Old 11-26-2003, 06:34 AM   #1
CRASH's Avatar
Trader Rating: 26 (100%+)
Default Favorite Diff Building Tips
Alright what are your favorite diff building tips? What is your favorite diff building grease?
This is for all types of cars.
CRASH is offline   Reply With Quote
Old 11-26-2003, 07:35 AM   #2
akrcracer's Avatar
I have tried Losi, Associated, Aero Car & Niftech diff lube. The best diff lube of all of them is Niftech Rocket Ring Diff Lube. It works good in my 12th scale & my touring car.. I also polish my diff rings with 1000 gid sand paper. And break in fresh diffs with a my dremel tool. I find a felt polishing tip that fits in outdrive and carefully turn on my variable speed dremel tool to slowest setting. Run tool for a minute, then swap outdrives... Retighten diff, run dremel again. This saves time.. 80-90% of time I never have to retighten diff in car..
akrcracer is offline   Reply With Quote
Old 11-26-2003, 08:01 AM   #3
pheyhoe's Avatar
R/C Tech Charter Subscriber
Default Diff lube
I use silicone lubricant, plumbers use it, i dont know what for but they use it. it makes my diffs run as smooth as a.. erm. hmmm smooth object..
[SIZE=1][COLOR=navy]Paul Heyhoe[/COLOR][/SIZE]
pheyhoe is offline   Reply With Quote
Old 11-26-2003, 09:03 AM   #4
sosidge's Avatar
1) Clean components.
2) Plenty of greasy grease (like Associated black) on the whole of the thrust assembly.
3) Not too much silicone grease (e.g Associated Stealth) on the main diff balls, coated evenly around them.
4) Tighten the diff until gently hand tight, put in the car, and adjust to your own taste.
Works for me.
building tips for the 808? revracer222 Nitro Off-Road 2 08-06-2008 02:16 AM
Building off-road track, any tips? Brian Searles Chat Lounge 2 05-28-2008 06:03 AM
Looking for Track Building Tips beerbarron Electric On-Road 6 12-06-2005 10:43 AM
Kit Building Tips tjrcs Nitro On-Road 3 04-13-2003 10:18 PM
TC3 Shock Building Tips? CRASH Electric On-Road 2 03-25-2003 04:21 PM
SEO by vBSEO 3.5.0
