Old 05-29-2011, 04:35 PM   #7621
hanulec's Avatar
Trader Rating: 27 (100%+)
Originally Posted by superspeed View Post
That looks like a Roche or litemods spool.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 05-29-2011, 07:09 PM   #7622
vabroom's Avatar
Litemodz and I think you need a Yokomo pulley since it has a 3 bolt mount to TOP's 4 bolt mount.
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 05-29-2011, 09:20 PM   #7623
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
Originally Posted by pakk View Post
Who's running aluminum pivot balls?
Is the only advantage weight? How much weight is saved when you replace them throughout the car?
I'm running all the top aluminum option parts(tie rods, Pivot balls & arm mounts) as well as lundsford screws w/ SXX Stock spec, rev tech pack bat weights in at 1330 w/ no lead. have only ever broke 1 tie rod (and it was a hard hit on carpet) since September.
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 05-29-2011, 10:07 PM   #7624
smilekt's Avatar
need help
anyone have setup for high speed Corner long sweeper & semi technical infield
Track surface asphalt low grip to mid
Kuala Terengganu Rc Club Facebook
http://www.facebook.com/group.php?v=wall&gid=357083332025
smilekt is offline   Reply With Quote
Old 05-30-2011, 01:16 AM   #7625
Bishop's Avatar
Anyone know if Yokomo shafts/CV's will work in the Photon ok?, I really need to dump the stock alloy front and rears (all that came in my kit) and switch to steel, Yoko ones are like half the price of the Top from where I'm buying...
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 05-30-2011, 02:30 AM   #7626
Professor's Avatar
yes it is & yes you do need the yok pulley,i have these in my 2 photons & they are almost bullit proof (not cheap though)
VBC RACING AUS--HOBBYWING--MAD GRAPHICS--BITTY DESIGN
Professor is offline   Reply With Quote
Old 05-30-2011, 07:34 AM   #7627
MikeXray's Avatar
Trader Rating: 73 (100%+)
The axles are the same from stock to steel, so you really only need the bone, amain sells the bone itself for $8.50 each, that's more than reasonable and they last a long time. If you are running a spool though, you will really want to go the ECS route, pricey but worth it...
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 05-30-2011, 08:20 AM   #7628
pakk's Avatar
Trader Rating: 79 (100%+)
would it be too much to ask for someone to weight one of the aluminum pivot balls?
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 05-30-2011, 08:27 AM   #7629
bkspeedo's Avatar
Why is everyone so keen on making there car lighter? The car is already to light and you have to add weight. The parts your replacing are so light to begin with i doubt you will feel any difference in performance.
If your looking at going faster work on setup and driving skills, making your car lighter is not going to help.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 05-30-2011, 08:40 AM   #7630
Its about a 4 aluminum to 1 steel ratio. I did weigh the 2 but I don't remember the exact weight
Old 05-30-2011, 10:07 AM   #7631
hanulec's Avatar
unless your a drug dealer it is hard to have a scale to weight just one of those balls. when i finally do up a whole car w/ aluminum balls i'll pull out 26 steel balls and weight them against 26 aluminum balls.
Old 05-30-2011, 10:33 AM   #7632
Mike Haynes's Avatar
I got a scale that goes to .1 gram, can bring to jackson sat if you like...and before you say it i bought it for mini z parts
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 05-30-2011, 10:43 AM   #7633
Any questions?
T.O.P. Racing "Photon" 1/10 EP Touring Car-photo-1-.jpg   T.O.P. Racing "Photon" 1/10 EP Touring Car-photo-3-.jpg
Old 05-30-2011, 10:45 AM   #7634
stiltskin's Avatar
Trader Rating: 102 (100%+)
Any questions?
Yeah. you got any of that good stuff left? I'll meet you on the playground beside the monkey bars.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 05-30-2011, 10:47 AM   #7635
nope I have that scale from back in my oval days and more recently when I thought a 4 scales would be better then a tweak station.
