Old 12-09-2011, 12:32 PM   #8551
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Originally Posted by stiltskin View Post
Since you called me out, I decided to weigh my electronics. I haven't weighed them in awhile, so I was a little surprised at the results. Thunderpower 50c 5200 battery 298 grams. OHP 65c 6000 battery 315 grams.
Electronics: Tekin RS, Futaba 9551, Futaba micro receiver, Micro xponder, Boss fan, 302 grams.
So I'm looking at a 302/298 or 302/315 weight balance. I guess (for me) the belt side doesn't matter as much as general placement and good balance.
Here is the problem with those numbers. The weight is distributed differently. The motor hangs wayyy off the chassis. The battery does not. So really you would have to use balance buttons or something to balalnce your car.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 12-09-2011, 03:20 PM   #8552
stiltskin's Avatar
Trader Rating: 102 (100%+)
Agreed
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 12-10-2011, 03:03 AM   #8553
TeamWTF's Avatar
If you are running the lipo chassis with the aluminium holders out as far as possible on the chassis, it should be very very close. I rebuilt a fellow racers car that had a lipo chassis and aluminium holders... It balanced well with 300g lipo's, hw 120a esc, std servo and receiver. Thats with the belts flipped and the esc mounted as far in as possible
T.O.P. Racing Australia www.topracing.net.au
TeamWTF is offline   Reply With Quote
Old 12-10-2011, 05:49 AM   #8554
Bishop's Avatar
One good thing with the alloy mounts, you can shim in or out on the battery you are using just right to balance the car.
I was running the larger Hobbywing ESC, which has some down sides, as if you want a slick layout you need the servo forward and out (with a micro spektrum RX), and the ESC is tough to push inwards.
Now I'm running a Justock, which can sit a fair way in, and the servo then had room to come back and in, benefit of all that, is I could shim my battery inwards to get my balance, car felt more responsive with these changes.
Other great point of the Photon I hope they don't drop on the new model, balance holes on the shock towers, seriously just get two metal skewers or something, bend them at the tips, and you have a instant way to check your balance by lifting the car from the small holes, so easy to do.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 12-10-2011, 05:59 AM   #8555
+1 on the balance holes...i haven't used skewers, but a couple of paper clips tied to the end of about 12 inches of string always gets me close...
The Hobby Shop,The Ohio RC Factory
T.O.P. Photon CRC XTI, XRAY T4 15 xray xb4 xb8e losi sct 2.0
insanity takes it's toll...please have exact change
bpalmer is offline   Reply With Quote
Old 12-10-2011, 01:53 PM   #8556
AlanHall's Avatar
Trader Rating: 42 (100%+)
Send a message via AIM to AlanHall Send a message via Yahoo to AlanHall
If my local track don't have a spec rubber tire.. what's a good choice? Was looking into these
http://www.sweepracingusa.com/110-EX...ts-4_p_18.html
Alan Hall
AE B5r
AE B5/SC10
AlanHall is offline   Reply With Quote
Old 12-10-2011, 02:36 PM   #8557
TeamWTF's Avatar
Whats the surface? Asphalt/carpet/something strange?
Old 12-10-2011, 04:40 PM   #8558
Trader Rating: 15 (100%+)
Default Car layout
I am using a Tekin esc with Spectrum receiver and small servo. Can someone post a pic of there car and how they laid it out.
mdhyams is offline   Reply With Quote
Old 12-10-2011, 05:27 PM   #8559
AlanHall's Avatar
Oh yeah LOL.. carpet..
Alan Hall
AE B5r
AE B5/SC10
Old 12-10-2011, 10:02 PM   #8560
hanulec's Avatar
Trader Rating: 27 (100%+)
Most big races and/or clubs run Solaris Medium or Sweep True Blue premounts
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 12-11-2011, 02:14 AM   #8561
TeamWTF's Avatar
I dont use a Tekin, but what chassis are you using? Have you done the servo mod?
I'd highly recommend the servo mod... makes it look like a totally new car and much neater.
Old 12-11-2011, 03:39 AM   #8562
Bishop's Avatar
You really don't 'need' to rotate the servo to get a good layout with the right gear, I actually don't see the point in rotating the servo unless your going to run a swing or sliding rack.
It's interesting the new EX seems to be going a swing rack, which it seems follows Xray etc, they say it's less sensitive in steering feedback to the car, while being more direct with less slop, though I think it's a shame to move the servo out further when running this type of rack, but it does give more ESC room, but with any luck another 6-12 months and 'all' the brands will have much more compact speed controllers.
Some other companies receivers though are almost embarrassingly over sized...
T.O.P. Racing "Photon" 1/10 EP Touring Car-compactphoton.jpg
QRCCRA
www.qrccra.org.au
Old 12-11-2011, 07:44 AM   #8563
AlanHall's Avatar
How's the handling change? My exotek chassis is set up for it.
Alan Hall
AE B5r
AE B5/SC10
Old 12-11-2011, 11:09 AM   #8564
odpurple's Avatar
Great avatar, Mike...I mean Santa!
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 12-11-2011, 11:58 AM   #8565
hanulec's Avatar
Thanks. We had a Toys 4 Tots race yesterday at Horsham and someone modified our awards to look like a Santa FJ.
Anyway - TOP drivers took down the four classes we competed in. Larry won super stock TC and 13.5 boosted 1/12. Goat won WGT in his debut. I took down stock 1/12.
