Old 06-11-2011, 06:58 PM   #7711
hanulec's Avatar
Trader Rating: 23 (100%+)
Originally Posted by MUDVAYNE View Post
Sweet, thanks Ron.
Hopefully Ron didn't give away all of the secrets . That setup is really good for 17.5 or 13.5.
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 06-12-2011, 02:32 AM   #7712
Trader Rating: 54 (100%+)
Originally Posted by Doug Lemmons View Post
Heres a couple of pics of the EJ design narrow chassis that I used at the Reedy Race........And WOW what a improvement!!
pics turned out great
Jamison R is offline   Reply With Quote
Old 06-12-2011, 02:56 AM   #7713
What pictures ???????????????????????????????
johnsen-dk is offline   Reply With Quote
Old 06-12-2011, 10:54 AM   #7714
Dan
Dan's Avatar
Trader Rating: 40 (100%+)
Anyone have pics of the USA spec chassis? Just curious how different it is over the standard Photon chassis.
My local tracks ONLY carry TC6 and Photon parts so I'm somewhat deciding between the two.... Just curious if there are any other TC6 owners in here and what are there thoughts.
Dan is offline   Reply With Quote
Old 06-12-2011, 01:12 PM   #7715
Trader Rating: 75 (100%+)
You have a pm. I just traded a guy at my local track a brand new/half assembled TC6 for a Photon with only 5 weekends on it. The quality of the Associated kit sucked that bad.
MUDVAYNE is offline   Reply With Quote
Old 06-12-2011, 05:41 PM   #7716
hanulec's Avatar
Hi Dan -
The 'USA Spec' kit is the same as the Limited Edition kit as it includes a set of spare arms, hubs and knuckles.
http://racerlog.com/wiki/T.O.P._Photon#Overview
The weakest part of the base Photon kit is the screws. I'd highly recommend swapping out the 3x6mm FH screws with the parts I have listed on my wiki - http://racerlog.com/wiki/T.O.P._Photon#Screws
Since coming over to run the TOP from years of XRays (T2'008, T2'009, T3) I'm impressed with the car's corner speed and overall handing. The base setup that Larry created 2+ years ago works super well from high traction carpet (Snowbirds) to medium grip outdoor asphalt with only minimal changes (the ones The GOAT mentioned on the prior page...).
Old 06-12-2011, 08:51 PM   #7717
mickrcarver's Avatar
Trader Rating: 98 (100%+)
what pinion/spur combo are you guys running on the photon on rubber tire,on a large asphalt track in blinky mode 17.5?
www.ovrccc.com
www.speedybillsrc.com
mickrcarver is offline   Reply With Quote
Old 06-12-2011, 09:06 PM   #7718
hanulec's Avatar
pinion depends upon motor and timing. but the spurs we've been running are at --
http://racerlog.com/wiki/T.O.P._Phot...SPEC_ESC_Class
in not so many words -- you'll be running big gears. stock up for 45t to 52t. don't forget to put a good fan on that motor (and wire it directly to the battery +/-)
Old 06-12-2011, 10:10 PM   #7719
bkspeedo's Avatar
I run a 96 tooth spur gear it covers running blinky and w/ timing.
17.5 blinky try FDR's in the range of 3.7 - 4.2. It really does depend in the motor and driving style. Make sure to turn up the timing on the motor.
I run a Ballistic with timing at 45deg (3 ticks above 0\N). FDR for this motor on a large (> 100' X 60') open flowing track would be 3.8 or 3.9.
As always set gearing and timing on motor, run for 3 minutes, check temp. As Hanulec mentioned use a heat sink with a fan attached or a fan mounted to the chassis behind the motor.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ ProtoForm ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 06-12-2011, 10:15 PM   #7720
hanulec's Avatar
Congrats to Michael Spiering for making the pro stock show at this last weekends ETS race..
http://ets.redrc.net/2011/06/champio...st-201011-win/
Old 06-13-2011, 10:15 AM   #7721
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
Guess its Time to do a complete Rebuild
T.O.P. Racing "Photon" 1/10 EP Touring Car-photon-chassis.jpg
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 06-13-2011, 11:13 AM   #7722
vabroom's Avatar
JasonC, Exotek is already out of stock on these chassis. Can you tell me if you can use the medium wings with this chassis? I notice that the mounting holes for the medium and hard wings are missing.
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 06-13-2011, 11:39 AM   #7723
Luppi Stefano's Avatar
no, look this link
http://www41.instantestore.net/merchant10762/pd-exp.cfm
first series of Chassis has excess surface texturing, called B Grade, low price.
now arrive "second" series A Grade
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 06-13-2011, 12:08 PM   #7724
gearhead1962's Avatar
Question for the Nor Cal guys. Whats up with EJ's narrow chassis? Is that something that is still a prototype? Liking that exotek chassis but would prefer EJ's so I can steal his set ups
gearhead1962 is offline   Reply With Quote
Old 06-13-2011, 01:45 PM   #7725
Just ordered my gear diff, an extra spool, and the king headz bell crank. Can't wait to start wrenchin. Has anyone ever tried the low friction belts, and are they worth the money?
SEO by vBSEO 3.5.0
