Old 03-18-2009, 03:54 AM   #1
vladconnery's Avatar
Trader Rating: 35 (100%+)
Default Traxxas ?
Is it possible to run other motors on the traxxax brushless ESC. Thanks all help is appreciated.
Kyosho: TKI3, TKIe Tekin RX8 Gen2
vladconnery is offline   Reply With Quote
Old 03-18-2009, 04:24 AM   #2
pyro18t's Avatar
Yup, the VXL system is a sensorless system... so any sensorless motor will work, as long as it's within the ESC's rating. So if your ESC is only rated to handle a 3700kv motor, don't go out and buy a 6500KV motor. Some sensored motors will also work without the sensor wire pluged in, but if I were you I'd stick with a regular sensorless motor.
~ Jason Kennedy ~
~ Sweep Racing Tires ~
~ TQ Wire~Wire~
pyro18t is offline   Reply With Quote
SEO by vBSEO 3.5.0
