Novak GT7 Question....
I just purchased this speed control and I was wondering if I could remove the circuit that is under the shrink wrap.
The reason for this is that the wires are way to long but I have never seen anything like this on any other speed control I have owned.
Thanks....
Thanks....
Re: Novak GT7 Question....
Thanks....
Thanks....
Yes, you can take it out, but you'd have to put doides in your motor, personally, i wouldn't, it makes your motor run more "cooler" and reduces "noise"
Run the new circuit, I have added it to my older Novaks. You have to make it fit. How are you and the family?
john
john
You can take it off and resolder it onto the wires somewhere else but it needs to stay on there. Novak also offers it seperately with 2 wires off of it that you can solder onto your motor or elsewhere as long it's on the positive wire and negative motor wire.
Thanks everyone for your responses.
Does anyone have any pitures with a TC3?
Thanks.....
Thanks.....
I don't know if this will help or not, but these are images of my BMI TC3 with the NOVAK GT-7 installed. I use a standard Schottky diode inline as close to the motor as I can within reason. This keeps me from having to have several schottkys on the several motors I run.
gt-7
correct me if i am wrong, but i think removing that diode also voids the warranty?
that's what it said in the instruction menu
i think you can use the stand alone doide novak sells
nicely done...i love the GT7's.
It's no problem ditching the new diode. Just put everything back when you send it in. Running all the extra stuff on the GT7 depends on what class you're racing.
In 6 cell Sedan, there's plenty of room for the new diode so you might as well run it. In 12th, You can take it off and just use the normal diodes that you always have.
Also, in stock 12th you can ditch that huge capacitor. I would definately run it in Mod though.
Novak needs to update their instructions then because a rookie like me would not know that the thing shrink wrapped was the diode. I have been soldering diodes to my motors too and it has been a major pain. Novaks instructions say you have to actually add a diode to the motor, if they have it built in now why have not not updated or at least added a drop in to say so??
I recently purchased a GT7. Your right the instructions are outdated. However, My GT7 box did have a notice in there that explained the new diode. It was tucked away under the decals that came with it.
I use the GT7...and removed the shrink wrap from the diode and soldered it directl to the power wires..
see my mod at:
http://groups.msn.com/RCZOMBIES/novakdiodemod.msnw
see my mod at:
