Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 07-03-2009, 09:41 AM   #1216
Josh Cyrul's Avatar
John - Those ackerman #'s are the difference in relation from inside/outside wheel travel from 0 degrees. Example - Going back to the chart 21mm crank (shortest setting) with a 12mm insert gives you an inside wheel angle of 25 degrees with the outside turning 17.65 = 7.35 degrees of ackerman at 25 degrees of inside wheel travel.
I haven't looked back at the servo arm to calculate the amount of servo travel/angle. I have general #'s that I've liked to stay within for the servo arm, bell crank, steering block reduction.....
CEFX, T.O.P. Racing, Thunder Power, Shepherd Micro Racing, Novarossi, Jaco, Hacker, Ko Propo, Kimbrough, Faskolor, MuchMore & Reilly Paint
www.cefx.net - www.topracingusa.com - www.thunderpowerrc.com - www.team-shepherd.com - www.kopropo.com/america - www.novarossi.com
Josh Cyrul is offline   Reply With Quote
Old 07-03-2009, 10:03 AM   #1217
Suspended
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Excellent ... Ty !
10R5 (WGT), A-10, DF-03 (Rally), F103-15th, M04R, SC10, SC8e, TOP Photon (13.5R),
TM E4 C1 (Vintage T/A), TM E4 DELE (13.5R), TRF416WE (GT1)
Futaba FAAST2.4 3Pk, LRP, Much More, Orion, Tekin, Thunder Power.
John St.Amant is offline   Reply With Quote
Old 07-03-2009, 11:33 AM   #1218
nocif13's Avatar
Send a message via MSN to nocif13
photon review
http://top-photon.blogspot.com/
teamspec/petitrc.com/TEAM WAVE/T.O.P racing/CBRacing.fr/rcmanufactory/Alien POWER/Team Terribles
nocif13 is offline   Reply With Quote
Old 07-03-2009, 12:00 PM   #1219
smoke81's Avatar
Send a message via AIM to smoke81 Send a message via Yahoo to smoke81
Hey Josh if I put a 2mm shim on my sway bars it seems the link will hit the cvds.. It takes a bit of suspension travel, but not out of the realm of possibilities . Just curious if you could give me a measurement from the bottom the ball cup to the top of the ball? Thanks..
Just thought i'd add.. 3mm and it seems to have all the room in the world in there..
Dustin Layne
www.laynemachine.com www.fastlanehobbies.com
smoke81 is offline   Reply With Quote
Old 07-03-2009, 02:11 PM   #1220
Goingfast's Avatar
Trader Rating: 23 (100%+)
Did anybody get any Photon Decals?
Everybody is ignorant, only on different subjects.
SpeedMerchant REV 4.5 LRP Q2 JR3550
T.O.P PHOTON ,XRAY T2 008,TAMIYA 416WE
TEKIN. High Velocity Racing
Goingfast is offline   Reply With Quote
Old 07-03-2009, 02:18 PM   #1221
RC MARKET's Avatar
Decal was arrived 1 week for was buy this car customer !
RC MARKET is offline   Reply With Quote
Old 07-03-2009, 04:42 PM   #1222
adamge's Avatar
hehe, I think that's your best post yet, rcmarket !!
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 07-03-2009, 07:56 PM   #1223
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Yeah I'm painting a body for my car tonight and was thinking what's with not including some decals...
Steve Madlock
Team Epic/Trinity
The Track @ Harbor Hobbies - www.harbor-hobby.net
PitNamedGordie is offline   Reply With Quote
Old 07-03-2009, 08:19 PM   #1224
beaim's Avatar
Trader Rating: 8 (90%+)
Send a message via MSN to beaim
hey guys,
droop measurement is to use the Droop Gauge,if follow manual, set it at F & R 5.5 . correct me if i am wrong.thanks
how about front 5.5 rear 1.
or front 1 rear 5.5. provide me some teory, will test later.
beaim is offline   Reply With Quote
Old 07-03-2009, 11:52 PM   #1225
CraigM's Avatar
Radial Ackerman:
Pos. #1 St. Block Inside Wheel degree vs. Outside Wheel Degree
21mm Length 5degree 10degree 15degree 20degree 25degree
9mm Insert 4.72 8.93 12.62 15.81 18.48
10mm Insert 4.71 8.87 12.51 15.62 18.22
11mm Insert 4.69 8.81 12.39 15.43 17.94
12mm Insert 4.67 8.75 12.26 15.22 17.65
22.5mm Length
9mm Insert 4.76 9.07 12.93 16.32 19.21
10mm Insert 4.75 9.03 12.83 16.16 18.98
11mm Insert 4.74 8.98 12.73 15.99 18.74
12mm Insert 4.72 8.92 12.62 15.81 18.49
24mm Length
9mm Insert 4.8 9.21 13.21 16.78 19.89
10mm Insert 4.79 9.17 13.13 16.64 19.69
11mm Insert 4.78 9.13 13.04 16.5 19.48
12mm Insert 4.77 9.08 12.95 16.35 19.26
This is generated using a set wheel base - adjusting wheel base/hinge pin sweep can adjust these #'s. Also, this is generated using 0 toe in/out. This is to generate different ackerman curves.
Generally, lower initial ackerman (closer # values) generate more initial steering and can make the car loose in the center of the corner/exit. Be warned though that at times it can overheat the tires and cause a mid/late race understeer.
Higher initial ackerman makes the car easier to drive, and more balanced through the run. Sometimes though, if you use too much ackerman you will just have slow lap times and a lazy/understeering car. So far, I've prefered the shorter bell crank (21mm) with 9-10 for the ackerman insert as it gives good initial steering and good low speed steering without over heating the front tires so much. Also, this combination is quite close to the ackerman data generated from the 416 I was able to guess some dimensions off of....
Sorry Josh, one more time for the cheap seats... when you say closer values, do you mean the set of 4 values are close i.e. you're preferred setting of 21 and insert 9 will provide more initial steering (and heat risk) to EJ's 22.5 and insert 10?
thanks
Next question, has anyone used the outside hole on the rear hub giving the longest setting for the rear camber link?
www.topracing.net.au | www.venom-group.com | www.smaracing.org
T.O.P. PHOTON RESOURCE SITE
www.tchub.info
CraigM is offline   Reply With Quote
Old 07-04-2009, 01:55 AM   #1226
vr01's Avatar
Craig,
Haven't tried that yet...
However, made the following changes to the kit setup and had the car running very nicely at the Hill last night despite the low grip and cold temps. New layout as well.
Stood up rear shocks one hole to position 2 at the top.
Inside front link from 2.5mm to 1mm
Inside rear link from 1.5mm to 0.5mm
vr01 is offline   Reply With Quote
Old 07-04-2009, 06:23 AM   #1227
bender's Avatar
Chris, what were you trying to achieve with the above set-up changes?
I debuted my car tonight in similar conditions (very low grip, very cold temps) and to be honest the car was absolute rubbish I was lapping miles away from a competative pace.
The car had a lot of off-power push, especially on the slow turns, but as soon as you got to the apex the car would then spin out. It was also very loose under throttle out of all low speed corners. Overall a very frustrating night and I'm not sure where to begin making changes
Jason W
Chargers Interclub rep '09
FIR#2 - "You can't buy this much talent"
Kyosho Ultima RB5 - Durango Dex410 - Top Photon
bender is offline   Reply With Quote
Old 07-04-2009, 08:11 AM   #1228
RC MARKET's Avatar
& our first lot all is had soft & Hard Spool Outdrive !
Old 07-04-2009, 04:16 PM   #1229
mikky32's Avatar
I don't have the Photon myself but a club member has it now and the car drives grate.
When I see te car go, its incredible stable and it roles great true the corner.
Josh you did a grate job. All the TOP critics are quit now and are only looking and don't dare to say any ting. Others are looking and making compliments about the car.
It's just fun to see them watch and don't dare to say any thing because they now the car is good, very good!!!
I think they want one to but don't dare to buy one because they were first talking like TOP was a cheap car and not a real car.
Thanks to you Josh I can laugh at them and I can't wait till I can buy my car.
Must wait till I get a letter from the tax that I may keep my money!!
When that's ok, I will buy a Photon.
Can't wait.
Epic team driver
TOP racing Photon
Tekin RS pro
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 07-04-2009, 09:21 PM   #1230
mtveten's Avatar
What online dealers are stocking parts & such for the new car?
Mark
mtveten is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (3 members and 1 guests)
HenBeav , stiltskin
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
