Old 11-19-2011, 02:40 AM   #8476
Originally Posted by ralph m View Post
Yeah that's what I need! Couldn't for the life of me find that Thanks!
Old 11-19-2011, 02:44 AM   #8477
Originally Posted by odpurple View Post
Hey Burt, all you have to do is email us at topracingusa@yahoo.com
Everything is in stock.
Or you can order through RWH
Thanks OD...I already have an order in for some 1/8th buggy parts at Amain so I'm going to see if they can add in these parts to the order
Old 11-19-2011, 05:52 AM   #8478
heretic's Avatar
Originally Posted by TeamWTF View Post
If its really low grip you might want it to roll a little more? Maybe softer oil also (40wt is standard, try 30wt)
I found the kit setup didnt turn really well... Maybe your car is easy to drive but if it is understeering maybe you could fix that also... Use a little less rear toe (For stock classes) for starters...
I should have mentioned that the only thing I tried to change from the box setup was, hum... going down to 30wt (AE oil). It didn't change as much as I expected but it felt a little easier ( not sure about laptimes though because the carpet picks up a bit of grip suddenly after the 2nd qualification usually.)
I definitely will try a bit less toe-in because indeed the rear end is planted, but most of my fellow racers use between 3 and 3.5 degrees. I had the winner of our race ( really, really good driver) drive my car during the lunch break and he was positive about the handling and told me to change nothing. Which I did. But I'm pretty sure I would have been faster with my fk05, haha
Could you explain the idea behind widening the rear track with +1mm between the bulkhead and the inner hingepin mount ? (i.e. like the manual says)
I noticed for example S.Weiss' sheet from the photon wiki has removed it, going to 0mm at the front of the arm, and 2.4mm at the back of the arm.
Why ?
thanks again !
I love wedge bodies. I love dish wheels.
heretic is offline   Reply With Quote
Old 11-19-2011, 08:45 AM   #8479
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
With the 2.4 in rear and 0 in front of ARM gives u ur toe angle .
It u increase each by say 1mm (3.4rr-1fr) will widen track width and take some traction away from rear of car . Same applies to front of car the narrower it is the more traction it will generate .
My vta setup I would have to say is set up for all the chassis traction I can get mechanically
Rear:
278 springs
40wt oil
1.2-3hole with 0 rebound
Laid in all the way on tower and in hole 1 on arms ( more progressive spring softer at first and stiffer later)
1.5-2 deg of toe per side ( this is a vta thing when traction is up) normal is 3deg per
LL inner mounts with option camber link plates(1.25) in #3
Front
344 /45oil/1.2-3hole 0 rebound
LL
Shock position on tower #3 / #2 on ARM
Outer hole on steering nuckels
#10insert in position 3 farward all the way
Chassis
6cell nimh standard
Soft top deck
Rubber wings
1.5mm droop front
3mm rear
5.6rear
5.2front
I know this is a vta setup but if traction is low I would think it sould work on a tc car also
I have ran this setup outdoors and it made a lot of traction too much
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 11-19-2011, 08:47 AM   #8480
P2
P2's Avatar
Trader Rating: 15 (100%+)
Originally Posted by AOD View Post
Time to come back out to RWH and do some racing.
Originally Posted by InspGadgt View Post
Dude we're running 1/12th out at RWH! Come on out!
All I have left is my Photon, what tires are working at RWH? I might be able to swing by the track this Sunday as a spectator.
TopRacingUSA | Team EPIC | Thunder Power | OD Racing
P2 is offline   Reply With Quote
Old 11-19-2011, 09:11 AM   #8481
AOD
AOD's Avatar
Still using Sorex 36's at RWH I have a set with 1 run on it you can use. Season starts 2nd Sunday in January plenty of time to pick up a rebel. 2nd Sunday in Dec is a test n tune. Just pick me up a new 12th starting to build it as I type. Give me a call sucka!!!!!
AOD is offline   Reply With Quote
Old 11-21-2011, 10:38 AM   #8482
Luppi Stefano's Avatar
Steven Weiss, TOP Racing Europe, win a Genitin Trophy in Rome, Italy.
great Job Steven! thanks to Luca Magnocavallo(Genitin) and Cristiano Mossa(Framega) for this!
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 11-22-2011, 11:59 AM   #8483
TAMAK's Avatar
Trader Rating: 28 (100%+)
Hey guys, been a while since I raced my photon. I was looking to give it a fresh rebuild, and was looking at chassis options. I really like the exotek, and was wondering if there is any reason I shouldnt give it a try? I will mainly run on carpet, 17.5 (blinky) touring.
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 11-22-2011, 01:04 PM   #8484
Which chassis u have on it now? If its the old 6cell and u have a high bite track I would say yes to the ecotech. Or the latest top chassis the ecotech is a nice chassis but not sure it its anybetter than the others on carpet
Justin & Matt Lyons
a800s sanwa m12s
Old 11-24-2011, 05:45 PM   #8485
dfsc10's Avatar
Trader Rating: 22 (100%+)
hey guys im thinkin about getting this car or the xray 2012. how well does this car work? thanks.
Dakota Feely
Tekno RC | Pro-Line Racing | Hobby-Pros.com | Fastlane Graphix
dfsc10 is offline   Reply With Quote
Old 11-24-2011, 06:08 PM   #8486
stiltskin's Avatar
Trader Rating: 102 (100%+)
The car works great. Xray has always produced top of the line cars that work straight out of the box. They also demand a premium price for them. The Photon performs just as well with high quality parts, amazing customer support from TOP USA, and all at 2/3 the price of the Xray. I won our Halloween race on asphalt, came inside to the carpet track with an oil change and put a lap on the field. Our track has become 80% Photon. TOP must be doing something right.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 11-24-2011, 06:21 PM   #8487
Default car
+1 I agree completely.
mdhyams is offline   Reply With Quote
Old 11-24-2011, 07:14 PM   #8488
Send a message via Skype™ to justin w
TOP is the way to go i agree with this 100% I have 2 photons 1 just was to fun, so 2 is twice the fun!!!
justin w is offline   Reply With Quote
Old 11-26-2011, 10:18 AM   #8489
Bishop's Avatar
Sorry, but -1 to some of the above...
Bare kit 'is' cheap enough, but add in just the battery mounts and it's getting up there (not to even mention the stock kit screws are a joke), a few more options (gear diffs spring to mind, stock on many kits now), plus everyone wants to bin the stock chassis now for a narrow spec option, and there is your Xray money and then some.
And sorry again but I have proven several times now TOP parts 'are' right up there in pricing near Xray, maybe a shade cheaper on some bits, but it still makes it the second most expensive race chassis to maintain at best.
Lately there is also at least two other kit brands as cheap to buy, both ok cars (though to be fair the TC6 does not impress me much in stock form).
Is it a great kit though?, yeah to be sure, mine has steering to die for, it's also forgiving to drive, and seems to have a wide tuning window.
But having gear diffs that don't quite fit perfectly sucks (Yoko or SpecR made for the BD5), and there is really a half dozen bits the stock kits 'should' come with, so I'll sit on the reality side of the fence, and say it's no better or worse than a half dozen other cars out there.
Just a shame I'm so in love with the original Josh design, and it's so pretty in red, one of which may be gone soon though, and a CEFX or 411 starts looking real nice...
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 11-26-2011, 10:48 AM   #8490
sprintcarracer's Avatar
Trader Rating: 25 (100%+)
I agree with what Bishop has said.
The photon is an exceptional car and works great. It's a very good beginner car as it has work well for me for 2 years.
sprintcarracer is offline   Reply With Quote
