Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 11-24-2003, 07:40 AM   #1
Vinyard's Avatar
Default Matched cells
What are matched cells?
How come they are better then single cells?
can somebody help me pls.
Vinyard is offline   Reply With Quote
Old 11-24-2003, 07:45 AM   #2
fatdoggy's Avatar
R/C Tech Charter Subscriber
Originally posted by fatdoggy
When you cycle a cell each cell has different numbers, like what was the average voltage, peak voltage, internal resistance. Matchers take similarly spec'd cells and build battery packs. If a battery is matched it will last longer if treated well and gives better performance bacause every cell in the pack is giving close to the same amount of power.
fatdoggy is offline   Reply With Quote
Old 11-24-2003, 07:50 AM   #3
GTO2's Avatar
May not answer directly to your q (?) but browse on, read this
hope it helps a bit.
GTO2 is offline   Reply With Quote
Old 11-24-2003, 07:51 AM   #4
highwayman's Avatar
To put it in a nut shell... matched cells are exactly what the name implies... they are "matched" together or "grouped" together along several parameters such as voltage, run-time and IR
They are better in the sense that all six cells will perform almost "simultaneously" giving off "power" at the same rate and at the same time... no one cell will be dead before the others.
hope this helps.
highwayman is offline   Reply With Quote
Old 11-24-2003, 12:08 PM   #5
Jon Kerr's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to Jon Kerr Send a message via MSN to Jon Kerr
One way to look at it is like a chain. A chain's only as strong as it's weakest link, a battery pack is only as strong as it's weekest cell. If you have one bad cell, you'll get short run times and feel short on power. It'll feel like you're running on a 5 cell instead of 6.
Jon Kerr is offline   Reply With Quote
Old 11-24-2003, 11:24 PM   #6
Cole Trickle's Avatar
Well spoken ! In addition, that "bad" cell (it might just be sligthly) will be stressed, since it'll be empty before the others. So it will be overdischarged. Even thogh cells are pretty tough, it will die before the others.
Tamiya DF-03 w. slipper clutch, 18x1.
Schumacher Mi2 - HPI Pro2. Both racing indoor carpet, stock class.
Cole Trickle is offline   Reply With Quote
Forum Jump
matched 4 cells chadlow21 R/C Items: For Sale/Trade 4 04-04-2008 06:14 PM
Why Buy Matched Cells? YR4Dude Electric On-Road 29 09-25-2006 11:42 AM
Matched cells frozenpod Electric On-Road 19 12-06-2004 04:40 PM
SRC matched cells- any good? rcpilot Electric On-Road 1 07-08-2003 05:04 PM
matched cells in sg? alucard Singapore R/C Racers 8 03-11-2002 05:18 PM
Powered By: vBulletin v3.7.6
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
