Old 09-12-2011, 11:39 AM   #8221
jdearhart's Avatar
Trader Rating: 14 (100%+)
Originally Posted by hanulec View Post
No clue.
When using them for rubber tire you must cut the "nub" below the threads in order to make ride height.
when I build shocks I have them measure 49.5mm from plastic shock bottom to top of threaded body without cap.
Thanks, but what I'm looking for is 28mm, 31mm, or ?? These shocks are amazingly smooth, and I'd like to use them on dirtoval car.
jdearhart is offline   Reply With Quote
Old 09-12-2011, 12:40 PM   #8222
odpurple's Avatar
The shock shaft measures 28.5mm in length.
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 09-12-2011, 08:42 PM   #8223
Send a message via Skype™ to justin w
Default right on!!!!!
Originally Posted by schmutz View Post
Photon wins the 2011 Germany Summerchamps in Hann.Münden
1st, 2nd, 9th in Modified
4th, 5th in 13.5
4th, 5th, 9th, 11th in 17.5
+ YouTube Video
BIG CONGRATS TOP GERMANY
justin w is offline   Reply With Quote
Old 09-12-2011, 11:21 PM   #8224
BoneCrusher's Avatar
Default Setup Help Please.
Just getting back into the indoor season so would like some advice from the Photon gurus. I ran this setup for a few months for 3 of our regional races during the winter season. It almost TQ’ed twice and I finish 2nd at our final race out of 50 drivers. I think it drives perfect except only with traction roll if I really pushed it hard when the grip came up. Funny thing was that someone told me he heard from Paul Lemieux that you can combat traction roll by instead of using harder springs, use softer springs. So I actually changed all four springs for the finals to one level softer and it ran great!
Anyways, I’m just prepping this car for next month and wondering what setup changes I can try to decrease traction roll but not lose corner speed. Please don’t tell me I need new parts.
Here’s the setup sheet. Hope you can read it. There’s a droop setting but I use up travel instead.
Thank you,
Ivan
T.O.P. Racing "Photon" 1/10 EP Touring Car-photon-setup.jpg
ARC R10, 12R5.1, Tamiya Mini, MTS FFv2 Pro, Exotek F1
carcar.ca
BoneCrusher is offline   Reply With Quote
Old 09-13-2011, 05:17 AM   #8225
hanulec's Avatar
Trader Rating: 23 (100%+)
Ivan - sway bars are like a spring - you can try disconnecting them. 306 rear spring is perfect. I'd play with the front spring and no bars.
Also -iif your next race is 1 month away - please replace those shock orings the week
of your race. I got lazy and didn't do that after letter the car sit for 1 month and the car didn't handle right.
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 09-13-2011, 08:03 AM   #8226
bkspeedo's Avatar
Good setup,
Minor things you can try; lower the front role center a bit, make it the same as the rear. If I'm reading your setup sheet correctly 4mm up travel is a bit excessive try 3mm all around. Also try lower rear shock mounting position 2. Rubber top deck, should give you more steering if needed.
Paul is correct, lowering your roll center and using softer springs will stop traction rolling.
You should try a rear gear diff as well, really makes the rear of the car rotate.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ ProtoForm ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 09-13-2011, 05:37 PM   #8227
Buckaroo's Avatar
Two questions:
  1. Where do I get the shims that go between the diff bearings and the bearing cams? Can't seem to find a part number cross reference or retailer with that listing. Yeah, pulled a bonehead and lost 2 of the 4.
  2. How much lateral play is prefered between the center drive bulkheads and the pulley/spur/pulley combo on the layshaft?
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 09-13-2011, 05:57 PM   #8228
RC MARKET's Avatar
Originally Posted by Buckaroo View Post
Two questions:
http://rcmarket.com.hk/index.php?cPath=51_98_249_250
RC MARKET is offline   Reply With Quote
Old 09-13-2011, 06:10 PM   #8229
locked's Avatar
Two questions:
  1. Where do I get the shims that go between the diff bearings and the bearing cams? Can't seem to find a part number cross reference or retailer with that listing. PA-101215-C-1 Yeah, pulled a bonehead and lost 2 of the 4.
  2. How much lateral play is prefered between the center drive bulkheads and the pulley/spur/pulley combo on the layshaft? Very little. I'd say just enough so the bearings don't bind at all.
If the shims don't go beyond the edge of the layshaft, but are very close to the edge, you should be fine
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 09-13-2011, 11:14 PM   #8230
Thanks Hanulec!
So disconnecting the front 1.4mm sway bar will soften the front right? Would it be better to go thinner before disconnecting?
Shock o-rings is that the 30 or 40 kind?
I appreciate your help!
Ivan
Originally Posted by bkspeedo View Post
Good setup,
Thanks bkspeedo!
Does lowering the front role center allow the car to 'roll into the turn' more? What would making the up-travel 4mm to 3mm do? Wouldn't lowering the rear shock mount from 4 to 2 stand up the shocks a bit therefore decrease side bite or rear traction in a turn? Rubber top deck is like 2 mm instead of 3 right. That make it less rigid right?
I have the gear diff available but just haven't messed with it yet.
Sorry for the further questions.
Thanks!
Ivan
carcar.ca
Old 09-14-2011, 01:33 PM   #8231
Photon takes top two spots in 17.5 non-ramping at last weekend's 2011 XRAY Challenge held at SpeedWorld Raceway & Hobbies in Roseville, CA.
Also, EJ took 2nd in open mod behind Paul Lemieux.
T.O.P. Racing "Photon" 1/10 EP Touring Car-img_1256.jpeg   T.O.P. Racing "Photon" 1/10 EP Touring Car-img_1259.jpeg
James "Nel" Nelson
SpeedWorld Raceway & Hobbies | DesotoRacing.com | R1 Wurks
neltime64 is offline   Reply With Quote
Old 09-14-2011, 02:48 PM   #8232
hanulec's Avatar
Great job fellas..
Old 09-14-2011, 03:02 PM   #8233
locked's Avatar
Great job fellas..
Indeed. Well done guys!
Dave Locke
Old 09-14-2011, 07:17 PM   #8234
yokemad's Avatar
Uuups
http://kkchung.pixnet.net/album/phot...4-dsc_9385.jpg
yokemad is offline   Reply With Quote
Old 09-14-2011, 07:46 PM   #8235
hanulec's Avatar
Originally Posted by BoneCrusher View Post
Thanks Hanulec!
Ivan
removing the cars will make which ever end softer. you can try removing them one at a time -- or just both at once.
40 degree. other shock building tips here: http://racerlog.com/wiki/T.O.P._Photon#Shocks
SEO by vBSEO 3.5.0
