Old 10-11-2011, 07:31 AM   #8356
Originally Posted by Dragarcher View Post
There is no new car, there is a prototype that is being tested and no one used it at the iic only the tried and true Photon. Results varied but all are listed on the iic web site.
Sorry for ignorance... but where on the website is the results... Can't find anywhere...
Corally PHI/PHI 09 TEAM DRIVER
BMI DB12RR TEAM DRIVER
TOP
LRP TC SXX, LRP SXX Ver. 2, LRP X12 Octa, Futaba 3PKS Spektrum Module, Protform.
SOUTH AFRICA :)
PHI/BMI racer is offline   Reply With Quote
Old 10-11-2011, 08:24 AM   #8357
ME NEITHER !
thanks to locked for the link....start with 3k ??
The Hobby Shop,The Ohio RC Factory
T.O.P. Photon CRC XTI, XRAY T4 15 xray xb4 xb8e losi sct 2.0
insanity takes it's toll...please have exact change
bpalmer is offline   Reply With Quote
Old 10-11-2011, 08:33 AM   #8358
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Liverc.com > click on the live tab > Live racing information > View Broadcast > IIC Las Vegas >Click on the Results Tab
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Old 10-11-2011, 09:19 AM   #8359
Originally Posted by bkspeedo View Post
Larry,
Will you be posting your setup?
The setup I ran is the same as the normal setup I run except I had 60 fr 50 rear losi shock oil.
Full long camber links all the way around. Stock camber plates.
2mm shim under the front inner camber link.
no anti squat in the rear. Medium Low roll center blocks all the way around.
Everything else is the same
Old 10-11-2011, 09:47 AM   #8360
Thanks!!!!
TOP
SOUTH AFRICA :)
Old 10-11-2011, 05:15 PM   #8361
Trader Rating: 15 (100%+)
Default New guy needs some help
I just purchased my first Photon car. I need some assistance with a setup for this car for carpet and asphalt. Also looking for a gear setup for a Tekin 17.5 motor in blinky mode. What body works best? Do I need to upgrade anything on this car?
Mike
mdhyams is offline   Reply With Quote
Old 10-11-2011, 05:22 PM   #8362
stiltskin's Avatar
Trader Rating: 102 (100%+)
Mike
http://racerlog.com/wiki/T.O.P._Photon
Congrats on the car Mike. Hanulec has done a great job keeping track of all the info required for this car. Take a look here and you should answer alot of your questions. Depending on track size, you should start around 4.0 fdr for blinky. The Photon internal ratio is 2.0 so your math skills won't get tested too much. I like the P-37 body or the LTC-R. Good luck. If you need any help, this is the place to go.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 10-11-2011, 05:26 PM   #8363
Default thanks
I will take a look at that website.
Old 10-11-2011, 05:38 PM   #8364
Default Website
Ok I read this webpage and of course I dont really understand half of the info. The car i bought came with nimh chassis and a brand new lipo chassis. Also came with a spec-r gear diff and a stock gear diff and low friction belts. The person I bought it from said it has Jesse Starks mod setup from the Reedy race. I can't seem to find that setup.
Old 10-11-2011, 05:49 PM   #8365
J SiN's Avatar
Give it a run with the setup that it has on it and see what it needs and go from there.
I find the pro setups dont always work for everyone. well not for me
T.O.P. Racing Australia
R.A.B Hobbies
AVID Bearings
J SiN is offline   Reply With Quote
Old 10-11-2011, 08:46 PM   #8366
J Stark's Avatar
MDhyams: If you are looking for this set up, here you go. Welcome to the Photon family. Let us know how things go
J Stark is offline   Reply With Quote
Old 10-13-2011, 06:53 AM   #8367
J SiN's Avatar
whats the flex like on the new Photon EX Vs the Photon chassis's
R.A.B Hobbies
AVID Bearings
Old 10-18-2011, 12:01 PM   #8368
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Interested in trying one but I was told that these cars are a bit fragile. Are they? Or are they as durable as any other top line TC except you just can't hit the boards with it constantly?
YR4Dude is offline   Reply With Quote
Old 10-18-2011, 12:48 PM   #8369
odpurple's Avatar
I'm curious which tc will be ok if you hit the boards constantly?
The Photon is as durable as any of the other cars available, each one has it's weak and strong points
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 10-18-2011, 01:49 PM   #8370
Buckaroo's Avatar
I progressed from a TC3 to a TC5 to a TC6 to the Photon. I'd say that the Photon is hands down the toughest of the 4 cars that I've owned in the past year. Easiest to work on, too.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
