Old 12-04-2011, 09:26 PM   #8536
TeamWTF's Avatar
Originally Posted by AlanHall View Post
Have you ran the speed passion V3? I haven't got to run mine yet..this one
http://www.rctech.net/forum/attachme...x-img_2628.jpg
Dont worry, that motor is fine
T.O.P. Racing Australia www.topracing.net.au
TeamWTF is offline   Reply With Quote
Old 12-04-2011, 10:17 PM   #8537
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
Originally Posted by TeamWTF View Post
Change roll and dive/squat by adding/removing spacers. Toe is changed with different blocks, width would be adjustable in the same way.
Sell it? Well, its a tougher design... Suppose to change the way the arms/bulkheads/chassis flexes?
I like it... The roll adjustment is probably easier with the new design. Toe and width well... Probably easier just a few additional spares needed. Realistically, if your on a budget, you wont need all the different blocks. Probably 2deg, 2.5 and 3.0... But that depends on motor class and how you set the car up.
I cant wait to get my hands on one....
Tks for reply
Seems like it would just be easier if they did it like the T3 does
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 12-05-2011, 05:44 AM   #8538
hanulec's Avatar
Trader Rating: 23 (100%+)
Guys - around the photon ex - it is changing. I cannot spill all of the beans but don't make up your mind if you like the car or not by a few shots of the car. The changes are more of a fine tuning based upon what they learned by running the prototypes.
This weekend Larry Photon EX looked really good at our club race. He is trying to build a setup that is easier to apply to the car by using the easier EJ shock building method. Honestly I haven't seen him as excited about his TC in a while as it as working better than his STD Photon.
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 12-05-2011, 06:19 AM   #8539
I use to run the v3 all the time till I bought a couple 1cell motors. The 1cell motors, I have found to have some good bottom end for TC. I just started messing with the mmms.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 12-05-2011, 06:38 AM   #8540
Bishop's Avatar
LOL, only problem with editing posts, if your subscribed you get email alerts with the original content, regardless of how quick you changed it.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 12-05-2011, 09:16 AM   #8541
hanulec's Avatar
I guess a secret might be out.. oh well. It is good news. Honestly I hope the new production car is as good as the prototype is now.
Old 12-05-2011, 12:37 PM   #8542
part-time racer's Avatar
on the EX, is it likely that this new car will follow the xray 12 method of connection between bulk-heads and wishbones or go with the proto-type / tamiya style?
part-time racer is offline   Reply With Quote
Old 12-06-2011, 07:57 AM   #8543
Buckaroo's Avatar
Anyone tried fitting/running the new TC6.1 gear diff?
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 12-06-2011, 10:32 AM   #8544
hanulec's Avatar
Haven't tried yet. The tc6 bones have a big ball end. You'll need their blades for sure.
I use asc blades in my yokomo diffs already by - sanding down the thickness Nd drilling the pin hole larger
Old 12-07-2011, 11:52 PM   #8545
AlanHall's Avatar
Trader Rating: 42 (100%+)
Send a message via AIM to AlanHall Send a message via Yahoo to AlanHall
When I look at my car it makes me think the belts should be flipped so the front belt is on the right. I saw a few pics like this too... any reason to..or not to try it?
Alan Hall
AE B5r
AE B5/SC10
AlanHall is offline   Reply With Quote
Old 12-08-2011, 05:37 AM   #8546
stiltskin's Avatar
Trader Rating: 99 (100%+)
The goal is to balance your car with everything as close to centerline as possible. With the motor side usually being the heavy side, you can flip the long belt to the right and mount your electronics closer to center. This will push the battery a little further out for balance but you shouldn't need as much weight on the battery side to balance the car. There is no reason NOT to try it.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 12-08-2011, 07:54 AM   #8547
AlanHall's Avatar
Cool thanks. I wont have all my electronics till after chrismas.gotta take care of the little kids toys before dads lol. Then ill mess with getting it balanced.
Alan Hall
AE B5r
AE B5/SC10
Old 12-08-2011, 08:59 AM   #8548
L.Fairtrace's Avatar
Send a message via AIM to L.Fairtrace
I dont know about everyone else but on my car the heavy side is the battery side.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 12-08-2011, 10:25 AM   #8549
AlanHall's Avatar
So you think it even matters with the belt? Cause the battery can go in more too.bigger I guess I really just need to get my electronic stuff in and see how it sits
Alan Hall
AE B5r
AE B5/SC10
Old 12-09-2011, 01:28 PM   #8550
stiltskin's Avatar
Since you called me out, I decided to weigh my electronics. I haven't weighed them in awhile, so I was a little surprised at the results. Thunderpower 50c 5200 battery 298 grams. OHP 65c 6000 battery 315 grams.
Electronics: Tekin RS, Futaba 9551, Futaba micro receiver, Micro xponder, Boss fan, 302 grams.
So I'm looking at a 302/298 or 302/315 weight balance. I guess (for me) the belt side doesn't matter as much as general placement and good balance.
Tony Rumple
SEO by vBSEO 3.5.0
