Old 04-23-2012, 02:05 AM   #8866
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
Mike, why you prefer the xray ones over top?
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
Don't practice until you get it right. Practice until you can't get it wrong
nnick is offline   Reply With Quote
Old 04-23-2012, 03:38 AM   #8867
hanulec's Avatar
Trader Rating: 27 (100%+)
In the states we race indoors on CRC click track and other hard border systems. The current (old) top steering blocks would break after a few hard hits. The Xray ones are a litttle beefier and can handle thd beating running on tight lanes.
From what I see the xray plastic blocks won't work unmodified in thd Photon EX so ill try the aluminum blocks initially while racing outdoors.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 04-23-2012, 03:57 AM   #8868
Shop Owner
nnick's Avatar
Oh I see!!
We had an indoor race once and I used all my stock on c-hubs 0,2,4,6 left right!! Only ones who survived were those with alu c-hubs
Nikolakopoulos Nick
RC RING
Enjoy RCing....
R/C Tech #82
IRT #123
Old 04-23-2012, 04:02 AM   #8869
hanulec's Avatar
Hinestly I've never run the stock c-hub as I've always been trying to run LCD/ecs style joints. The xray c-hubs are the gold standard in durability. I was happy these xray parts fit when I switched to the photon -- I had less spares to buy.
Old 04-23-2012, 06:38 AM   #8870
bkspeedo's Avatar
The new Tamyia double jointed CVD's look nice and will work with the stock Photon c-hubs with just a little shaving of the inside side walls. They'll probably hold up better than the xRay ones as well, large pins holding them together.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design ~ Helix Designs
5280 Raceway
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 04-23-2012, 08:26 AM   #8871
hanulec's Avatar
Can 10x5x4 bearings be used? Or only 3mm wide ones??
I'm also looking into the Reflex lcds for the TC 6.1. They are longer than 50mm ecs and top 44.5 mm shafts but shorter than top 46mm shafts.
Old 04-23-2012, 12:11 PM   #8872
bkspeedo's Avatar
Yes i did forget about that. You would need the 3mm thick bearings.
Brent Klingforth
5280 Raceway
Old 04-24-2012, 02:26 PM   #8873
Trader Rating: 23 (100%+)
Smokin deal on my top
CEFX/TOP TOURING CAR
bmcallister is offline   Reply With Quote
Old 04-28-2012, 03:20 PM   #8874
yogii's Avatar
I hate to change the topic but can someone give me some info on what a good long lasting 17.5 motor would be. I purchased a Thunder Power 17.5 last September only too run it in 3 races and last night the motor had no top end. I thought my speed controller had lost itís bind with radio but that was not it. I always take 4 balance batteries to the race 1 to practice with, 2 too qualify with and 1 for the A main. Well the motor did great the 1st 2 qualifiers, but the final race it did 1 or 2 great practice laps and poof no top end. This morning I took motor apart couldít see anything wrong. Iím thinking itís in the timing bell. I have no means of testing this area, or even know what itís for. I have never adjusted the timing I left it ware it came on 20 degree mark. If you are thinking what speed controller Iím using, that would be the Tiken RS Pro. Any suggestions for a rookie. Thanks
yogii is offline   Reply With Quote
Old 05-01-2012, 11:48 AM   #8875
ewashburnaf's Avatar
Trader Rating: 14 (100%+)
I would recommend the Team Epic Duo 3 17.5 motor or the RevTech 17.5. My experiences with these motors, in blinky and boosted class have been great. They are both very similar motors, but hold up to abuse very well. They do not overheat easily and are very competitive motors. A bonus is that they cost around $70-80. StormerHobbies has the Duo3 for $69.99.
Fishhook
ewashburnaf is offline   Reply With Quote
Old 05-01-2012, 12:29 PM   #8876
bkspeedo's Avatar
Most likely the Sensor board is bad, this can happen with any motor. I've been running 2 ThunderPower motors 3-4 race days a week since the beginning of January with no issues. I my opinion the TP 17.5 with a Green rotor is the faster motor I've ever used. Stick with it, there small, light weight, and run cooler than most.
FYI for TC 17.5 blinky run an FDR around 3.8 with timing set to 35 & a fan for a track size around 45x96ft, wicked fast.
Brent Klingforth
5280 Raceway
Old 05-01-2012, 06:46 PM   #8877
yogii's Avatar
Thanks for the reply guys, that Thunder Power motor after coming off the track, was stone cold. I could if wanted wrap my hands around it and hold it forever. My rotor has no color to it other then silver. But I will try a Team Epic or Rev Tech
Thanks ones again
Old 05-01-2012, 06:55 PM   #8878
yogii's Avatar
Sorry what is TC 17.5 blinky? I know only one thing I love my TOP, I only hope I can get it dial in. I'm the only one at this track with one. I run Serpent 966 and 733 there so dial in. I hope soon I can push the TOP to higher limits.
Old 05-01-2012, 09:50 PM   #8879
bkspeedo's Avatar
TC 17.5 Blinky is; Tour Car running a 17.5 turn motor using a Timing based ESC with no timing.
What class are you running at your track and what wind is the TP motor?
Brent Klingforth
5280 Raceway
Old 05-04-2012, 02:14 PM   #8880
http://www.youtube.com/watch?v=ehqHQ...eature=g-all-u
Larry Fairtrace racing at iic!! They didn't show much of him on RCracing.tv but well done regardless.
Fishhook
