Old 03-26-2009, 11:27 PM   #1
Default Solder inside a brushless motor
I have a brushless motor where the winds desoldered, i have resoldered using some 60/40 solder, yet everytime it heats up now, it desolders. What solder do they use inside these motors that can withstand heat?, is it some lead free solder, like 97% tin or such?
Thanks Ya`All
MoonTrap is offline   Reply With Quote
Old 03-27-2009, 03:48 AM   #2
Trips's Avatar
Trader Rating: 16 (100%+)
It's a high temperature solder. The typical 60/40 or lead free solders we're using melt at a much lower temperature.
Trips is offline   Reply With Quote
Old 03-27-2009, 04:18 AM   #3
LOSI123's Avatar
Trader Rating: 63 (100%+)
Also if it has become desoldered, its probably overheated the wire in the windings and thus burned some insulation and now is slightly shorted out and will now forever overheat. It may still work but it would still be considered stuffed if it is getting very hot all the time now.
Team Durango - Speed Passion - Gens Ace
LOSI123 is offline   Reply With Quote
Old 03-27-2009, 05:02 AM   #4
Trader Rating: 16 (94%+)
If it is truly just a soldering condition, use solder with low lead content. I believe Silver solder has a higher melting point.
If your "brushless motor" is a Trinity Pulse model, than you will not likely be able to correct the issue, Trinity's supplier tried twice already. If it is another motor, than you probably have a motor problem that will require replacement.
kn7671 is offline   Reply With Quote
QCRCCC OFF-ROAD RACING emer Manila Racers 16543 04-08-2016 12:31 AM
Race Results Addict sa RC Manila Racers 1028 03-29-2016 08:55 PM
why need for standard 13.5 motor?? magm20001 Electric On-Road 48 12-11-2007 04:15 PM
BRUSHLESS MOTORS Now Legal At ROAR Races & The IFMAR Worlds!!! STEALTH Electric On-Road 315 03-22-2005 03:09 PM
SEO by vBSEO 3.5.0
