Old 03-23-2009, 04:02 AM   #1
Default TT01D problem continues, HELP!!!!
Now im really frustrated, issue started when the car just wont get up to speed, after about 5 seconds it has a burst and will get there but really struggles.
Took the car apart and everything seemed normal so re assembled. Must be a problem with the esc or motor????
My mate came over and i put his motor in and hey presto it was off like it should be and shot around for about 5 minutes no problem at all, from this today i went out and bought a new replacement motor came home put it in and it has the same problem again????
How can it work with his but not my old or a brand new motor?
I just dont unerstand what is going on and its driving me bonkers!!!!!!
Can someone help as i cant find anything online.
The gearing has been suggested but im frustrated with buying new parts and they dont fix the problem....
Help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!:co nfused:
adsy76 is offline   Reply With Quote
Old 03-23-2009, 05:51 AM   #2
Trips's Avatar
Trader Rating: 16 (100%+)
What speed control are you using?
What motor were you using that wasn't running properly?
What motor was iot from your friend that did work?
What new replacement motor did you try that wasn't working well?
Trips is offline   Reply With Quote
Old 03-23-2009, 02:47 PM   #3
Its all standard TT01D.
The 3 motors are exactly the same sports tuned tamiya?
The ESC is the TEU 101BK.
Old 03-23-2009, 05:56 PM   #4
Errrm, you could check for a hung brush (dirt inbetween the end of the brush and the armature).
Also, could it be a radio problem? Is the car glitching at all when its accelerating?
Is there anything that your mate did to the car or replaced things with his own when he swapped his stuff over? (Did he use his own transmitter?)
Tamiya TL01
Tamiya TA05 (ish)
Associated B4 3.5r
Limerick91 is offline   Reply With Quote
SEO by vBSEO 3.5.0
