Old 07-21-2011, 06:19 PM   #7981
stiltskin's Avatar
Trader Rating: 102 (100%+)
Originally Posted by team_tamale View Post
How many of you to owners would be interested in an aluminum version of the front piece of the steering bellcrank? I've had a couple of requests for this, just wondering if there is enough interest to justify making some up. Post here, pm me, or email to teamtamale@tx.rr.com
I haven't had an issue with this piece yet, but I've seen a few go on other cars.
I'm sure you would have plenty of interest.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 07-21-2011, 06:47 PM   #7982
vabroom's Avatar
Plus 2 for me!
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 07-21-2011, 06:48 PM   #7983
Trader Rating: 66 (100%+)
Send a message via AIM to joey
I would take 2..
=Joe Wright=
joey is offline   Reply With Quote
Old 07-21-2011, 06:51 PM   #7984
hanulec's Avatar
Trader Rating: 27 (100%+)
Sounds like a winner Larry.
Are they done yet?
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 07-21-2011, 07:11 PM   #7985
J SiN's Avatar
just ordered my car
now the waiting game.
J SiN is offline   Reply With Quote
Old 07-21-2011, 07:29 PM   #7986
vabroom's Avatar
If you have a couple ready, give to Hanulec, first since he has the nationals coming up and they will be better advertise there. I'm just a club and practice boy.
Old 07-21-2011, 07:46 PM   #7987
locked's Avatar
X2 for me as well, yeah! It's a part I've been wanting a stronger version of for a while. I've only broken one once, but I've seen a few others break it and it sucks having to buy the whole bellcrank assembly just for that one piece.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 07-21-2011, 08:04 PM   #7988
Professor's Avatar
if you are willing to ship to australia im sure there would be interest here also
i personally would take 4 (not that ive had an issue to date)just nice to have
VBC RACING AUS--HOBBYWING--MAD GRAPHICS--BITTY DESIGN
Professor is offline   Reply With Quote
Old 07-21-2011, 08:31 PM   #7989
Send a message via Skype™ to justin w
Default photon on solaris hardmounts
hey guys was wondering if any one has set up for rubber/asphalt 21.5 blinky on solaris hard mounts on med grip track outdoor generally track will temp at bout 85deg F then climb to bout 130 on sunny warm afternoon, i am chassing the rear end coming aroung off power right now set up is pretty much as directions showed 37.5 shock oil front and rear and ran 2 deg rear camber also roll center is all the way up marks up in front marks down in rear.
any help is much appreciated
justin w is offline   Reply With Quote
Old 07-22-2011, 12:21 AM   #7990
Default Chassis
Can anyone eksplain to me , why all is choosing an Exotek or EJ chassis , instead of the stock LIPO chassis , witch come in different hardness , Ex stiff, stiff and moderate.
Andy
Sweden
HB-forever is offline   Reply With Quote
Old 07-22-2011, 12:35 AM   #7991
bkspeedo's Avatar
With it being that warm on the track you may want to think about thicker oil up front. Silicon oil viscosity drops almost in half at 130-140 deg F. You car may be OK at the start of the race but half way thru the oil is thinning which will increase over-steer. Here's a good article to read,
http://www.twf8.ws/php/tip/shock.html
You want to lower your roll-center not raise it. Try Medium hing pin blocks front and rear with notch up in front and notch down in the rear of the car. Top camber link slightly angled down to center of car in front compared to lower a-arm. Down slightly to parallel in rear compared to lower a-arm.
Try running 344 springs up-front and 306 in the rear.
Look at some of the setups on Hanulec's Wiki page.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 07-22-2011, 08:45 AM   #7992
MikeXray's Avatar
Trader Rating: 73 (100%+)
Andy
Sweden
Its is a few mm narrower and has a different flex characteristic, it seems to be working well on asphalt and carpet for everyone that has switched to it.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 07-22-2011, 08:47 AM   #7993
MikeXray's Avatar
Yes please If you do make it, don't copy the stock part exact, because you need to dremel the front part of it (in front of the ball studs) a bit to make it clear the pulley if you choose to run the forward position. There is more material there than needed.
Old 07-22-2011, 08:59 AM   #7994
And the EJ and exotek are the same or what
thanks
Andy
Old 07-22-2011, 10:01 AM   #7995
MikeXray's Avatar
thanks
Andy
I have not tried the exotek myself, it has a little more flex and offers a 2nd servo mounting position, other than that they are similar.
