Old 06-30-2009, 07:45 AM   #1141
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Originally Posted by snoopyrc View Post
A couple of questions for you guys. First what is the parts support like for this car. Locally I have never seen any TOP products at my LHS. As much as I love the design and like what Josh has done to help develop it, I rest uncertain that I would be able to actually race the car. I am just a club racer and as such I am more aquainted with the walls at my local track. I at least need to know that I can get suspension arm and CVD components.
I am currently running an S400 and Im really happy with the car. However parts support has been lacking for it and I am considering moving to something else. I am thinking of sticking with VTA or RCGT. Part of me thinks it would be overkill to get a kit like the Photon for that purpose, but the other part of me just likes nice gear. Any thoughts???
All you really need to do is to get your local hobby shop to support the kit and parts will be available to you . If not I think RC Market or others can get your fix right on line. But I recommend the hobby shops. Parts will be available soon if not already. Best thought is just order two kits.
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 06-30-2009, 07:46 AM   #1142
Originally Posted by LOW ET View Post
new to rubber on carpet, do you guys use tire warmers when running on carpet?
Some times yes.
I do it only when i'm in the A final and as I have tested with it.
So as I used it in the qwalifications. As that made the car handle good, than I use it in the finals to.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 06-30-2009, 07:50 AM   #1143
Originally Posted by mikky32 View Post
Some times yes.
I like my tires about 95 degrees .
Old 06-30-2009, 10:27 AM   #1144
Send a message via AIM to ERTRACHTER
The high bite tracks we race on here i don't feel tire warmers are needed
ASSOCIATED 12r5.1,REEDY MOTOR AND BATTERY, LRP SPEEDO,KIMBROUGH PRODUCTS,BIG DOG RACING,BELMONT R/C SPEEDSHOP, DENNIS LYMAN RACING, TEAM TOSO, TEAM FACTORY BITTER, SCHUUR SOLUTIONS, SIMMONS RACING, TEAM BOOZCRUZ
ERTRACHTER is offline   Reply With Quote
Old 06-30-2009, 10:56 AM   #1145
Probably not necessary outside. But indoors on the first few laps I believe it helps.
Old 06-30-2009, 10:58 AM   #1146
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
I have never seen one A main driver at any big race on carpet run tire warmers in rubber including mod rubber drivers at the IIC, also I always use warmers outside to bake in the sauce.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 06-30-2009, 11:09 AM   #1147
E.J. Evans's Avatar
Send a message via Yahoo to E.J. Evans
Default Carpet Nats 09
Sorry for the delay. Here is my carpet nats setup. I actually have two versions but I think this one is the better of the two. I'll post the other one in a little bit.
This setup will also work for high grip asphalt, or if you traction rolling hint hint.
You will notice there is not much difference. The main difference is the hing pins are in the medium low position. I had it at the high position but when the traction came up the car started flipping. When I dropped them down the problem went away.
T.O.P. Racing | APEX Hobbies | R1 | Solaris | NorCal Hobbies |
Solaris Racing Products (SRP) Solaris Spec Tires!
www.solarisrp.com | www.apexhobbies.com | www.topracingusa.com
E.J. Evans is offline   Reply With Quote
Old 06-30-2009, 11:58 AM   #1148
Send a message via AIM to HenBeav
yeah it would take some planning and someone else setting your car down for them to not cool off during the annoucements
[URL]http://www.fastlanehobby.com[/URL]
Support your local Lowe's, Walmart and Layne Machine Works INC.
HenBeav is offline   Reply With Quote
Old 06-30-2009, 12:30 PM   #1149
smoke81's Avatar
Send a message via AIM to smoke81 Send a message via Yahoo to smoke81
Thanks EJ..
Dustin Layne
smoke81 is offline   Reply With Quote
Old 06-30-2009, 12:37 PM   #1150
Ive only sen or heard about tire warmers on carpet at the tcs in japan where they don't allow any sauce otherwise i dont think you would need them and all i race on carpet is rubber tire and i think ive done allright in the past!
Old 06-30-2009, 01:01 PM   #1151
All I can say is try it .. and yes it would have to be planned and you would need a pit buddy at the race.
Old 06-30-2009, 01:24 PM   #1152
RC MARKET's Avatar
turnbuckle
T.O.P. Racing "Photon" 1/10 EP Touring Car-top-po-pu005rd.jpg
RC MARKET is offline   Reply With Quote
Old 06-30-2009, 01:34 PM   #1153
Is the Car available to purchase now? If So where?
Im not seeing at TOPUSA?
Sam
Sam DiLeo is offline   Reply With Quote
Old 06-30-2009, 01:44 PM   #1154
bigkoitat's Avatar
Trader Rating: 6 (88%+)
A-Mainhobbies have them in stock
JAWS
TRF-416WE & 416-X / DHW / TEAMRCR.NET
bigkoitat is offline   Reply With Quote
Old 06-30-2009, 01:49 PM   #1155
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
Originally Posted by RC MARKET View Post
turnbuckle
now that's worth 0.3 a lap minimum just for being red!!
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
