Old 10-25-2012, 02:51 PM   #8986
E.J. Evans's Avatar
Send a message via Yahoo to E.J. Evans
Originally Posted by THE GOOCH View Post
Hey EJ, how often should you change the Kyosho O-rings?
Do they swell up like the stock ones with oil?
Beau
They don't swell as bad as our stock ones. It's not an exact science how often I change them. I just go by feel.
T.O.P. Racing | APEX Hobbies | R1 | Solaris | NorCal Hobbies |
Solaris Racing Products (SRP) Solaris Spec Tires!
www.solarisrp.com | www.apexhobbies.com | www.topracingusa.com
E.J. Evans is offline   Reply With Quote
Old 10-25-2012, 03:54 PM   #8987
The Captain's Avatar
Originally Posted by E.J. Evans View Post
Cap,
First thing, rebuild the shocks and change the o-ring. I've been using the Kyosho dual lip o-ring, or our standard 40 degree o-ring.
http://www.amainhobbies.com/product_...Shock-O-Ring-8
Our stock springs are very good. You should start off with 344gf in the front and 306gf in the rear.
as Professor mentioned lots of parts are interchangable, and we even now offer a conversion kit.
EJ
Thanks for the heads up, ill be sure to check the orings out and replace as necessary. As far as the stock springs, i only have the ones that came on the car, no idea what rates they are (didnt see any markings, they are black though). ill look to see if i can buy the different rates as a set, or ill just buy them separately.
I havent even touched it yet, hopefully this weekend i can tear in to it. Overall impression just giving it a once over is very good. Really like the anodized parts, really makes it pop.
-Derrick-
"Yeah, well, thats just like your opinion, man."
The Captain is offline   Reply With Quote
Old 10-25-2012, 04:22 PM   #8988
Professor's Avatar
captain
the top springs have the numbers (rating)printed on the springs although they can be a little difficult to read at times
VBC RACING AUS--HOBBYWING--MAD GRAPHICS--BITTY DESIGN
Professor is offline   Reply With Quote
Old 10-25-2012, 04:53 PM   #8989
Thanks professor, ill get a good look when i rebuild the shocks. Te guy i bought it from suggested running the front spool for vta. Opinions?
-Derrick-
Old 10-25-2012, 07:06 PM   #8990
Professor's Avatar
i have only ever run my cars with spools in the front,so i cant really comment on what will be best suited to vta & your surface conditions,but i'm sure one of the guys from here will help out
Old 10-25-2012, 07:22 PM   #8991
bkspeedo's Avatar
If you've driven a car with a spool i would go with that. If not you night want to start with a diff or gear diff in the front if you have one. These will be easier to drive.
The ultimate is a one-way for vta.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 10-25-2012, 09:28 PM   #8992
Trader Rating: 21 (100%+)
Originally Posted by MAD916 View Post
Just an FYI until the top DJS are available the arrowmax ECS shafts for the Tamiya 416/417 work perfect in the photon and the EX. They work with a slight dremel mod on the stock C-hubs, and still use the stock steering blocks and king pin collars. The best part is they work with the stock spool drive cups or the steel ones. And they take no CVD Blades. You just need to use 5x10x3 bearing on the inside of the steering knuckle
Got TONS of packs through my car with zero problems
Yup, felt good to me.....
See you on Sunday Mark!
Time Zone Raceways www.Timezonehobbies.com
www.ColinBranch.com
C Branch is offline   Reply With Quote
Old 11-01-2012, 02:55 PM   #8993
I got a top car and looking for a good starting setup for a snowbirds size track. Any help would be great. Thanks.
Joe DiGirolamo
losi888 is offline   Reply With Quote
Old 11-01-2012, 03:34 PM   #8994
RCFREAK's Avatar
Trader Rating: 17 (100%+)
Joe ygpm!!
Arv.
RC AMERICA// EA MOTORSPORTS// KO PROPO// ORCA
RCFREAK is offline   Reply With Quote
Old 11-02-2012, 05:55 PM   #8995
Hey guys, i tried to mount an hpi camaro body and my body posts are too short. Im not sure if the previous owner shortened the mounts, can someone measure them for me? I dont want to order the factory replacements if they are going to be too short as well.
If the stock ones arent long enough, anyone got a part number for some that will be long enough?
Thanks!
-Derrick-
Old 11-10-2012, 11:03 PM   #8996
Stock posts were plenty long, had to trim them.
Now I just need to get more steering out of this thing! Running a spool in the front, z suggestions? I have the lightest springs I have in the front, and adjusted the rear droop, which helped. I'll post my spring rates tomorrow. Car is set up for VTA. Also need opinions for shock oil.
Thanks!
-Derrick-
Old 11-10-2012, 11:03 PM   #8997
Thanks!
-Derrick-
Old 11-11-2012, 06:01 AM   #8998
snoopyrc's Avatar
It's a common issue when you buy a chassis from a TC racer. I almost always have to order more body post as soon as I get the car. VTA just rides higher.
Cap,
http://www.amainhobbies.com/product_...Shock-O-Ring-8EJ
Green slime? Or just get them wet with some oil?
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 11-11-2012, 02:06 PM   #8999
Does anyone have a link to some setup sheets for carpet? VTA specific would be awesome!
Car handled pretty good considering it was my first time running an onroad car. The problem i was having was very little steering in the corners. Like i said above, i put the softest springs i had in the front and gave it some more rear droop. Saucing the tires helped a lot as well.
Will the setup changes from 1/8 offroad carry over to onroad cars? Ive got a nice setup chart for 1/8 buggy that always worked.
I was also having issues with the servo saver sticking (not smooth). Is this a common problem, and do most people swap this out and or delete it?
Overall i am satisfied with the car. I really like the fact that no one ever knows what it is, i like being different.
Edit: as it sits right now 306 springs all around. No idea what shock oil (haven't changed it yet, wanted to get a baseline).
-Derrick-
Old 11-11-2012, 05:10 PM   #9000
Location: Beneath a rock down by the river. Don't have money for van
Hey guys,just got one Photon with lipo chassis.Will be reading the entire thread
( ͡ ͜ʖ ͡)
30Tooth is offline   Reply With Quote
