Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 07-01-2009, 01:20 PM   #1186
Goingfast's Avatar
Trader Rating: 23 (100%+)
Originally Posted by E.J. Evans View Post
Hello Everyone,
The new drive cups are in! They are made of a harder material that will wear better. When you get these, please throw your old ones away.
One bag (4 pcs) is complimentary to everyone that bought a kit. We'll be sending them out to all our customers.
You can also send us an email topracingusa@yahoo.com and put in the subject heading "Drive Cups V2". We will need proof of purchase, USA customers only.
Hi EJ
I sent in my receipt please check your email...Thanks
Everybody is ignorant, only on different subjects.
SpeedMerchant REV 4.5 LRP Q2 JR3550
T.O.P PHOTON ,XRAY T2 008,TAMIYA 416WE
TEKIN. High Velocity Racing
Goingfast is offline   Reply With Quote
Old 07-01-2009, 01:29 PM   #1187
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
Originally Posted by The Teacher View Post
EJ, my kit came with 2 spools. One said new on the bag, what is different with this spool? Is this made of the harder material or did everyone get this and it's still the old spool/outdrives?
Originally Posted by wyd View Post
Hmmm looks like someone is working on their kit.
Wow... You got one Teach.... Ask Hess about the car...
This is DICK!!! And you're NOT!
RC Tech member #11 ROAR Member 98196
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 07-01-2009, 07:25 PM   #1188
E.J. Evans's Avatar
Default Reedy Setup
Couple guys were asking for my Reedy setup, so here it is again. Made it a PDF this time and brought down the file size.
I ran mod with this setup. The only thing I changed was the front springs. I went to a 324gf.
T.O.P. Racing | Thunder Power | Spintec | Spektrum | OD 12 Racing | Protoform | NorCal Hobbies | Muchmore Racing | CEFX | Solaris Racing Products (SRP) Solaris Spec Tires! www.solarisrp.com
topracingusa@yahoo.com | solarisrp@yahoo.com | www.topracingusa.com
E.J. Evans is offline   Reply With Quote
Old 07-01-2009, 07:28 PM   #1189
THeGame's Avatar
Send a message via AIM to THeGame
Rick... Teach better watch out for you now... I would hate to see you put it one him with it.....
Kyosho USA, Top USA, CEFX, Team OHP, Matrix, Glitter Lidz Paintz, Team HR
"Pull IT"
I was told it needs to be on the track to Pull IT..
THeGame is offline   Reply With Quote
Old 07-01-2009, 07:30 PM   #1190
THeGame's Avatar
Ej are you coming out for the Nats in Frederick?
"Pull IT"
Old 07-01-2009, 07:33 PM   #1191
Regional Moderator
mrrcguy's Avatar
Any chance we can get a detailed explanation of how changing the radial ackerman adjustment inserts will affect handling? A few of my racers have been asking me about this and having not tested this I dont have any of the answers.
WWW.MIDAMERICARCRACEWAY.COM
www.tchub.info
mrrcguy is offline   Reply With Quote
Old 07-01-2009, 09:13 PM   #1192
Suspended
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
So I could have gotten my kit already and had an extra spool//Dammit !
I want parts to make a diff fior the front and eventually a one way . Whats the gerth of the spool between the bearings? Maybe a Tamiya one will fit > No ?!
10R5 (WGT), A-10, DF-03 (Rally), F103-15th, M04R, SC10, SC8e, TOP Photon (13.5R),
TM E4 C1 (Vintage T/A), TM E4 DELE (13.5R), TRF416WE (GT1)
Futaba FAAST2.4 3Pk, LRP, Much More, Orion, Tekin, Thunder Power.
John St.Amant is offline   Reply With Quote
Old 07-01-2009, 09:58 PM   #1193
JimmyMac's Avatar
Yokomo BD5 oneway with BD5 pulley fits. I already tested my BD5 oneway in someones Photon. Just like you can use BD belts on the car too.
Mike J. Mc. (Roar No. 3-95872)
Team eXpress Motorsports : HobbyHaven : ORCA
Yokomo BD5
Tamiya TRF415 MRE : Tamiya TA05 : Tamiya Evo IV JM
JimmyMac is offline   Reply With Quote
Old 07-01-2009, 10:09 PM   #1194
RC MARKET's Avatar
outdrives cup harder !
RC MARKET is offline   Reply With Quote
Old 07-02-2009, 01:28 AM   #1195
syndr0me's Avatar
So, a suggestion...
How about a longer servo mount? Many of us run the short servos, and longer mounts (much longer than the longest option in the kit) could give us the ability to push the shorter servo closer to the edge of the chassis. This would enable us to run the servo in the forward holes, giving us much-needed space for our electronics, and won't require you to take a live beaver to the corner of your servo to prevent the arm from rubbing. It also seems to still maintain decent alignment between the servo horn and arm on the steering assembly.
Also, in aluminum would be great.
corrc.org | 416WE | TA05 IFS-R | Privateer
syndr0me is offline   Reply With Quote
Old 07-02-2009, 05:51 AM   #1196
Josh Cyrul's Avatar
syndr0me - They make aluminum spacers don't they??...lol..
Radial Ackerman:
Pos. #1 St. Block Inside Wheel degree vs. Outside Wheel Degree
21mm Length 5degree 10degree 15degree 20degree 25degree
9mm Insert 4.72 8.93 12.62 15.81 18.48
10mm Insert 4.71 8.87 12.51 15.62 18.22
11mm Insert 4.69 8.81 12.39 15.43 17.94
12mm Insert 4.67 8.75 12.26 15.22 17.65
22.5mm Length
9mm Insert 4.76 9.07 12.93 16.32 19.21
10mm Insert 4.75 9.03 12.83 16.16 18.98
11mm Insert 4.74 8.98 12.73 15.99 18.74
12mm Insert 4.72 8.92 12.62 15.81 18.49
24mm Length
9mm Insert 4.8 9.21 13.21 16.78 19.89
10mm Insert 4.79 9.17 13.13 16.64 19.69
11mm Insert 4.78 9.13 13.04 16.5 19.48
12mm Insert 4.77 9.08 12.95 16.35 19.26
This is generated using a set wheel base - adjusting wheel base/hinge pin sweep can adjust these #'s. Also, this is generated using 0 toe in/out. This is to generate different ackerman curves.
Generally, lower initial ackerman (closer # values) generate more initial steering and can make the car loose in the center of the corner/exit. Be warned though that at times it can overheat the tires and cause a mid/late race understeer.
Higher initial ackerman makes the car easier to drive, and more balanced through the run. Sometimes though, if you use too much ackerman you will just have slow lap times and a lazy/understeering car. So far, I've prefered the shorter bell crank (21mm) with 9-10 for the ackerman insert as it gives good initial steering and good low speed steering without over heating the front tires so much. Also, this combination is quite close to the ackerman data generated from the 416 I was able to guess some dimensions off of....
I can't really make this chart look right on here... Sorry guys...
CEFX, T.O.P. Racing, Thunder Power, Shepherd Micro Racing, Novarossi, Jaco, Hacker, Ko Propo, Kimbrough, Faskolor, MuchMore & Reilly Paint
www.cefx.net - www.topracingusa.com - www.thunderpowerrc.com - www.team-shepherd.com - www.kopropo.com/america - www.novarossi.com
Josh Cyrul is offline   Reply With Quote
Old 07-02-2009, 07:43 AM   #1197
The Teacher's Avatar
Josh Cyrul, so basically what you're saying is...download your setup sheet and use the setting on it.... GOT IT!
The Teacher is offline   Reply With Quote
Old 07-02-2009, 08:09 AM   #1198
syndr0me's Avatar
Thanks Josh.
Old 07-02-2009, 08:44 AM   #1199
Suspended
Doesn't the kit come with Josh's And E.J.'s set up sheets ?
Old 07-02-2009, 11:45 AM   #1200
E.J. Evans's Avatar
Radial Ackerman:
22.5mm Length
24mm Length
Great post Josh!
I like running the 10mm insert in the middle position (22.5) with rubber tires on asphalt. Josh did a great job with this bell crank. I never knew that playing around with this made such a difference with how the car feels.
Currently Active Users Viewing This Thread: 4 (3 members and 1 guests)
skypilot , spoket
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
