Old 12-26-2011, 07:25 PM   #8626
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
Thanks for the info guys! Getting back into high end 1/10th touring after doing 1/8th offroad for the past few years. The Photon has been an easy build so far with some very minor issues but I can't wait to get this thing on the track.
Guess I'll slap on a servo saver. Any recommendations for ones that just seem to fit well?
Lastly, will the stock aluminum bones for the front bend easily on a slight tap with the boards?
Dan is offline   Reply With Quote
Old 12-26-2011, 10:41 PM   #8627
Professor's Avatar
Default servo saver
hi dan
currently i am using the servo saver that xray brought out earlier this year with no problems,prior to that i was using the standard one that top have also with no problems
get the steel bones for the front they will serve you much better than the alloy ones
VBC RACING AUS--HOBBYWING--MAD GRAPHICS--BITTY DESIGN
Professor is offline   Reply With Quote
Old 12-27-2011, 05:08 AM   #8628
hanulec's Avatar
Trader Rating: 27 (100%+)
The STD servo saver is a kimbrough medium. Works fine - and 1/3 the price of the xray one.
Some of us are running xray ecs along with my side piece racing Mira outdrives up front. Add some mid-corner steering and removes the wheel chatter at full lock.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 12-27-2011, 10:11 AM   #8629
I think you should slap on two servo savers.
Sydewynder is offline   Reply With Quote
Old 12-27-2011, 10:39 AM   #8630
Trader Rating: 17 (100%+)
I thought I would throw this over here. before I put it on the for sale section I'm selling my EJ chassis. Only 2 carpet races on it!! Love IT! some stuff came up..
Shoot me a PM.. Thinking $65 shipped (Lower 48). open to offers.. if international you pay for shipping
T.O.P Racing USA
"This T-bird will put a spell on you"
Mr.A Morris is offline   Reply With Quote
Old 12-27-2011, 11:42 AM   #8631
TeamWTF's Avatar
Originally Posted by Professor View Post
hi dan
I'm also using an xray servo saver...
Not sure on the part number, but its pretty beefy. It flexes less when running the servo east/west nd feels more consistent. As said though, its pretty pricey
T.O.P. Racing Australia www.topracing.net.au
TeamWTF is offline   Reply With Quote
Old 12-27-2011, 11:52 AM   #8632
vabroom's Avatar
This is probably the one that you are talking about:
http://www.nexusracing.com/product_i...ab6f9260d743d0
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 12-27-2011, 12:13 PM   #8633
Professor's Avatar
[QUOTE=vabroom;10087305]This is probably the one that you are talking about:
yes thats the one
Old 12-29-2011, 08:26 PM   #8634
Dan
Dan's Avatar
Completed the kit a few days ago...sexy in red.
Built it with the main belt on the battery side, will need to get some spacers for the side piece battery retainer. Little bit disappointed the upper deck gets in the way of the battery terminal connections but at least the battery will be pushed out more to even out the L/R weight distribution.
Old 12-30-2011, 01:22 PM   #8635
ghostman24's Avatar
Trader Rating: 25 (100%+)
Default gear diff
does anyone know if the gear diff from the TC6.1 will work in the Photon?
ghostman24 is offline   Reply With Quote
Old 12-30-2011, 02:07 PM   #8636
Jerry P's Avatar
Trader Rating: 44 (100%+)
if anyone is insterested pm me, i have a used exotek chassis for sale.
Used Exotek Photon Chassis
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 12-30-2011, 02:09 PM   #8637
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
I have fitted a Spec r and Yokomo diffs on my Photon which also fits the TC6 so big chance it will. Just had to shim it and also use the different diff blades.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 12-30-2011, 02:23 PM   #8638
ghostman24's Avatar
Ok thanks. I was thinking the same.
Old 12-31-2011, 06:50 AM   #8639
is yokomo geardiff as smooth as xray diff?
I tried to rotate my friend's xray diff by hand, it is very smooth, and no leakage (from their experience).
I couldn't find yokomo diff in our local shop, so I just want to make sure how smooth it is before I order it from the online store.
TOP Racing
krat is offline   Reply With Quote
Old 12-31-2011, 07:10 AM   #8640
hanulec's Avatar
the yokomo is pretty good. it takes a few packs to break in -- but so does the xray gear diff. as gear diffs wear in they become smoother -- so you need to use heavier oil to get the same feel as they had when they are brand new.
running modified touring is a great way (although somewhat expensive when mistakes happen) to break in new gear diffs
