Old 06-26-2009, 06:40 AM   #991
Kwikvdub's Avatar
Trader Rating: 89 (100%+)
Send a message via AIM to Kwikvdub
That's a really nce looking car........ Very clean install.......... Bravo!!
Alex Valdes
TQRacing / 360 v2 RC Raceway
Kwikvdub is offline   Reply With Quote
Old 06-26-2009, 08:22 AM   #992
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
I saw a post somewhere that mention someones lack of enthusiasm over the way the center pulleys mount to the spur gear. I supposed there was concern over the strength of the plastic threads holding up.
So, I though I would mention the note about reaming out thee mounting holes in the spur gear. This "note" in the manual would be easy to miss of you are not paying attention. I actually missed it myself on the first build.
Anyway my point is make sure you ream the spur gear. When properly done this makes the assembly feel quite solid which will likely eliminate any worries over the strength of the threads. Also keep in mind that there really should be no significant amount of lateral force on this assembly which eliminates any need to put any torque on these screws.
mrrcguy is offline   Reply With Quote
Old 06-26-2009, 08:37 AM   #993
Paul Ohlsen's Avatar
Send a message via Yahoo to Paul Ohlsen
EJ you have PM
Viper R/C Solutions | Team ARC USA | Express Motorsports | Xpert USA | Max.FX |Blitz / Team Titan | Hiro Seiko
Maxim 39-There is a difference between spare parts and extra [parts]. From The Seventy Maxims of Maximally Effective Mercenaries
Paul Ohlsen is offline   Reply With Quote
Old 06-26-2009, 08:55 AM   #994
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
Originally Posted by syndr0me View Post
Cone washers in the diff: (((((( ?
Out of curiosity, what's the advantage to using cone washers over a spring?
If you are running mod then (((((( to lock it down and not slip it/strip it...
Stock ()()() because there won't be high tourge...
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 06-26-2009, 09:50 AM   #995
syndr0me's Avatar
Trader Rating: 32 (100%+)
Cool, thanks. I've noticed the 416 diff screw/thrust/spring/t-nut seem to fit well. If it clears the CVD, I may just use that. I'm a fan of the spring and caged thrust.
syndr0me is offline   Reply With Quote
Old 06-26-2009, 09:51 AM   #996
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Originally Posted by Rod M View Post
all my electrics are in and did not need to double stack anything,
Looks pretty sweet!
Who makes that speedo?
I like the layout ... Power on one side and motor on the other ...
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 06-26-2009, 09:57 AM   #997
You are welcome, thats how it was explained to me when I asked the same question Monday night to a pro-driver....
RC Tech member #11
Old 06-26-2009, 10:07 AM   #998
Okay so.... What about 13.5 ? ()()()() TO (((((( or something in between?
No slip no strip are both important so.... (((((( for 13.5 as well?
Old 06-26-2009, 10:18 AM   #999
RC MARKET's Avatar
option parts
T.O.P. Racing "Photon" 1/10 EP Touring Car-top-po-pchc005.jpg   T.O.P. Racing "Photon" 1/10 EP Touring Car-top-po-pchc006.jpg
RC MARKET is offline   Reply With Quote
Old 06-26-2009, 11:02 AM   #1000
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
very interesting...... keep me posted.
luke
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
Old 06-26-2009, 11:06 AM   #1001
Luke you going to be at cotswold this weekend?
Craig Morgan - Tamiya 417
Slick990 is offline   Reply With Quote
Old 06-26-2009, 11:20 AM   #1002
i cant unfortunatly, i have sooooo many things on lol.
i will be there testing before the national though.
luke
Luke Hobson
Old 06-26-2009, 11:49 AM   #1003
JamesReilly's Avatar
Trader Rating: 56 (100%+)
try this:
Multiple Belleville washers may be stacked to modify the spring constant or amount of deflection
Deflection
Deflection or deflexion may refer to:*Deflection *Deflection *Deflection *Electrostatic deflection*Deflection ...
. Stacking in the same direction will add the spring constant in parallel, creating a stiffer joint (with the same deflection). Stacking in an alternating direction is the same as adding springs in series, resulting in a lower spring constant and greater deflection. Mixing and matching directions allow a specific spring constant and deflection capacity to be designed.
Example: 1 Spring is considered to be 1 in Parallel, 1 in Series. (This notation is needed for load calculations)
If n = # of springs in a stack, then: Parallel Stack (n in parallel, 1 in series) - Deflection is equal to that of one spring, Load is equal to that of n x 1 spring. i.e. Stack of 4 in parallel, 1 in series will have the same deflection as that of one spring and the load will be 4 times higher than that of one spring.
Series Stack (1 in parallel, n in series) - Deflection is equal to n x 1 spring, load is equal to that of one spring. i.e. Stack of 1 in parallel, 4 in series will have the same load of one spring and the deflection will be 4 times greater.
Tekno RC, Discount RC Store, REDS Racing USA,Reilly Paint (reillypaint@gmail.com)
"I'm not normal, just more normal then Finnish guys" - Ilias
JamesReilly is offline   Reply With Quote
Old 06-26-2009, 12:10 PM   #1004
Originally Posted by JamesReilly View Post
try this:
Deflection
So six of one and a half dozen of the other ... LOL
Looks like (((((( would be the way to go but the adjustment will be sensitive.
Or did I read that wrong?
Old 06-26-2009, 12:39 PM   #1005
Send a message via AIM to HenBeav
(((( is a hard spring
((() is a medium spring
()() is a soft spring
()()()()()() is really soft
all just depends on how much slip and play you want in the adjustment
[URL]http://www.fastlanehobby.com[/URL]
Support your local Lowe's, Walmart and Layne Machine Works INC.
HenBeav is offline   Reply With Quote
