Old 07-06-2011, 08:57 PM   #7861
Mike Haynes's Avatar
Hanulec's mod car has awesome written all over it, do exactly what he says Please just drive better
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 07-06-2011, 09:21 PM   #7862
hanulec's Avatar
Trader Rating: 27 (100%+)
but my stock TC is SO MUCH BETTER (or at least I can drive it better....)
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 07-07-2011, 10:13 AM   #7863
Trader Rating: 76 (100%+)
Anyone have any advice on sidebite? I'm looking for some in the low speed corners. The sweeper at the end of the straight seems to be ok for some reason, maybe the spoiler has more downforce on it then (straight is at least 120 feet long). In the infield the car feels loose, and I have 3 degrees of toe. Should I make the link longer, or maybe adjust the wheelbase?
MUDVAYNE is offline   Reply With Quote
Old 07-07-2011, 10:43 AM   #7864
bkspeedo's Avatar
Try narrowing the rear of the car. Most people have a 1mm shim behind the Rear\Front hing pin holder. Try .5mm shim and adjust the Rear\Rear spacers accordingly.
If this does not work a longer link would be something to try.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design ~ Helix Designs
5280 Raceway
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 07-07-2011, 12:50 PM   #7865
hanulec's Avatar
Is it only side bite or is it traction everywhere? When grip outdoors sucks we reduce the number of top deck screws to 4 (rem insides) and loosened the wings or put orings under Tue wings.
If it is really side bite then u need more camber gain. Go to a lower shim on the rear inside camber link or a larger shim on the rear hub. I'd adjust the rear hub first.
You could also play wth adding more rear toe.
Old 07-07-2011, 02:14 PM   #7866
Trader Rating: 20 (100%+)
Default Camber links
What are the advantages of running the longer camber links? I run a temp parking lot track sprayed with sugar water.
I also am planning on running the narrow chassis with duel gear diffs. Are there any good tarmac setups out there for this setup.
TLR 22
Desc410r
zleader_99 is offline   Reply With Quote
Old 07-07-2011, 02:23 PM   #7867
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
Longer camber links generally give you more overall traction but make the car less responsive.
Dual gear diffs will make the car easier to drive but will not be as fast as spool/gear diff setup.
If you go back a couple pages you'll find the setup I posted which is Larry's Carpet setup with a list of changes that we make to run asphalt.
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 07-07-2011, 03:53 PM   #7868
RC MARKET's Avatar
RC MARKET is offline   Reply With Quote
Old 07-07-2011, 04:19 PM   #7869
OVA
OVA's Avatar
Trader Rating: 78 (100%+)
hear ya go
Start with this setup with the fallowing changes 344 front springs, 40 wt oil and 2* front and rear camber. I also run all my top deck and wing screws loose to get more flex out of the car. Been Running this setup at Jackson all year with very good results when the track is both med and high bite.
Light weight arms will also help the car some. I also run a yokomo gear diff w/ 20 weight shocks oil
OVA is offline   Reply With Quote
Old 07-07-2011, 05:52 PM   #7870
Default Thanks
Thanks for all the help..
TLR 22
Desc410r
Old 07-07-2011, 07:30 PM   #7871
bigbank66's Avatar
Hey Ron.... whats the advantage of the anti squat on the rear arms??? can u explain what the off set do for the handling??? Thanks
bigbank66 is offline   Reply With Quote
Old 07-07-2011, 07:31 PM   #7872
bigbank66's Avatar
An also expalin the angle of the rear arms???
Old 07-07-2011, 07:51 PM   #7873
hanulec's Avatar
The anti-squat helps decrease rear traction, and improve steering. If your track is very low bite then you might want the rear arms level/flat, or to even have some pro-squat (the arms angled the opposite direction)
by angle, do you mean rear toe? the 1mm/3mm combo is just the kit standard. it seems to work well everywhere. in modified racing we have been trying more and less rear toe-in to get the cars to behave better.
Old 07-07-2011, 07:51 PM   #7874
Anti squat helps with steering going in the corner and also rear traction/drive out of the corner
I'm not sure what you mean by off set?
Again not really sure what your talking about here. Rear toe maybe? If so rear toe gives the car stability and rear traction. However to much toe can actually take traction away.
Old 07-08-2011, 06:07 PM   #7875
Default exotech chassis
I am trying to do the optional servo install, the paper work says the xray servo saver works the best. I have the kingshead steering crank and dont want to Danny the Dremel off the arm. I was going to use the orignal arm as another Photon driver sudjested. However I dont have any left.
Is xray servo saver a steering crank? If so does anyone have a part number? Sorry if this has been covered. I am putting a order together and want to sort this out before I submit.
TLR 22
Desc410r
