Old 06-26-2009, 12:44 PM   #1006
syndr0me's Avatar
Trader Rating: 32 (100%+)
Originally Posted by HenBeav View Post
(((( is a hard spring
((() is a medium spring
()() is a soft spring
()()()()()() is really soft
all just depends on how much slip and play you want in the adjustment
Whoaaaaa... time to create v2 of the setup sheet!
syndr0me is offline   Reply With Quote
Old 06-26-2009, 01:25 PM   #1007
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by E.J. Evans View Post
5.02 with a Hurricane Trinity Duo (10 degrees of timing) and 7 or 8 on the speedo (LRP SPX) I'll have to go check. I also ran two fans on the motor.
Wow 5.02. You must have a rocket ship! Or was that what most guys ran? I thought it was in the 5.6 range
Originally Posted by Rod M View Post
all my electrics are in and did not need to double stack anything,
Man that esc is TINY! is that the new keyonce (sp)?
Originally Posted by Nova F1 Racer View Post
If you are running mod then (((((( to lock it down and not slip it/strip it...
Stock ()()() because there won't be high tourge...
lol I always wondered that. I always ran them ()()() in my wheeler for mod. I never knew you could change the direction like that and make a difference.
Thats cool! Thanks for the info
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 06-26-2009, 01:26 PM   #1008
BagofSkill's Avatar
Actually, with respect, that's not right.
((() would be a progressive spring, soft then hard.
From soft to hard spring stiffness we would have:
()()() Soft
(((((( Hard
There are other combinations to give progressive springs but this probably isn't necessary in a diff as there is no displacement of the spring during working.
HTH, Chris
BagofSkill is offline   Reply With Quote
Old 06-26-2009, 01:35 PM   #1009
RC MARKET's Avatar
good note !
RC MARKET is offline   Reply With Quote
Old 06-26-2009, 02:00 PM   #1010
Send a message via AIM to HenBeav
()()() Soft
(((((( Hard
HTH, Chris
but i read it on the internet that means it has to be right??
yeah never really thought of the progressive part, i've used the ((() with rubber tires before and it seemed to help give more initial slip, never really thought about why though, i slept through most of the classes that had to do with moving things and springs and such...
[URL]http://www.fastlanehobby.com[/URL]
Support your local Lowe's, Walmart and Layne Machine Works INC.
HenBeav is offline   Reply With Quote
Old 06-26-2009, 02:33 PM   #1011
Has anyone tried the Solaris tyres also from TOP racing?
Southpaw707 is offline   Reply With Quote
Old 06-26-2009, 03:06 PM   #1012
Josh Cyrul's Avatar
The bevel washers were used for a few reasons. The main of which was space. I wanted to keep the thrust assembly sitting against the differential outdrive so it was packaged close enough to the pulley for the hole/slot in the diff screw to alighn for external adjustment. Also, springs never sit perfectly flat so I did not want the thrust washers to be mis-alighned against the spring face causing any sort of binding from the diff screw dragging on the ID of the spring or the thrust washers sitting crooked and dragging on the inside of the differential outdrive. Also, it was for the space in the short half. As it is now, it's already a bit too close for my comfort if you want to run a narrow rear end with the "C" blade on the universal touching on the screw/nut of the differential. With a spring, there is no way it fits but with the spring washers we have a level of spring tension adjustment with the possibility of using a much smaller package.
Sanding the rings... Some do, some don't... I'm too lazy but my diff works great.
One piece thrust... Some do (EJ), some don't (myself). I like the standard thrust and I'm sure EJ can tell you I kicked his butt in the diff war at the Reedy Race....lol... With the box stock diff!!!
The spur gear assembly locks in pretty solid so you really don't have to over tighten the screws - Remember - there is NO SIDE LOAD on this part that would require a strong assembly to keep them together. We could practically use a "snap" fit assembly that would hold it together and it would work unless you changed spurs a lot from stripping them.
Destiny, Ko Propo, Hobby Wing, Ulti Racing Tires, Protoform, Xenon Racing, Pivothead, Vizon, TQ Wire & Hella Graphics
Josh Cyrul is offline   Reply With Quote
Old 06-26-2009, 03:15 PM   #1013
Josh Cyrul's Avatar
I think someone posted something about the top deck screws - I agree that they are a little soft so I think they are trying to find a better supplier for these. The reason for them was the room around the motor/spur area and still having enough material for strengh with using the double screw per mount to help with tweaking. Really, you don't have to crank on them to keep the car from tweaking though - Remember, there is 4 screws in the back and 4 in the front with a center steering post screw... It has no where to go.
Spur gears - Of course you can run as small as the pulleys...lol.. How big depends. If you use the optional "wings" that connect through the center then a 116 is the maximum. If you take this off I think you can run a 120 (don't quote me as I'm not 100%) and possibly 124 if you slightly bevel the slot under the spur in the chassis. The possible pinion size with this I am not sure but I only recommend this for if you use the car for foam tires to move the motor forward. In rubber - center to back on the motor screw slots will provide the best performance.
Yes, I am in Lostallo Switzerland right now for the 1/8 Pre-WC but I saw so many questions on here I wanted to post what I could to help everyone out with the car.... There's a lot on it that is different so I want everyone to know how it works and why I did what I did.
Old 06-26-2009, 03:34 PM   #1014
JamesReilly's Avatar
Trader Rating: 56 (100%+)
That's why I have a torque wrench for all the screws now ...I know it's sick to have a screwdriver torque wrench but what the heck, it's fun! Good Luck, you evil genius LOL!!
Tekno RC, Discount RC Store, REDS Racing USA,Reilly Paint (reillypaint@gmail.com)
"I'm not normal, just more normal then Finnish guys" - Ilias
JamesReilly is offline   Reply With Quote
Old 06-26-2009, 05:13 PM   #1015
Rod M's Avatar
yea the new Keyence Tachyon,
Size: W31mm D30mm H19mm
Weight: 35g
FET Qty: 36pcs
On Resistance: 0.24mΩ
Applicable Motor: unlimited
I started a thread here but there is still not much discussion, I must of been one of the first outside of Japan to use one? :
NEW Keyence Tachyon Brushless ESC
I have a set and will try them this weekend,
TOPRACING.NET.AU Australian Importer of:
T.O.P. Tokyo Hobbies Optional Parts,
Team Trinity , BL Motors and Tyre compound
Team Tekin , ESC's, motors,
Elangears, Chargers,
Rod M is offline   Reply With Quote
Old 06-26-2009, 06:57 PM   #1016
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Thanks for filling us in Captain.
That torque wrench screwdriver is pretty trick James!
I just might have to get one of those. Where was the discounted one you suggested ? All I can remember is the Snap-On one was $200!
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 06-26-2009, 08:03 PM   #1017
syndr0me's Avatar
There's something sketchy going on with what the manual says about hingpin/toe spacers, and what comes in the kit. Basically, the parts it comes with match the kit setup, not the manual.
Old 06-26-2009, 08:15 PM   #1018
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Done. Tomorrow for the virgin ride.
All I need is a body
T.O.P. Racing "Photon" 1/10 EP Touring Car-dsc02019.jpg
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 06-26-2009, 09:03 PM   #1019
Rod M's Avatar
I believe the main guts of the manual was completed prior to the kit setup being finalised, and they did not have time to go back and ammend the manual,
Old 06-27-2009, 12:35 AM   #1020
vr01's Avatar
Keep an eye on the screws for the spur gear shaft. I have put some threadlock on mine because one of them came loose under acceleration / braking (10.5) causing the spur gear to be trashed.
Otherwise - all good. Car was reasonable with kit set up and won't need too many changes to get it up to the speed of my Scythe.
vr01 is offline   Reply With Quote
