Old 07-07-2009, 06:06 PM   #1291
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by syndr0me View Post
TAM54078 (44mm steel CVD) appear to be an exact fit if you're looking for something just a little shorter in the rear. The TOP blades seem to fit fine, and the remaining hardware for the axle end is compatible. I'll test it on the track first thing next week.
good to know, I was gonna stick the blue ones in hehe
Apparently TOP have 43mm ones already?
http://www.topracing.net.au/shop/ind...&productId=454
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 07-07-2009, 06:11 PM   #1292
RC MARKET's Avatar
Originally Posted by LOW ET View Post
still no foam cars?
around 2-3 weeks
RC MARKET is offline   Reply With Quote
Old 07-07-2009, 06:30 PM   #1293
Send a message via AIM to goop
dont worry you guys arent the only ones waiting on the foam kits.
good things come to those who wait
Hurricane Motorsports
Team Trinity
TOP Racing - Gravity Rc - Contact tires - KO Propo - Competition Electronics
goop is offline   Reply With Quote
Old 07-07-2009, 06:34 PM   #1294
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
Originally Posted by mtveten View Post
I used 8, the spare ball is still in the bag. Rings sanded flat, I think the wear is coming from the soft balls. Carbide thrust & diff balls should should yield something that lasts a long time.
mark
Check your thrust bearing! Some kits have ad many as nine in the bag. Check it!
mrrcguy is offline   Reply With Quote
Old 07-07-2009, 06:35 PM   #1295
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
still no foam cars?
Foam is for pan cars.
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 07-07-2009, 07:00 PM   #1296
syndr0me's Avatar
Trader Rating: 32 (100%+)
It's 49313, 49314, 49315 you really want to avoid. The temptation is stroooong.
I believe TOP is planning to release a shorter bone, but doesn't have it available yet. I'm just looking for solutions to the CVD blade problem, and it seems the length of the rear CVD's is currently the prime suspect.
syndr0me is offline   Reply With Quote
Old 07-07-2009, 07:22 PM   #1297
CraigM's Avatar
Yep I've thrown 2 blades and ruined my outdrive in the process. Even with the blade sanded like we do on the 416 it still touches, this is with 2.5 deg of rear toe and 4 cone washers
EJ said the new ones are 44.5mm... which makes me wonder why they have a 43mm available. I'm getting a set of these this week so I'll sus it out then
Old 07-07-2009, 08:56 PM   #1298
I hope my car has the correct ones . Couldn't you just run a few more spacers behind the lower suspension pivots? Make the ass a bit wider ?
Old 07-07-2009, 09:25 PM   #1299
CraigM's Avatar
Yeah that would solve the problem, but the setup I'm working towards is actually .5mm narrower in the rear arms
Old 07-08-2009, 07:21 AM   #1300
Josh Cyrul's Avatar
The different lenght bones are a tuning option as the car will handle differently with different lenghts. Usually, shorter bones will increase responce from the end of the car the are put in and slightly reduce roll (universal will bind more/more angle from being shorter through suspension travel).
The car standard is actually pretty narrow in the rear. (I think 186-187mm). I'm suprised to hear you want to run it this narrow. I used a 1mm spacer in the front of the rear arm and a 3mm spacer in the rear of the rear arm... I also prefered to narrow the rear from the wheel hub (hex) on the outside instead of on the inside. This is why I've drawn and asked for (I think we are making) 4mm hexes for the car....
Destiny, Ko Propo, Hobby Wing, Ulti Racing Tires, Protoform, Xenon Racing, Pivothead, Vizon, TQ Wire & Hella Graphics
Josh Cyrul is offline   Reply With Quote
Old 07-08-2009, 09:30 AM   #1301
beaim's Avatar
Trader Rating: 8 (90%+)
Send a message via MSN to beaim
when will spool (in drive) available? rcmarket
beaim is offline   Reply With Quote
Old 07-08-2009, 11:52 AM   #1302
RC MARKET's Avatar
broke ?
have new ver. coming soon !
Old 07-08-2009, 11:53 AM   #1303
RC MARKET's Avatar
TOP Servo Saver
T.O.P. Racing "Photon" 1/10 EP Touring Car-top-ss-km01bk.jpg
Old 07-08-2009, 06:33 PM   #1304
CraigM's Avatar
Whoops I forgot the hexes are wider than what I'm used to... carry on
I'm running the same suspension spacers as you, can you explain how have your diff assembled so as not to get binding on the driveshaft blade?
Old 07-08-2009, 06:56 PM   #1305
Originally Posted by E.J. Evans View Post
it says to run a spacer (red) between the head of the screw and coned washers.
Does shimming the screw resolve the blade failure issue?
9.10938291(40)10−31
WooHoo is offline   Reply With Quote
