Old 06-13-2011, 08:55 PM   #7741
bkspeedo's Avatar
Originally Posted by J Stark View Post
Set up sheet attached. Sorry for the delay. Hanulec, I know you might have been joking with the RC fame post, that is so not that case at all. Please don't think that is where I'm coming from, it's actually completely the opposite.
A couple things to note*
Tamiya shocks with 3 hole piston. Solaris tires using Fx2 and 15 minute dry time. Cleaned with Simple Green before application of Fx2. LRP SXX V2 Throttle profile #3, Drag brake #5. Radio settings: Throttle EXP -17%, Brake EPA -82%. Regular weight LTC with wing mounted in back position. No alloy parts on car. Yokomo gear diff using Kyosho 1000 oil. Titamuim screws everywhere except for top deck.48 pitch gears.
How are you setting droop? Noticed 6 front and 5 rear, are you using drop blocks, if so where are you measuring on the arm? Or is this over ride height?
You did not mark the front diff section, I'm assuming you were using a Spool?
This is quit the different setup, I would never have thought about 324 front springs and such a high roll center. Did you feel this gave the car more steering or was a lower roll center just to much for the traction?
What chassis where you using?
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 06-13-2011, 09:40 PM   #7742
J Stark's Avatar
bkspeedo: Yes, I set droop with the car on blocks and use standard droop gauge and measure off the very end of the arm to get a 6mm front and 5mm back measurement. For the rear, I take the hub carriers off and that allows you to measure at the end of the arm which I think is very important to note and thanks for taking notice on that.
Standard TOP spool in front
The reason for the roll centers being at High/low position is because I was using the TOP lipo 2.25 chassis which is discontinued now. The higher the roll center, the flatter the car stays and it becomes more responsive.
Hanulec: all good
J Stark is offline   Reply With Quote
Old 06-14-2011, 09:07 AM   #7743
Trader Rating: 17 (100%+)
Originally Posted by OVA View Post
Thanks you Mr Stark
Shall I address you as "Mr. Stark" at the track now? You fast guy!
Art
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 06-14-2011, 09:15 AM   #7744
Lets try this agian,Here are pics of the narrow chassis.....
T.O.P. Racing "Photon" 1/10 EP Touring Car-img_0172.jpg   T.O.P. Racing "Photon" 1/10 EP Touring Car-img_0173.jpg   T.O.P. Racing "Photon" 1/10 EP Touring Car-img_0174.jpg   T.O.P. Racing "Photon" 1/10 EP Touring Car-img_0176.jpg   T.O.P. Racing "Photon" 1/10 EP Touring Car-img_0175.jpg
Team Green Racing
LemonHead motorsports
TOP Racing
Doug Lemmons is offline   Reply With Quote
Old 06-14-2011, 09:27 AM   #7745
Bishop's Avatar
Am I imagining it, or have you shaved a little out of the inside of the top deck and shimmed the spur a little closer for belt alignment with the yoko diff?.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 06-14-2011, 10:36 AM   #7746
hanulec's Avatar
Trader Rating: 23 (100%+)
I used one more 10x12x0.2mm thick shim on the pully side to keep the chaasis from eating the diff
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 06-14-2011, 11:31 AM   #7747
Luppi Stefano's Avatar
I use 1.3mm shim on Pulley side and 0.6mm on other side
No problem with rear Rogbone and Blade
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 06-14-2011, 12:54 PM   #7748
I did not shave spur,Did not shave chassis I did cut the outdrives on the diff so I could use the top blades...just shimmed the diff over and it works great...This chassis works really good,I have never had a car that changes directions as fast as this car does...It made the car very carvy...It is a EJ design.The last time I saw him he had a few left..Doug
Team Green Racing
TOP Racing
Old 06-14-2011, 06:08 PM   #7749
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
Okay Mike
it is all done .ready to ROCK......Exotek Photon
T.O.P. Racing "Photon" 1/10 EP Touring Car-exotek-photon-001.jpg   T.O.P. Racing "Photon" 1/10 EP Touring Car-exotek-photon-002.jpg
OVA is offline   Reply With Quote
Old 06-15-2011, 09:36 AM   #7750
jdogger1's Avatar
Cool Scott Kimbrough leaves Top Racing!
Check out this story on Scott Kimbrough...
http://rcinsider.com/?p=12637
www.rcinsider.com
jdogger1 is offline   Reply With Quote
Old 06-15-2011, 02:18 PM   #7751
odpurple's Avatar
The TMZ of RC Racing
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 06-15-2011, 02:25 PM   #7752
RC MARKET's Avatar
Okay Mike
Nice Car !
RC MARKET is offline   Reply With Quote
Old 06-15-2011, 03:47 PM   #7753
OVA
OVA's Avatar
Originally Posted by RC MARKET View Post
Nice Car !
Thank you
Old 06-15-2011, 03:50 PM   #7754
gearhead1962's Avatar
Nice, I will have to hunt me an EJ
gearhead1962 is offline   Reply With Quote
Old 06-15-2011, 03:57 PM   #7755
vabroom's Avatar
Thank you, Jesse, for you RROC setup. Now we just need EJ's setup.
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
