T.O.P. Racing "Photon" 1/10 EP Touring Car >
Like Tree9Likes
Old 06-21-2011, 02:11 PM
  #7801
locked's Avatar
I thought only the team guys had the prototype narrow chassis. I would have ordered one long ago, had I known.
I have an exotek on the way if the post office here ever ends their strike.
OD or EJ, if it's still possible to get the prototype chassis, could you let me know?
OD, I keep buying TOP parts locally for convenience, so I still haven't managed to get those low friction belts from my order back in January. If I can order the narrow chassis, can you include the belts? If I can't get the chassis, can you just send me the belts? I know it will probably be another 6 months or I'll end up forgetting about them entirely.
locked is offline
Old 06-21-2011, 04:06 PM
  #7802
Luppi Stefano's Avatar
Originally Posted by vabroom
Luppi, here you go:
http://www.rctech.net/forum/9254207-post7744.html
There's no part number since it's EJ's own design. Need to call or email TOP Racing USA.
thanks for explanation!
Luppi Stefano is offline
Old 06-21-2011, 05:23 PM
  #7803
odpurple's Avatar
Dave,
Either way, no problem. Send us an email and I'll get right on it.
[email protected]
OD
odpurple is offline
Old 06-21-2011, 05:26 PM
  #7804
locked's Avatar
Originally Posted by odpurple
Dave,
[email protected]
OD
You rock sir. Thank you.
locked is offline
Old 06-21-2011, 05:41 PM
  #7805
Are there plans for Equalized Corner Speed (ECS) Drive Shafts for the TOP from TOP?
ElliotCanada is offline
Old 06-21-2011, 05:55 PM
  #7806
ChadB.'s Avatar
Trader Rating: 21 (100%+)
Anybody got a FDR for a large track asphalt track? The motor is an LRP 5.0 and the speedo is a LRP SXX V2.
ChadB. is offline
Old 06-21-2011, 05:58 PM
  #7807
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
I don't know anything "official" about this, but I do know what you can do right now! I would recommend you not wait for the unknown and pick up some of my Side Piece Racing Mira Outdrives -- http://www.sidepieceracing.com
8.0 FDR. Should come off the track about 192 degrees. I've run upto a 7.2 FDR but the motor went up to 220 degrees. Using a 'high' FDR + more timing is probably the answer.
hanulec is offline
Old 06-21-2011, 06:07 PM
  #7808
ChadB.'s Avatar
Thanks Mike, what's a good speedo temp too?
ChadB. is offline
Old 06-21-2011, 06:15 PM
  #7809
hanulec's Avatar
didn't turn off
i'd run a fan on the speedo if i was u...
hanulec is offline
Old 06-21-2011, 06:29 PM
  #7810
ChadB.'s Avatar
Originally Posted by hanulec
didn't turn off
Thanks again Mike, I will look into getting one.
ChadB. is offline
Old 06-21-2011, 06:44 PM
  #7811
L.Fairtrace's Avatar
Trader Rating: 24 (100%+)
Im running a ssx tc spec v2 and I'm running a 5.5 octo wind at 0,4,5,4 with the 4 dot at 7.22 FDR and the setup is very smooth and Fasssst.
L.Fairtrace is offline
Old 06-21-2011, 07:01 PM
  #7812
danjoy25's Avatar
Trader Rating: 38 (100%+)
Just finished converting to a narrow chassis. Can't wait to try it.
danjoy25 is offline
Old 06-21-2011, 07:27 PM
  #7813
hanulec's Avatar
I just wanted to give a shout out to my homie Jerry Perez for his TQ (and fail) in 17.5T at the ROAR Region 2 Asphalt race this past weekend. Jerry's mechanical issues during the first lap (radio issues) caused an interesting result for the rest of the field. Also in the battle were local fast guys The Goat (4th), Arvin Nano (5th), and Rob Estep (7th) all running the Photon. Ralph Morella BQ'd the event and drove home to a convincing win, even recording a quicker fast lap then the A-main winnner (Cuffs).
In the 13.5T class I had an good battle with a few folks during the 6m after a bad first lap but battled back to nearly end up on the podium -- I think I needed another lap or two. Jerry also put his car into the show but again continued to experience radio drama, sorry buddy.
Finally, in Modified TC myself, Mark Unrath and Bill Dove all put our Photons into the A-main (ok, there was only one main but..). Thankfully I think I stumbled upon a setup during Sunday testing that might help yield a different result next time...
Unfortunately Larry couldn't make the race otherwise the top positions in many of these classes might of had another look. I guess we will just have to wait for the upcoming ROAR Asphalt Nats to see what the finals look like -- but I suspect we will see a few local Photons at the TOP.
You can read me at -
- http://www.redrc.net/2011/06/roar-re...ved-regionals/
- http://www.rctech.net/forum/racing-f...up-race-9.html
hanulec is offline
Old 06-21-2011, 08:49 PM
  #7814
ChadB.'s Avatar
Hey Larry, your speedo doesn't get that warm with that much boost?
ChadB. is offline
Old 06-21-2011, 08:54 PM
  #7815
Trader Rating: 17 (100%+)
Chad! I will be at TZ sat. Hope to see you there with your top! It will be my first time taking mine out since nats!!! time to blow off the dust and see if i can still drive
Mr.A Morris is offline
