help needed urgent
help needed urgent
Hi guys,
I just installed my universal drive shaft to my e10, removed the small ring from the hex hub as it seemed like it wont fit in poperly with the ring on the hub, went for couple of runs and ı found out that the inside of the hub has melted. I later found out that I should have used 26mm screw with this set(I used 24mm instead) and when I put 26s on, the wheels seem so offset and they seems to rotate freely. Dont know what to do.. Also do westill need to use two bearings when we install this kit as it is not clearly shoen on the instructions.. Thanks in advance...
