Old 07-06-2009, 09:23 PM   #1276
CraigM's Avatar
Trader Rating: 34 (100%+)
Nice track, especially the colour scheme (see below). I'll be interested to see setups from you guys, I too have found the car super responsive to roll centre changes and yep it's definitely a good thing
Here's some footage my mate took of my car getting around our track on Sunday. As you can see it's handling pretty nicely, but there's still a tonne of speed left to find in it
+ YouTube Video
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 07-06-2009, 09:51 PM   #1277
E.J. Evans's Avatar
Send a message via Yahoo to E.J. Evans
Default CVD Blade Issue
I've gotten a couple emails regarding people breaking the CVD blade. This is our own part and do not OEM them. The reason Josh never drew them up was because we used them on our last TC.
I think the reason they are breaking is because the diff screw is hitting it. In the instruction manual, it says to run a spacer (red) between the head of the screw and coned washers. If you run this spacer the CVD blade has a less of chance of hitting the screw.
If you run the rear width very narrow, this will also cause the CVD blade to hit the end of the screw.
With this spacer in place the diff can not be adjusted externally (through the hole in the outdrive), you have to use a scew driver from the side.
We are coming out with a 44.5mm aluminum rear universal. This should solve all the clearance problems. Art is testing a 44mm universal, we'll see what he reports back with.
T.O.P. Racing | APEX Hobbies | R1 | Solaris | NorCal Hobbies |
Solaris Racing Products (SRP) Solaris Spec Tires!
www.solarisrp.com | www.apexhobbies.com | www.topracingusa.com
E.J. Evans is offline   Reply With Quote
Old 07-06-2009, 09:58 PM   #1278
smoke81's Avatar
Send a message via AIM to smoke81 Send a message via Yahoo to smoke81
With the spacer and only using 4 cone washers i seem to beable to adjust from the outside.. Would maybe sanding down the front of the blade help with some clearance?? Assuming the reason they are coming off is they are hitting the screw, and not simply breaking it might help. I know i've lost two blades my self.
Dustin Layne
smoke81 is offline   Reply With Quote
Old 07-07-2009, 07:16 AM   #1279
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Default Spur gear choice
Just an FYI...I used a PRS spur gear and they fit great. I didn't have to ream the holes.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 07-07-2009, 10:46 AM   #1280
Team STPN's Avatar
Without going back, does anyone know the spring rates for the Photon
Team STPN is offline   Reply With Quote
Old 07-07-2009, 10:52 AM   #1281
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
They seem to be using a different system.
Diameter of wire, # of coils.
Not rated by pounds at all.
Also there seems to be different spring sets.
One for foam, Carpet and Ash fault.
And another for rubber Ash fault.
I hope those are the same ones I need for the carpet cause thats what I ordered.
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 07-07-2009, 12:43 PM   #1282
artwork's Avatar
Trader Rating: 59 (100%+)
rubber tire springs...
PS-TR15550 Gamma Spring 393gf/mm, 22.0lb/in (2 pcs)
PS-TR15575 Gamma Spring 367gf/mm, 20.5lb/in (2 pcs)
PS-TR15600 Gamma Spring 344gf/mm, 19.2lb/in (2 pcs) - Kit
PS-TR15625 Gamma Spring 324gf/mm, 18.1lb/in (2 pcs)
PS-TR15650 Gamma Spring 306gf/mm, 17.1lb/in (2 pcs) - Kit
PS-TR15675 Gamma Spring 289gf/mm, 16.2lb/in (2 pcs)
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 07-07-2009, 01:07 PM   #1283
Send a message via AIM to HenBeav
nevermind
[URL]http://www.fastlanehobby.com[/URL]
Support your local Lowe's, Walmart and Layne Machine Works INC.
HenBeav is offline   Reply With Quote
Old 07-07-2009, 01:31 PM   #1284
Team STPN's Avatar
Awesome thanks....
Old 07-07-2009, 01:31 PM   #1285
ty.
Old 07-07-2009, 02:34 PM   #1286
mtveten's Avatar
Trader Rating: 27 (100%+)
So who's thrust bearing fits, I just check my stock one after a day on track and its not holding up well.
Mark
mtveten is offline   Reply With Quote
Old 07-07-2009, 02:39 PM   #1287
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
How many balls did you fit to it? Thrust race that is***
Also did you sand the diff and thrust rings down?
Luke
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
Old 07-07-2009, 03:33 PM   #1288
mtveten's Avatar
Luke
I used 8, the spare ball is still in the bag. Rings sanded flat, I think the wear is coming from the soft balls. Carbide thrust & diff balls should should yield something that lasts a long time.
mark
Old 07-07-2009, 04:00 PM   #1289
syndr0me's Avatar
Trader Rating: 32 (100%+)
TAM54078 (44mm steel CVD) appear to be an exact fit if you're looking for something just a little shorter in the rear. The TOP blades seem to fit fine, and the remaining hardware for the axle end is compatible. I'll test it on the track first thing next week.
syndr0me is offline   Reply With Quote
Old 07-07-2009, 04:02 PM   #1290
LOW ET's Avatar
Trader Rating: 95 (100%+)
still no foam cars?
LOW ET is offline   Reply With Quote
