Old 06-07-2011, 05:28 AM   #7681
Ilya's Avatar
Hi guys.
Why did you change the position of the servo?
Example photo in the post 7677. thanks in advance)
Ilya Plakhotnik
Russia Moscow
RCRacer Magazine
Yokomo-Serpent
https://www.facebook.com/ilya.plakhotnik.RC
Ilya is offline   Reply With Quote
Old 06-07-2011, 05:39 AM   #7682
Edu Brasil's Avatar
Send a message via MSN to Edu Brasil
Hi ILYA
I changed the servo position to accommodate better amb , esc and receiver and to improve the weight balancing , here in Brasil we run with 1350gr. of limit , to equilibrate my car had to stay with 1395gr. with the turned servo managed to let the balanced car with 1360gr. !!!
Top Photon and Tekin
Edu Brasil is offline   Reply With Quote
Old 06-07-2011, 12:50 PM   #7683
OVA
OVA's Avatar
Trader Rating: 76 (100%+)
Where ever happen to the promise Reedy Race set up?
OVA is offline   Reply With Quote
Old 06-07-2011, 04:30 PM   #7684
I wouldn't mine trying that setup also.
JETT is offline   Reply With Quote
Old 06-07-2011, 08:56 PM   #7685
J Stark's Avatar
Sorry guys about not getting that set up posted yet. I don't have a set up sheet with me to fill out and don't have pdf version either. I will be with EJ this weekend at a race and I will get the set up sheet dialed in with him as I'm sure we will be pitting together. Just a bit more time and I'll have up shortly.
J Stark is offline   Reply With Quote
Old 06-08-2011, 04:15 AM   #7686
hanulec's Avatar
Trader Rating: 27 (100%+)
Jesse - I have an editable setup sheet here -
http://racerlog.com/wiki/T.O.P._Photon#Setups
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 06-08-2011, 04:29 AM   #7687
Bishop's Avatar
My Yoko gear diff just arrived today, of interest that I noticed right away, the TOP blades won't fit in it, too thick, but it comes with Yoko blades, which are a tiny bit looser around the TOP shaft pins than stock, but look like they should work, or I could just sand down the TOP blades a little bit.
Also shimming will require some tweaking I think, alignment of the diff look a shade different to the TOP micro gear diff, and number of shims will differ, the TOP diff uses two 1.5mm shims (one each side), the Yoko looks like it will need 1.5mm total, so .75mm per side, or some tweaking to get the belt alignment right.
Up side though is the Yoko diff comes as a nice package, it may be a little dearer than the SpecR but I'm impressed it comes with the yoko blades and 700 weight silicone oil, and even some black grease for the build.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 06-08-2011, 05:03 AM   #7688
hanulec's Avatar
Get the associated blades --
http://racerlog.com/wiki/T.O.P._Photon#Option_1_2
Old 06-08-2011, 05:23 AM   #7689
J Stark's Avatar
Hanulec: Thank you for the link!
Old 06-08-2011, 05:57 AM   #7690
Professor's Avatar
Default ball diff
hanulec
what is the theory/benefit of building the ball diff this way ???
Ball Diff
Install only four cone washers in the diff half like this: ")()("
VBC RACING AUS--HOBBYWING--MAD GRAPHICS--BITTY DESIGN
Professor is offline   Reply With Quote
Old 06-08-2011, 06:06 AM   #7691
hanulec's Avatar
The ball diff thing was something Larry mentioned a year or so back. I don't remember Tue context
Old 06-08-2011, 07:08 AM   #7692
Bishop's Avatar
Wow the fit of the Yoko diff is so borderline, the BD5 has thicker spacing out on the gears off the spur, meaning the diff pulley sits further out, big problem with that is in multiple areas, you 'have' to shim the yoko diff off it's true center (right now I'm like .9mm one side and .4mm on the other), and even then the diff is nearly touching the chassis on one side, with the right side diff blade coming close to binding up, also the belt alignment is not ideal, or marginal.
Diff is a little tight right now (still got the original TOP .3mm shims in the bearing carriers), so I'll try dropping to .8mm and .3mm, I'm a little worried about the belt being hard against the guides, but I know there is a .2mm shim on the spur layshaft I can adjust on the left side, so less belt side rub if I tweak that.
Couple of notes, I'm on a foam tyre setup, with 3deg camber or so on the rear, which is partly why the diff blades are so close to binding, but also I know the Yoko runs 44mm rear shafts, .5mm shorter than the TOP, makes me wish I had bought some Yoko rear shafts, maybe worth a try by someone at some point.
QRCCRA
www.qrccra.org.au
Old 06-08-2011, 09:37 AM   #7693
Bishop's Avatar
Nope, looks like 0.9mm left side (3x0.3mm shims), and 0.4mm right side (2x0.2mm) is fine, about the same amount of side to side play as the TOP micro diff I got up front.
You can't go less on the left side, diff will rub on the chassis cut out, and belt alignment gets worse, less shim on the right works if you have the cup and shaft length space, but depends on suspension setup.
Not only did I have 3 degree or more camber, I also had less toe in than kit spec (minus the .4mm rear arm shim), but I did have a final fix to increase length for the shafts, in my parts order I had some extra suspension arm spacers (bought them to space out my servo), so in the end I threw on the .4mm shims front and rear of the arms, so I'm going to be a little wider in the rear, but I got the length now so the blades don't foul in the cups on the right side.
Final thought though, it would be nice if TOP or SpecR made us a dedicated gear diff that will run 13.5-10.5 and mod...
QRCCRA
www.qrccra.org.au
Old 06-08-2011, 11:49 AM   #7694
XxRONNxX's Avatar
At first, I used the Yokomo blades which worked fine until I noticed they would always spread open. I'd replace them again with new blades with the same result. Now I use the TOP blades and sand them down to the size of the Yokomo blades and I no longer have the problem. I run mod so it puts more stress on the blades. As for shimming the gear diff, I was looking at EJ's gear diff and saw that it wasn't shimmed. It just moves from side to side. I asked him if he runs it that way and he does. Said he keeps forgetting to shim it. I told him that was crazy running it like that but it works with no problems.
Ron D.
XxRONNxX is offline   Reply With Quote
Old 06-08-2011, 09:38 PM   #7695
MikeR's Avatar
Trader Rating: 15 (100%+)
Hi All!
You knew it was coming More info is up.
http://www41.instantestore.net/merch...po-chassis.cfm
Thanks for your support!
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
