Old 12-16-2011, 05:19 PM   #8581
hanulec's Avatar
Trader Rating: 23 (100%+)
Justin - have you rebuilt your shocks recently? how do you build them? shocks are SO important on the photon...
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 12-16-2011, 05:34 PM   #8582
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
Yea always .. f55 r 45 zero rebound all 4 r even indexed so each rebuild the cap is tightened identicaly every time shock length is identical on all 4 also
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 12-16-2011, 05:41 PM   #8583
RCFREAK's Avatar
Trader Rating: 17 (100%+)
Justin is that your wt oil in the shocks? 55wt front and 45wt rear?
you need to post your setup entirely and the changes from the "LF" setup.. my car has been getting faster as i run it, and easier to driver even on high bite conditions.. even running against "new" version cars.
I was able to TQ at our local Toys for Tots race and take the win this past weekend. previously, i had also won 2 weeks in a row. now thats 3 wins and a TQ in 3 races straight... Before this, i would only be able to qualify top 3 at best for a year at my local track.
Arv.
RC AMERICA// EA MOTORSPORTS// KO PROPO// ORCA
RCFREAK is offline   Reply With Quote
Old 12-16-2011, 05:41 PM   #8584
hanulec's Avatar
what o-rings are you using?
what brand of oil?
why so heavy with the oil in the front end? i'd recommend running the same oil front and rear. i run 42.5wt losi to begin with where ever i go.
what springs are you running?
heck, what setup are you running? have you tried one of Larry's?
Old 12-16-2011, 06:49 PM   #8585
TeamWTF's Avatar
I see people talking about O rings a lot...
I just bought the 30 deg oil mixed for a rebuild. It gets pretty hot here (But thats what was in stock) will these be ok?
Please, teach me!
T.O.P. Racing Australia www.topracing.net.au
TeamWTF is offline   Reply With Quote
Old 12-16-2011, 07:07 PM   #8586
hanulec's Avatar
Please, teach me!
Been running the 40 degree.. they hold up longer than 30 degree. Orings start to absorb oil and grow causing the shaft to slow down. If you spray your shocks with motor spray that could destroy thd orings too... making 10wt oil feel heavier than 100wt.
Old 12-16-2011, 07:30 PM   #8587
what brand of oil?
Let me dig my car out. Lol its Larry's set up as I was told by him
This is the carpet lipo chassis car with v2 shocks ,alum f/r carriers ,alum ball studs
Equipment : airtronics m11,futaba 9550,tekin rs pro,revtech 17.5 w/ heatsink,fan ,revtech 65c 6500 . Car rtr 1382g only 14g added to rear outside corner of batt to balance
Setup
Front;
2.25+- neg camber /2 deg total toe out
Med/low inner mount spaced out 2mm
2mm spacer behind ARM ,1.5 infront
Inside camber link in hole 3 ( far inside) shimmed up 1mm
Lower shock in #2 ,shock tower ; #2 (second hole out)
393 front springs with 55wt AE oil 0 rebound w/ 40deg o-rings(new )
5.2mm ride with 1.5-2mm up travel (tire lift)
Steering ; mid position with #10 insert / outside hole used on steering blocks
Rear ;
2.5 neg per side camber / 4.5 deg total toe in
Hinge pin mounts
Front of rear med/low w/1mm shim
Rear of rear low/high w/ 3mm shim
2mm shim infront of ARM / 1.5 mm behind
1.25 optional camber plates in hole #3 (all way in) shimmed up 2mm
On hub inside hole shimmed up 1.5mm
Bottom of shock in hole #2 / top of shock in #2 (2nd hole from outside)
Shocks : 306 springs / 45 oil /0 rebound/40deg o-rings
5.8mm ride with 2.5-3mm up travel (tire lift)
Realy hope all this makes sence
Justin & Matt Lyons
a800s sanwa m12s
Old 12-16-2011, 07:59 PM   #8588
L.Fairtrace's Avatar
Send a message via AIM to L.Fairtrace
Setup
Front;
Rear ;
Hinge pin mounts
I see a number of differences from that setup to the one I have posted a bunch of times.
Front:
I run 1mm shims for trackwidth not 2mm
I always run the middle hole on the tower.
I usually run 1.5mm shim on the inner camberlink. Sometimes 2mm
I always run 45 or 42.5 losi shock oil in the front
and the alum front knuckles are not good for rubber tires. The ackerman difference between the outer hole on these to the composite ones is massive. This could be a major part of the problem here.
Rear:
I run my car with wheelbase 2.5 front of arm 1mm rear
Question? about camber link plate? Are you running the optional plate in the rear super long? Like where the screw is on top of the bearing? If so that is wrong you want the middle hole here. This is also another major issue if that is how you have it. It will make the rear super lazy.
Rear tower I usually run the 3rd hole in sometimes the 4th hole on carpet
usually run 42.5 rear losi oil.
5.5 rideheight rear 5.2 front
I also usually run the weight I had to add on the front of the battery and servo but that is up to you. The car should be easier to drive the farther forward you put the weight.
Battery pushed all the way forward also.
Try all those changes. Please try them all together at one time.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 12-16-2011, 08:26 PM   #8589
Front:
Rear:
Sounds good might be a few weeks .. yea I don't know if I can afford running the plastic front carriers. Lol those things r just stupid brittle ... Would using the inner hole be better ?
Justin & Matt Lyons
a800s sanwa m12s
Old 12-17-2011, 04:28 AM   #8590
hanulec's Avatar
Run xray medium steering blocks/knuckles
Make sure u have a manly bumper - top hard or Parks photon bumper. The wimpy top soft bumper is just asking to break knuckles
Old 12-17-2011, 08:39 AM   #8591
Ok sounds good . As for the bumper yea I have a very beefie bumper think its a parma block, carved to fit the body shape and I cut a spot into the top to drop weight in if needed
Justin & Matt Lyons
a800s sanwa m12s
Old 12-17-2011, 12:11 PM   #8592
Default DRCCC
I won the Club Championship in 17.5 Boosted with TOP PHOTON Exotek Chassis with ORCA MK2 esc and RX2 17.5 Motor and ORCA INFINITE 6000mAh 7.4V 60C RACE PACK.
VIDEO CLIP OF WINNING CAR
Took 2nd place in 13.5 Boosted with TOP PHOTON Exotek Chassis with ORCA MK2 esc and RX2 13.5 Motor and INFINITE 6000mAh 7.4V 60C RACE PACK.
Won FWD Class with TOP Sabre.
I love TOP RACING Products
2Quick is offline   Reply With Quote
Old 12-17-2011, 04:04 PM   #8593
stiltskin's Avatar
Trader Rating: 101 (100%+)
Congratulations. Way to lay it down.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 12-18-2011, 01:13 PM   #8594
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
Hi,
What's the difference of the 3 versions of springs? Alpfa, Beta, Gamma? I'm interested for asphalt and usually not good traction
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
Don't practice until you get it right. Practice until you can't get it wrong
nnick is offline   Reply With Quote
Old 12-18-2011, 01:30 PM   #8595
RC MARKET's Avatar
Photon kit X'Mas discount now !
RC MARKET is offline   Reply With Quote
