T.O.P. Racing "Photon" 1/10 EP Touring Car >
Like Tree9Likes
Old 07-17-2011, 12:07 PM
  #7936
Luppi Stefano's Avatar
Originally Posted by odpurple
If you want to try some different pistons check out the T.O.P. optional shock pistons. Machined with either two or three 1.0 or 1.2mm dia holes
unfortunately I can't use the TOP piston...because they never arrived in Italy...
Luppi Stefano is offline
Old 07-17-2011, 12:44 PM
  #7937
Well,today Race on Low Grip moquette surface...
TQ + Faster Laps + Win
but car isn't perfect...
after the race try EJ narrow Chassis....WOW!
more Steering, more faster on curve and more rear Traction
this chassis is Fantastic!
Compliments to EJ and TOP racing USA
Old 07-17-2011, 12:48 PM
  #7938
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
That'd good news..did you have the old 6cell chassis?
what was the thickness beween two chassis?
OVA is offline
Old 07-17-2011, 01:30 PM
  #7939
EJ Chassis had same thickness to 6cell, 2.5mm
Old 07-17-2011, 02:06 PM
  #7940
OVA
OVA's Avatar
Thanks...I have the Exotek chassis..and it is alittle thinner than EJ by .25mm
OVA is offline
Old 07-17-2011, 10:22 PM
  #7941
Groomie's Avatar
Default Photon
Hi all
Ran the photon for the first time on the weekend was quite impressed with the car. The track was indoors and carpet tiles i was lacking a little steering on entry to corners was running pretty much kit except i had a tight ball diff in the front and gear diff in the rear any ideas on getting that extra steering would be great
Regards Mark
Groomie is offline
Old 07-17-2011, 10:34 PM
  #7942
danjoy25's Avatar
Trader Rating: 38 (100%+)
3 things I would change to get more steering:
Harder front springs
shorter wheel base
Less rear toe
I'll see you on Sunday so you can check out the TQ car LOL! LOL! LOL!
danjoy25 is offline
Old 07-17-2011, 11:06 PM
  #7943
Groomie's Avatar
shorter wheel base
Less rear toe
Thanks Dan I will be studying you car for sure
See you Sunday morning
Groomie is offline
Old 07-18-2011, 12:01 AM
  #7944
Professor's Avatar
Originally Posted by Groomie
Hi all
Regards Mark
x ray 6 deg caster blocks as well,btw what front springs were you using ???
Professor is offline
Old 07-18-2011, 02:33 AM
  #7945
Groomie's Avatar
Thanks i was using kit 344 springs on the front 306 on the rear
I am also have a slight rear toe issue cant seem to get it the same both sides without using different shims. I have been told this is common any ideas its only out by .5 - .7 mm i am using the exotek chassis
Regards Mark
Groomie is offline
Old 07-18-2011, 02:35 AM
  #7946
barts71m's Avatar
Trader Rating: 34 (100%+)
Regards Mark
Grab a Yokomo...keefy had awesome steering
barts71m is offline
Old 07-18-2011, 03:40 AM
  #7947
mazmo's Avatar
Regards Mark
I like to use 324 springs all round and less rear toe, about 2.5 deg.
No sway bars, shorten camber links instead.
This frees up the car alot and together with 6 deg x-ray hub / knuckles improves steering & rotation.
I also had the rear toe issue. Never seemed right on the set up station but the car was fine on the track.
When I tried to even up with shims would steer different left to right ... took shims out & car was fine again.
If car is behaving fine, I would leave it.
Cheers
Alan
mazmo is offline
Old 07-18-2011, 03:59 AM
  #7948
hahahahahahahaha
Keefy win!
Wylie27 is offline
Old 07-18-2011, 04:08 AM
  #7949
Rod M's Avatar
shorter wheel base
Less rear toe
My current setup shortens the wheel base and has less rear toe,
qualified 3rd (5th finish) at 2010 nats
qualified and finished 2nd at 2011 summer nat,
File Type: pdf
Rod M is offline
Old 07-18-2011, 04:21 AM
  #7950
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
Hi all
Regards Mark
Make sure you have enough mechanical steering in the car too. Remove the link from the servo to the steering rack and see if the three is the same side to side. If not, use a dremel to remove whatever is in the way. Two parts to look four-wheel
1- the "nub" on the steering block - remove it
2- the aluminum chassis bulkheads may hit the steering rack
hanulec is offline
