Old 09-22-2012, 09:37 PM   #8971
Kwikvdub's Avatar
Trader Rating: 90 (100%+)
Send a message via AIM to Kwikvdub
Thumbs up
Will do!..... Thanks JD!.....
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 09-23-2012, 08:53 PM   #8972
abi787's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to abi787
Questions?? Photon Titanium
Hi,were can I find a set of TITANIUM screws for the TopPhoton.
abi787 is offline   Reply With Quote
Old 10-02-2012, 04:57 AM   #8973
j.d.roost's Avatar
Trader Rating: 28 (100%+)
Looking for a set of Mira outdrives if anyone has a spare they are not using.
Shoot me a pm.
F1
Roche usa
R.I.P. Jon Williams
j.d.roost is offline   Reply With Quote
Old 10-02-2012, 06:46 AM   #8974
Trader Rating: 17 (100%+)
Shoot me a pm.
With everyone at IIC it might be hard to get a pair. I have a pair I was considering replacing they have a little bit of play in them though.
T.O.P Racing USA
"This T-bird will put a spell on you"
Mr.A Morris is offline   Reply With Quote
Old 10-02-2012, 08:23 AM   #8975
j.d.roost's Avatar
Going to have a nice set of T3 shafts to look at and nothing to
put them in.
I committed (ordered) a set of ecs's and the cups.
Got caught in a showed in stock but were not actually there .
Retailer might have the option to buy a good used set after IIc so that was super cool of him.
Not too many other options until the race is over with unless there is another cup that will work with the t3 style dogbones.
If everything falls through...I will pm you and see if you still have the used set to sell me.
I really appreciate it.
Jd
F1
Roche usa
R.I.P. Jon Williams
Old 10-21-2012, 03:36 PM   #8976
The Captain's Avatar
I just bought a TOP Photon from a friend to run VTA with, and have no clue what kind of diff and shock oils to use (first onroad car). Suggestions on diff and shock oil weights to start out with? Can only run one tire set, so no need to experiment with tires. I've only got one set of springs, any suggestions on a spring set?
Where is everyone getting their parts for these from, amain? Are the parts interchangeable with the photon ex? Thanks for any help/suggestions, I think I'm going to enjoy onroad more than offroad.
Edit: looks like this car only uses ball diffs, so no diff oil. How do you tune the diffs, by tension?
-Derrick-
"Yeah, well, thats just like your opinion, man."
The Captain is offline   Reply With Quote
Old 10-21-2012, 10:02 PM   #8977
Professor's Avatar
hey captain
the interchangeable parts between the photon & the ex are
arms
hinge pins
c hubs
steering knuckles
shocks
front bumper
rear belt
the gear diff from the ex will fit into the photon (just has to be shimmed properly for aligment
may be more parts, cant remember,been a while since i had my photon now, someone on here will let you know
t.o.p.usa seel patrs also i believe
hope this helps & hope you enjoy the photon
VBC RACING AUS--HOBBYWING--MAD GRAPHICS--BITTY DESIGN
Professor is offline   Reply With Quote
Old 10-22-2012, 09:09 AM   #8978
Default ECS shafts
I read the wiki, but the mira outdrives are discontinued . . .
is the only option to go with the Spec-R shafts?
mupchu is offline   Reply With Quote
Old 10-22-2012, 05:21 PM   #8979
mazmo's Avatar
+ 1
Also has anyone tried the Yokomo DJC? Pic below. Part No. BD-010FW
Team TOP Australia www.topracing.net.au
TOP Photon EX 17.5 + TOP Photon EX 21.5 + TOP Rebel F1 21.5
ORCA | Tekin RS Pro | Tekin Gen 2 RPM | Ko Pro-Po | EPIC Trinity
mazmo is offline   Reply With Quote
Old 10-25-2012, 06:25 AM   #8980
There making a conversion kit to the EX!!!!
https://www.facebook.com/#!/photo.ph...type=1&theater
T.O.P Racing USA
Old 10-25-2012, 11:40 AM   #8981
E.J. Evans's Avatar
Send a message via Yahoo to E.J. Evans
Originally Posted by mazmo View Post
+ 1
The ball and pin are bigger then ours. You can make it fit but will require some modification of our outdrives.
TOP DCJ's are coming. About 3 months away.
T.O.P. Racing | APEX Hobbies | R1 | Solaris | NorCal Hobbies |
Solaris Racing Products (SRP) Solaris Spec Tires!
www.solarisrp.com | www.apexhobbies.com | www.topracingusa.com
E.J. Evans is offline   Reply With Quote
Old 10-25-2012, 11:45 AM   #8982
E.J. Evans's Avatar
Cap,
First thing, rebuild the shocks and change the o-ring. I've been using the Kyosho dual lip o-ring, or our standard 40 degree o-ring.
http://www.amainhobbies.com/product_...Shock-O-Ring-8
Our stock springs are very good. You should start off with 344gf in the front and 306gf in the rear.
as Professor mentioned lots of parts are interchangable, and we even now offer a conversion kit.
EJ
Old 10-25-2012, 11:58 AM   #8983
Originally Posted by E.J. Evans View Post
Cap,
EJ
can you tell us when the conversion kit will be available, and what the price will be?
Old 10-25-2012, 12:35 PM   #8984
MAD916's Avatar
Just an FYI until the top DJS are available the arrowmax ECS shafts for the Tamiya 416/417 work perfect in the photon and the EX. They work with a slight dremel mod on the stock C-hubs, and still use the stock steering blocks and king pin collars. The best part is they work with the stock spool drive cups or the steel ones. And they take no CVD Blades. You just need to use 5x10x3 bearing on the inside of the steering knuckle
Got TONS of packs through my car with zero problems
Timezone Raceway Park " on-road outdoor european style road course.
Timezone II 60'x100' indoor carpet track. Host of the ROAR 2011 Carpet Nat's.
Timezonehobbies.com your new source for online RC products.
MAD916 is offline   Reply With Quote
Old 10-25-2012, 12:51 PM   #8985
Cap,
EJ
Hey EJ, how often should you change the Kyosho O-rings?
Do they swell up like the stock ones with oil?
Beau
THE GOOCH is offline   Reply With Quote
