Old 06-17-2011, 02:32 PM   #7771
XxRONNxX's Avatar
Thumbs up
7
Originally Posted by E.J. Evans View Post
Attached is my 2011 Reedy Setup. It's quite a bit different from my 2010 setup. I would imagine 80% of the tracks the 2010 setup would be better off.
The first day of the Reedy I used my 2010 setup and it worked fairly well. My lap times were decent and on pace. However as the grip came up my lap times stayed the same and everyone went faster. After feeling other racers cars, I concluded my car was under sprung and under dampened for the high grip level.
Lap times were a touch faster and the car was much easier to drive. It also finished the turn a lot better than my previous setup. I just needed to drive better.. LOL
Some things to note on the setup:
- 1.0mm 3 hole pistons
- 1.0mm hole drilled in the top of the shock cap
- After filling the shock, I seal the bladder with the piston all the way down. Due to the hole in the cap there is no rebound in the shock.
- Outside shock hole on the front arm
- 367 front and 324 rear
- Neg 2.5 Camber on the setup gauge, about Neg 1.5 on the wheel.
- Outside hole on rear hub
Anyway give it a shot. Part of the fun of racing is trying different things!
I tried to duplicate E.J.'s setup at the Reedy and ran something close to it. I shaved almost a whole second off my fast lap. Thanks E!
Ron D.
XxRONNxX is offline   Reply With Quote
Old 06-17-2011, 02:47 PM   #7772
wayne breault's Avatar
Thanks E. J. Can't wait to try it. Wayne
wayne breault is offline   Reply With Quote
Old 06-17-2011, 04:20 PM   #7773
hanulec's Avatar
Trader Rating: 27 (100%+)
Wayne - EJ has a high grip setup and was running mod. I'd recommend the setup the goat posted a few pages back.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 06-17-2011, 06:06 PM   #7774
odpurple's Avatar
Originally Posted by hanulec View Post
Wayne - EJ has a high grip setup and was running mod. I'd recommend the setup thevhoat posted a few pages back.
I think he means the setup "the Goat" posted
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 06-17-2011, 06:13 PM   #7775
OVA
OVA's Avatar
Trader Rating: 77 (100%+)
Mike is this what you are talking about ..Page 514 posted# 7709
OVA is offline   Reply With Quote
Old 06-17-2011, 06:19 PM   #7776
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
Originally Posted by Ron Goetter View Post
http://www.racerlog.com/w/images/3/3...up_11-6-10.pdf
Start with this setup with the fallowing changes 344 front springs, 40 wt oil and 2* front and rear camber. I also run all my top deck and wing screws loose to get more flex out of the car. Been Running this setup at Jackson all year with very good results when the track is both med and high bite.
Light weight arms will also help the car some. I also run a yokomo gear diff w/ 20 weight shock oil
Yes this is the post my none typing Friend is referring too......
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 06-17-2011, 06:42 PM   #7777
Thanks for getting me on the right set up. Do you know what size shim I should use for the battery brace? Thanks
Old 06-17-2011, 06:58 PM   #7778
hanulec's Avatar
dam cell phones. thx OD & Goat
Old 06-17-2011, 07:22 PM   #7779
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
I never should have taken resume writing advice from FJ. No wonder I ended up working as a stripper.
Why don't we endurance race more often?
Greg Sharpe is offline   Reply With Quote
Old 06-18-2011, 06:31 AM   #7780
MAD916's Avatar
I have been running EJ's setup with his narrow lipo chassi back at home since the Reedy Race and it is working awesome. both at our track with moderate grip when not sprayed and also last weekend at a parking lot race bumpy low-grip, I through in a mod motor and ended up taking 2nd in Mod Sedan.
The setup with the shock mod, and the dampening/spring rates/med high roll center.... great car..
Hey EJ......... Y.G.M.
Timezone Raceway Park " on-road outdoor european style road course.
Timezone II 60'x100' indoor carpet track. Host of the ROAR 2011 Carpet Nat's.
Timezonehobbies.com your new source for online RC products.
MAD916 is offline   Reply With Quote
Old 06-18-2011, 09:52 AM   #7781
Bishop's Avatar
Did anyone else hear/see, rumor is Team Associated have a gear diff for the TC6 in the works, possibly be a couple of month away, could be interesting to have another gear diff that may work in the Photon, being TA it could be cheap as well.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 06-19-2011, 05:09 AM   #7782
hanulec's Avatar
Ain't a rumor. The only question is when will it be available (and is it any good)
Old 06-19-2011, 08:17 PM   #7783
OVA
OVA's Avatar
Okay Guy..feedback
How did the Exotek Photon chassis work out for ya?
Old 06-19-2011, 08:19 PM   #7784
bigbank66's Avatar
Fellas i got to keep it real.....i have be running the Evo verison of the Photon an its a nice design....but i just went back to the stock kit version an wit E.J. set-up an the car is Ballistic....TOPS is the Shizzzz....Props to E.J....he told me not to try the other version....Im a beliver now an back home E.J....ill be down at nor-cal more often to get some good racing inn...
bigbank66 is offline   Reply With Quote
Old 06-19-2011, 09:06 PM   #7785
TeamWTF's Avatar
I'm in the process of changing the servo around. Just double sided in place at the moment (To check fit and mark holes for servo posts) and it looks much better. I run the hobbywing 120a with the 4 cap board so space is an issue with the old setup. I look forward to running the receiver on the deck!
Hopefully some new chassis plates land in Aus soon for us to try (Exotek)
T.O.P. Racing Australia www.topracing.net.au
TeamWTF is offline   Reply With Quote
