Old 07-09-2009, 03:17 PM   #1321
Send a message via AIM to HenBeav
Originally Posted by artwork View Post
rubber tire springs...
PS-TR15550 Gamma Spring 393gf/mm, 22.0lb/in (2 pcs)
PS-TR15575 Gamma Spring 367gf/mm, 20.5lb/in (2 pcs)
PS-TR15600 Gamma Spring 344gf/mm, 19.2lb/in (2 pcs) - Kit
PS-TR15625 Gamma Spring 324gf/mm, 18.1lb/in (2 pcs)
PS-TR15650 Gamma Spring 306gf/mm, 17.1lb/in (2 pcs) - Kit
PS-TR15675 Gamma Spring 289gf/mm, 16.2lb/in (2 pcs)
rubber springs at least
[URL]http://www.fastlanehobby.com[/URL]
Support your local Lowe's, Walmart and Layne Machine Works INC.
HenBeav is offline   Reply With Quote
Old 07-09-2009, 03:22 PM   #1322
Gone Racin's Avatar
i think they are 17lb and 19lb springs, someone else has posted the spring rate a couple of pages back. Ron H,
Gone Racin is offline   Reply With Quote
Old 07-09-2009, 03:29 PM   #1323
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Originally Posted by stonedgti View Post
Can someone explain what the poundage of the springs are that TOP has? 344 = to? 306? and all the other ones.
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 07-09-2009, 03:38 PM   #1324
syndr0me's Avatar
Trader Rating: 32 (100%+)
Originally Posted by jtveten View Post
It was meant to be humorous, see inserted, most everyone else understood. Sorry if it offended you.
Nah, no offense here, it's just frustrating when what seems to be legitimate issues get swept under the rug in favor of "nothing to see here" type comments. It's good to hear other people aren't experiencing the trouble we are, especially considering it's mod and carpet.
I really can't explain it. But I can say I've put hundreds of packs through my previous car (which seems to have been an influence on the Photon) under these exact circumstances, and have never had to think twice about CVD blades. My expectations for this part, especially with everything else on the Photon being so nice, are pretty high.
The way I see it... it's good for people to figure out and solve these small issues that aren't experienced by everybody. That way, there's less of a chance of visiting a new track (like a big race out of town) and suddenly finding out 8 spare CVD blades isn't enough.
Anyway, we're not just sitting idle and whining. Those of us having trouble are testing out all kinds of different ideas to try and solve it. A little free R&D, if you will.
syndr0me is offline   Reply With Quote
Old 07-09-2009, 05:09 PM   #1325
E.J. Evans's Avatar
Send a message via Yahoo to E.J. Evans
Free R&D works for me! Let me us know what you and Art find.
T.O.P. Racing | APEX Hobbies | R1 | Solaris | NorCal Hobbies |
Solaris Racing Products (SRP) Solaris Spec Tires!
www.solarisrp.com | www.apexhobbies.com | www.topracingusa.com
E.J. Evans is offline   Reply With Quote
Old 07-09-2009, 05:29 PM   #1326
Josh Cyrul's Avatar
Hey George - Keep in mind, I only had prototype or pre-production parts so I'm not 100% sure where the difference/tolerance problem is at. I know in the files it is extremely close if you run the rear end narrow. This was one of the reasons why I went with the cone washers instead of the spring.
Everyone else bought up all the kits so I am still waiting on a production kit also...lol... Hopefully, I'll have one soon and I can check it out...
Trinity, Destiny, Ko Propo, Hobby Wing, Ulti Racing Tires, Protoform, Zenon Racing, Pivothead, Vizon, TQ Wire & Hella Graphics
Josh Cyrul is offline   Reply With Quote
Old 07-09-2009, 06:52 PM   #1327
CraigM's Avatar
Trader Rating: 34 (100%+)
The 416 had the same prob with the 46mm shafts when running the short arms, that's why they came out with the 44s
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 07-09-2009, 09:26 PM   #1328
JimmyMac's Avatar
Actually, the original 416 came with 44mm shafts with long arms. I switched to 42mm shafts in the rear when I went to short arms. If anyone needs to source out 44mm shafts, if you can't find Tamiya ones, you can use Yokomo BD5 rears. They are 44mm as well. If you do not want to use steel rears, or want to stay away from Tamiya Blue, you can get Square Ti 44mm bones. Just some thoughts for you guys.
M.J. McIntyre
R1Wurks
Yokomo YRX12
Ho-B Max
JimmyMac is offline   Reply With Quote
Old 07-09-2009, 10:26 PM   #1329
artwork's Avatar
Trader Rating: 54 (100%+)
OK so EJ asked me to post some of my findings in relation to the blade situation. A replaced all of my TOP universals with Hot Bodies 44mm steel universals. unfortunately I had to do a little grinding on the ball end of each universal so that it would fit inside the out-drive, but that was pretty easy. Once I did that I installed Hotbodies blades in the rear of the car and TOP blades (had to ream out the holes) on the front of the car. I ran the car 5 times tonight and did not have one issue with the blades. After some close evaluation of the situation it is clear to me that the length of the universal is the problem and not the blades themselves. Of course this is my personal observation, but I think based on what I have been seeing with the way in which the blades are breaking that is indeed the case.
I am not sure if it has anything to do with the blades hitting the screw assembly or if it is getting caught in the out-drive during universal articulation.
I know that the Tamiya 44mm universals are a direct fit without any required modification, and might be a good option until TOP can release the 44.5mm universals.
I was thinking about the way the cars are shimmed and how that would indeed be a factor. So, I figured I would post what I am running in reference to the 44mm universals.
Front - Front: 0 spacers
Front - Rear: 0 spacers
)))) diff washers
Rear - Front: .75mm spacer
Rear - Rear: 3mm spacer
)))) diff washers
Hope this information helps people, but I am in no way talking for TOP racing, these are my own personal findings.
Thanks,
Art
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 07-10-2009, 12:03 AM   #1330
syndr0me's Avatar
That's great news Art! I've got some Tamiya 44's I can spread around Monday, if I don't drown in the river (or vodka) this weekend.
Every car has its quirks starting out. I hope this talk about blades hasn't discouraged anybody, this car is fantastic. I got the 416 before it was released in the states, and stayed up all night building it so I could run it on the track the next day. I was so tired I nearly fell asleep at the wheel on the way there. Anyway, on the first lap, I hit a board and decimated both front CVD's (aluminum). The car was forever nicknamed "rice cake" after that by witnesses (smoke81, HenBeav). I didn't have any spares, so it was a very discouraging maiden voyage. And don't even get me started on the steering tie rods, aluminum ball ends, and front/rear block. Definitely a rocky start for a car that's now being used to win a lot of significant races.
The thing about TOP, though, is that these guys listen to the issues racers have (even if you're not all-world team driver), and consider them carefully. That kind of care doesn't exist anywhere else in our hobby. How many threads dedicated to the various chassis have the engineer of the car show up and say why they made the decisions they did? Are you kidding me?
Anyway, that's about used up my online kindness for the year, so now it's back to being grumpy.
Old 07-10-2009, 12:13 AM   #1331
E.J. Evans's Avatar
)))) diff washers
)))) diff washers
Thanks,
Art
That's good news Art! We will have our 44.5mm really soon. Thanks for testing that!
Old 07-10-2009, 12:16 AM   #1332
E.J. Evans's Avatar
Josh is the man when it comes to that!
Old 07-10-2009, 09:06 AM   #1333
I'm rather fond of using a one way up front.
Is there going to be one available for my Photon ?
Perhaps a 416 one would fit but I would need a pulley for it.
Old 07-10-2009, 09:44 AM   #1334
Thirtybird's Avatar
Awww, and just three weeks ago, you couldn't even drive my car because of the front one-way
Racing a Kawada SV-10 in 2010
http://omgitsakawada.blogspot.com/
The VTA Photon! (Inactive - back to the Kawada!)
http://vtaphoton.blogspot.com/
Thirtybird is offline   Reply With Quote
Old 07-10-2009, 10:29 AM   #1335
It was a bit twitchy .
I try to make my cars easier to drive.
Maybe the Kawada was just too stiff in the rear.
SEO by vBSEO 3.5.0
