charger(onyx230), a radio system, and electronics of your choice. If you want new, and are willing tot ry out a new company. Teamwave, from what I hear, is putting out a really amazing ESC/motor combo. The motors are Speed passions relabeled. Teamwave isnt new themselves but there ESC/motor are. Radio you can go spectrum now used for well under $200. Or look into somethign cheaper if you want to.
But I will say this. You'll want to upgrade. It happens. And when you start off on the cheap side, you end up in the long run, spend ing a lot more money, than if you just bought good stuff from the start. And good doesnt even mean expensive. YUsed radio and chassis arent that expensive.
My local hobby shop has a brand new Xray T2R pro for $300...
I'm just not sure yet i wanted some opinions....
so who makes the best motor/esc combos? teken, castle creations, novak, etc.?
Thanks,
Alex
I know it's an older car design, but the TC4 is still a very good option for a beginner. It has all the tuning options you could want and it's easy to find parts for. It's also very durable. At a club level, it's very competitive. You won't be able to take advantage of the capabilities of high end cars until your driving and setup skills have improved anyway.
Stay away from the Sprint. It is a good basher, but not a very good racer.
Other cars you might want to consider are the Tamiya TA05 series and the Associated TC5F.
In the end, I'd go with what you can get parts for easily at the LHS.
About used cars, they can be a double edged sword. They may cost less up front, but in the end, you could end up investing more than new to fix problems created by the prior owner. So, be very well educated about the car before buying used.
is the TC4 belt driven?
Alex
Alex
academy str-4 pro-2 was my first real TC. very good car for the money, carbon chassis and top deck , shaft drive,easy to drive, pro qual shocks, CVD axles, steel outdrive cups, etc. plus it is very cheap compared to alot of other cars. I would highly reccomend this for you if money is a llittle tight. I also have a used one I used as a rolling spare parts car when i ued to drive the academy that i could sell you (Ill give you all my setups for it too =D)
no it is shaft, but at this stage I think that is negligible since you will be learning how to drive for a while. as for motors and speedos,
the speedpassion grandturismo FPF is good, has a little programming card so u dont have to do the blinky light thing, but i have also heard good thing about the tekin's performance, plus that can hook up to ur PC to program its values. For motors I just recently got both an orion vortex and a High velocity(trinity) duo (dont get the pulse), and i am very happy with the performance of both. in fact the orion was what I won my regional title with (plus it is much less noisy/squeaky than the novaks) but the novak motors are okay too, and there alot of used ones on the market so you could probably find a decent one for cheap.
well im looking at the tc5f and losi jrxs-r since my lhs carries all its parts for those... theres a losi jrxs-r in the tade/sell forum im looking at... it seems like a good deal but once i get it ill have to buy lipo and bushless ystem to go in it.. im still toying with my options...
e-mail me some pics of your car mike? [email protected]
Alex
Alex
bump....
mike i want some pics bud...
Alex
Alex
Location: Somewhere between raising hell and Amazing Grace
Trader Rating: 38 (100%+)
+1 for whoever said buy a used high-end...since you are planning on running the 009 eventually, I'd suggest checking the for sale threads and fleabay for a nice 007. There are plenty of good deals that include spares, something you will need plenty of running carpet. You didn't specify if you are running rubber tire or foams, so if you go the TC5 route make sure you get the R for rubbers and the F for foams.
-rocky b
-rocky b
+1 with the suggestions.
It's very easy to outdrive a fully built RTR that you'll probably need to upgrade/replace later anyway.
I had the tc3team for a few years and came to my senses that it was the car that was the problem, not me.
Now I have the car and the speed and i'm back to learning how to get even quicker, with the all important consistancy
