Old 07-13-2009, 06:54 PM   #1396
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
Originally Posted by L.Fairtrace View Post
Actually im trying to get my hands on a oneway and I will come down a whole day this week and get a setup for the people with the Photon at the C. The problem is finding a oneway that will work that I can get my hands on this week.
Teach ....has mine... I need to get it back from him...
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 07-13-2009, 06:58 PM   #1397
syndr0me's Avatar
Trader Rating: 32 (100%+)
Originally Posted by CraigM View Post
I couldn't get my Photon shocks to a point where I was happy with them so I put black TRF shocks on and havent looked back. even got the red ball mounts for them
Me too. I even got the red caps, collars and retainer. The TOP springs are a little big, though.
syndr0me is offline   Reply With Quote
Old 07-13-2009, 08:09 PM   #1398
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Originally Posted by Thirtybird View Post
Sorry, I was going by the google shopping result showing it at 379.99... regardless..
Shopping results for top photon buyCustom Cut Urethane Chassis Protector Top Photon $19.99 new - eBay
TOP Racing Products Photon Competition 1/10 ... $379.99 new - A Main Hobbies
Photon-Ologist Women's Tank Top $17.19 new - Betcha Like It
You have removed results from this search. Hide them
Loading...
slakr - where would one find this coupon code - I'd never ordered from them before, so I'm not on their mailing list...
Copy that ... $379.99 I saw it too.
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 07-13-2009, 08:19 PM   #1399
syndr0me's Avatar
Larry, do you plan to run a one-way or spool on carpet with 13.5?
Old 07-13-2009, 08:23 PM   #1400
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
I am hoping to use a spool it makes racing with people much much easier, and alot of track layouts now dont have a sweeper like the nats track and it makes running a oneway tough.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 07-13-2009, 08:41 PM   #1401
Originally Posted by Nova F1 Racer View Post
Larry, come on down to the C and I'll show you 2 shocks that leak through the top of the shock. Brandon Hess and Jamie Hanson both took a look at it and could not figure out why it was leaking...
I consider myself an above average when it comes to building shocks and I am going to take an engineering approach when I rebuild then again this week, build all 4 at the same time, step by step and take measurements..
From building a kit for a mate, the shocks have the same problem as the original cyclone shocks, the top cap is too deep for the threads, and it allows the plastic shock top to rotate in the cylinder, and not compressing the bladder fully to make a seal. If it were my car i would sand down the top ring same as i did with the Cyclone WE.
Also the overall finish on the shock body is pretty appalling.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 07-13-2009, 08:43 PM   #1402
smoke81's Avatar
Send a message via AIM to smoke81 Send a message via Yahoo to smoke81
HEHE.. I tried and tried and tired at Nats to do it with a one way.. And went from 7th back to 11th. One spool after another went on by . Just getting killed at the end of the straight, and the short shoot on the left side of the track.
Dustin Layne
smoke81 is offline   Reply With Quote
Old 07-13-2009, 08:50 PM   #1403
Sand down the top ring ?
Ummm What ?
Old 07-13-2009, 08:53 PM   #1404
smoke81's Avatar
Ummm What ?
I think he means the red cap that screws down against the black plastic part of the shock. If the red cap is to long it doesn't press the plastic part down against the bladder. Causing a leak.
Personally havn't had a issue with this, but it seems some are for sure.
Dustin Layne
Old 07-14-2009, 12:03 AM   #1405
Two of mine are leaking badly out of the shaft seal,Ill try another rebuild or perhaps a "quick fix" might be a very thin shim between the seal and retainer or shock body to compress it ??? "hopefully".....Its an irritating shame the shocks are very smooth,TRF's will be my last resort....good luck to all leaky shock owners!
Sponser,Reality Racing/CML
lesbaldry is offline   Reply With Quote
Old 07-14-2009, 12:31 AM   #1406
razzor's Avatar
There was mention that the Scythe oneway worked.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 07-14-2009, 03:39 AM   #1407
nocif13's Avatar
Send a message via MSN to nocif13
Originally Posted by razzor View Post
isnt the mount hole at the bottom offset like on the Scythe ?
I THINK THAT THE SERVO WAS NOT THE RIGHT SIZE, otherwise I drilled a hole on the chassis
teamspec/petitrc.com/TEAM WAVE/T.O.P racing/CBRacing.fr/rcmanufactory/Alien POWER/Team Terribles
nocif13 is offline   Reply With Quote
Old 07-14-2009, 04:32 AM   #1408
xray racer's Avatar
Trader Rating: 22 (100%+)
Dont forget that the plastic mounts for the servo ARE offset, so if you have attached one in the inner position, and one in the outer, this would cause the servo to be mounted offset.
Check the alignment of the holes on the mounts, and make sure they are mounted the same way before drilling the chassis.
Cheers
Robbie
Robbie Lloyd
Yokomo * HobbyWing * Sanwa
xray racer is offline   Reply With Quote
Old 07-14-2009, 04:43 AM   #1409
nocif13's Avatar
Cheers
Robbie
thank robbie
best regards
olivier
Old 07-14-2009, 04:46 AM   #1410
razzor's Avatar
Cheers
Robbie
Thats what i meant.
Happened to me when rebuilding my Scythe.
Casterracing ZX1.5R
