Old 06-29-2009, 11:00 PM   #1126
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by adamge View Post
Craig, can you publish the build tips doc in pdf format? "PDF Creator" is a free pdf printer that works awesome.
Also, no love for rctech? How about a link back to this thread, home of the Photon.
Ah good thinking! This is why i'm not left in charge of things. Love added, and build tips PDF'd. A toe chart has also been added (thanks DZ)
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 06-29-2009, 11:37 PM   #1127
syndr0me's Avatar
Trader Rating: 32 (100%+)
Well, by the end of the night, I bested my fastest lap ever, and was pretty easily clicking off quick laps. I'm having a heck of a time with mid-corner traction roll, though. Gonna do another full day of testing tomorrow and try some things out.
From the kit setup, I went to a medium sway up front, camber link in the middle hole F/R, middle ackerman position, 2.5 rear toe, and put a 2.5mm spacer under the rear inner links. I'm running the medium roll center links with the dot up, so I think that's medium high? I tried medium low all around and lost .3.
I've got a nice thick bumper on the car (P-Dub 415), and am happy to report that even with several good whacks on the front, nothing broke. I didn't hit anything with the side of the car, but had some pretty spectacular traction rolls. These bent both of the screws in the rear holding the hinge pin mounts to the bulkhead. I'm trying longer screws in there now to see if they're better. The existing ones were pretty short.
Any suggestions on tricks to reduce traction rolling?
syndr0me is offline   Reply With Quote
Old 06-29-2009, 11:40 PM   #1128
syndr0me's Avatar
Oh, one other thing. I've got some wobble in my diff pulley. Like, I can grab it and wobble it, not like it's warped. This was causing it to rub slightly on the cutout for the pulley in the chassis. The other Photon at the track also had some wobble, but didn't have the rub.
Old 06-29-2009, 11:51 PM   #1129
CraigM's Avatar
I’ve got a slight wobble too & I think it’s the diff rings - when I sanded mine I noticed that they weren’t completely flat
To stop you traction rolling you probably want to raise the RCs and a get a bit more camber change going
Old 06-30-2009, 02:48 AM   #1130
vr01's Avatar
If you have the diff equally spaced in the cams, move the spacer from the long side to the short side should remove the rub.
There was some talk a page or so back about either pulley or dust covers not quite equal. So if you rebuild the diff with the pulley, etc, flipped over, you might get some more room, preventing the pulley catching.
vr01 is offline   Reply With Quote
Old 06-30-2009, 03:03 AM   #1131
nocif13's Avatar
Send a message via MSN to nocif13
Originally Posted by SRW141 View Post
Why are you using Schumacher steering rods/ assembly for this car? I would think it would through off how it was designed.
Because IT IS ALMOST IDENTICAL AND MUCH STRONGER THAN THE ORIGINAL
teamspec/petitrc.com/TEAM WAVE/T.O.P racing/CBRacing.fr/rcmanufactory/Alien POWER/Team Terribles
nocif13 is offline   Reply With Quote
Old 06-30-2009, 04:29 AM   #1132
LOW ET's Avatar
Trader Rating: 91 (100%+)
i may have missed it but this is on carpet, correct?
LOW ET is online now   Reply With Quote
Old 06-30-2009, 05:14 AM   #1133
TRF415boy's Avatar
Gee I never thought I'd ever read that, schumacher parts stronger than something other than cheese ?
TRF415boy is offline   Reply With Quote
Old 06-30-2009, 05:18 AM   #1134
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
Originally Posted by CraigM View Post
Hi Guys,
I've knocked up a quick website to store all the Photon setups, build tips, resources, and anything else useful I come across.
http://www.tchub.info/
p.s. the URL is new so it may not have propogated to the US yet
It works just fine here in the us of a...
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 06-30-2009, 05:23 AM   #1135
nocif13's Avatar
I compare the Schum AND PHOTON! NUANCE
AND THE SINGLE parts MI4 rises without changing this
Old 06-30-2009, 06:02 AM   #1136
TRF415boy's Avatar
Yeah, well that makes that part of the photon similar to cheese...
Old 06-30-2009, 06:23 AM   #1137
Rod M's Avatar
I too had a good first meet with the car down under. TQ, fastest lap, and 2nd overall (could have been first but was taken out by a backmarker while leading A3 ). Most guys running the car for the first time had the same push I did with the base setup, but by the time the finals came around everyone running them looked pretty happy and I think we walked away with 3-4 podiums. We also learned the hard way to use a servo saver with 2 of us running just the arm broke steering bell cranks.
it was a very good meet for the 5 photons that were there,
Super stock 10.5
1, Christian (xray 009)
2, Craig Mcphee (Photon) TQ
3, Damien Zarb (Photon)
Stock 17.5
1, Darren L (Cyclone) TQ
2, Rod M (Photon)
3, Ray Z (Photon)
TOPRACING.NET.AU Australian Importer of:
T.O.P. Tokyo Hobbies Optional Parts,
Team Trinity , BL Motors and Tyre compound
Team Tekin , ESC's, motors,
Elangears, Chargers,
Rod M is offline   Reply With Quote
Old 06-30-2009, 07:38 AM   #1138
snoopyrc's Avatar
Super stock 10.5
Stock 17.5
2, Rod M (Photon)
3, Ray Z (Photon)
Thats awesome that you even have that many running at your local track. I have never even seen one in person. Although I did hang around Josh's pit at the snowbirds for a few minutes. What he had there was cool.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 06-30-2009, 07:52 AM   #1139
syndr0me's Avatar
Yep, Ozite with quite a bit of grip. (pics)
Old 06-30-2009, 08:31 AM   #1140
LOW ET's Avatar
new to rubber on carpet, do you guys use tire warmers when running on carpet?
SEO by vBSEO 3.5.0
