Old 03-06-2012, 04:22 PM   #8821
1shnot's Avatar
would it fit original photon without mod?
-Fast cats
-eXpress motorsports
-T.O.P
-Airtronics
1shnot is offline   Reply With Quote
Old 03-06-2012, 05:56 PM   #8822
Professor's Avatar
may be a little early to tell unless ej has tried or had a good look at it fitting in the photon (not the ex)
VBC RACING AUS--HOBBYWING--MAD GRAPHICS--BITTY DESIGN
Professor is offline   Reply With Quote
Old 03-06-2012, 08:38 PM   #8823
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
Aww...thought the EX would have the aluminum hinge pin toe pieces. Anyways, the rest of the car looks good, glad to hear if I upgrade from my Photon, I'll have spares to go along with the EX.
Dan is offline   Reply With Quote
Old 03-06-2012, 08:54 PM   #8824
hanulec's Avatar
Trader Rating: 25 (100%+)
i don't see a reason why it wouldn't fit. the Photon ball diff also works w/in the Photon EX -- and they didn't remake the ball diff.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 03-06-2012, 09:50 PM   #8825
Professor's Avatar
mike,i thought the same thing but wasnt prepared to say so at this point as i only got to look/play with the original prototype which has been changed a lot to the production version
Old 03-08-2012, 01:38 AM   #8826
Bishop's Avatar
Couple of things I noticed with the CAD pictures, am I imagining it, or does it still have all the mounting holes for the current steering rack and servo position?.
Also has it crash tested alright with the new motor mount?
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 03-08-2012, 01:52 AM   #8827
Motor mount is no problem, we had no problems with a few months of racing on the proto.
The only thing to look out of is to be selective which holes you use on some motors, we had a can bend on an Orion VST, using the wrong set of holes, near some vents.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 03-08-2012, 03:15 AM   #8828
*SBH*'s Avatar
Hi Bishop
Yes it will be possible to use both the new and the old type of steering system. Then it's up to the driver if You prefer a steering rack or not.
*SBH* is offline   Reply With Quote
Old 03-08-2012, 04:51 AM   #8829
hanulec's Avatar
Ive seen Larry send his first EX prototype countless times without worry. He didn't replace a metal part on that car.
Old 03-08-2012, 05:47 AM   #8830
Bishop's Avatar
Good to know, thanks guys.
QRCCRA
www.qrccra.org.au
Old 03-08-2012, 03:03 PM   #8831
brqsdad's Avatar
Default RE: Mod Setup
Anyone have any good set ups for mod? We will be running it at Carpet Nats. Never ran it before.......only 17.5 blinky and boosted. Thanks in advance for your help!
www.rcamerica.com
"Nitro is dumb!" - Billy "The Snake" Sydor
brqsdad is offline   Reply With Quote
Old 03-09-2012, 05:43 PM   #8832
Bishop's Avatar
It struck me today looking at the EX CAD pics that the new diff looks like the one out of the Sabre...
I'm pondering weather to order an EX or not this weekend, spent a lot on RC gear over the new year, but then my current Photon needs a work over, between a few shagged bits and really needing some replacements diffs (managed to chew two micro diffs within two meets in the front end), I realized by the time I clean up and sort out the old car, I'd be half way to buying the new one...
QRCCRA
www.qrccra.org.au
Old 03-09-2012, 07:49 PM   #8833
hanulec's Avatar
I have a setup from EJ that is going in the right direction. He ran it at Jackson in mod... and I've been running it at Horsham with a 4.0. Ill put together a setup sheet Sunday. If u don't see anything remind me..
EJ will be at the Nats too ....
Old 03-14-2012, 06:26 PM   #8834
hanulec's Avatar
I just upload my current modified rubber TC carpet setup. It is inspired by EJ's Asphalt Nats setup. The major difference is the front anti-dive.
http://racerlog.com/wiki/T.O.P._Photon#Setups
Old 03-15-2012, 11:18 AM   #8835
E.J. Evans's Avatar
Send a message via Yahoo to E.J. Evans
Default EX
More pics of the EX.
T.O.P. Racing "Photon" 1/10 EP Touring Car-front-front-ex.jpg   T.O.P. Racing "Photon" 1/10 EP Touring Car-lipo-retainer-ex.jpg   T.O.P. Racing "Photon" 1/10 EP Touring Car-motor-mount-ex.jpg   T.O.P. Racing "Photon" 1/10 EP Touring Car-rear-rear-ex.jpg
T.O.P. Racing | APEX Hobbies | R1 | Solaris | NorCal Hobbies |
Solaris Racing Products (SRP) Solaris Spec Tires!
www.solarisrp.com | www.apexhobbies.com | www.topracingusa.com
E.J. Evans is offline   Reply With Quote
