Old 05-22-2011, 08:36 AM   #7576
stiltskin's Avatar
Trader Rating: 101 (100%+)
Originally Posted by Luppi Stefano View Post
used on Carpet or Asphalt?
because, on carpet, I have try this Chassis(I narrowed old Lipo 2mm) and it work really bad!
Originally Posted by smilekt View Post
what do mean very bad ... not stiff enough ?
I used the 2.5 mm lipo chassis. Even after narrowing it, it is stiffer than the current lipo chassis.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 05-22-2011, 09:20 AM   #7577
Luppi Stefano's Avatar
I did not know there was 2.5mm!
I thought only 2mm and 3mm
eh, then the question changes!
how come you do haven't drilled the lipo side?
for the same dx-sx flex
T.O.P. Racing "Photon" 1/10 EP Touring Car-22-04-11_1822.jpg
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 05-22-2011, 09:39 AM   #7578
stiltskin's Avatar
I haven't had too much time with the chassis but haven't seen any ill handling effects yet. Maybe I'll do some more cutting after a few more runs.
Tony Rumple
Old 05-22-2011, 09:40 AM   #7579
hanulec's Avatar
Trader Rating: 23 (100%+)
+1
the base stiff lipo chassis that ships with the current batch of cars is VERY good. it works on carpet and asphalt (both with rubber tires). if you look where the car 'drags' on the track you can think about places on that chassis that it might make sense to 'self-optimize' the chassis with a Dremel and cut-off wheel.
this is one of the more extreme narrowing that i've seen. prior to this, Martin Crisp had done something as dramatic as this. it sure does make mounting electronics a little more difficult though...
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 05-22-2011, 10:22 AM   #7580
pakk's Avatar
Trader Rating: 79 (100%+)
What is the "theory" behind a narrow chassis working better? Is it just that the chassis does not rub on the surface?
I'm one of the lucky few that was able to grab a narrow chassis from EJ. It is amazing how much easier the car is to drive with it.
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 05-22-2011, 10:28 AM   #7581
hanulec's Avatar
i believe it is all about chassis rub and scrub marks. indoors you'll see marks from carpet, and outdoors you'll see scrapes against the chassis. i've been running the EJ chassis in 13.5T outdoors and you'll see a nearly perfect 'scrub' on the entire chassis edge. with the stock stiff chassis (which i run in modified) there is a much greater scrub at the front sides of the chassis, and there is less scrub marks at the rear sides.
Old 05-22-2011, 11:54 AM   #7582
locked's Avatar
Damn all you guys with the prototype narrow chassis :P
I tried to get Martin's when he switched to orange. I contacted him the weekend after, but he had already sold it.
Cyrul, if you are reading this, make some more of those narrow chassis and sell them through cefxspeedshop. I'm sure I'm not the only one who wants one. I actually want two of them.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 05-22-2011, 05:42 PM   #7583
MikeXray's Avatar
Trader Rating: 72 (100%+)
Exotek's site lists a narrow photon chassis coming soon, hopefully very soon, I need 2 as well.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 05-22-2011, 05:46 PM   #7584
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
I have seen the first proto-type first hand (I can't wait for the production version)
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 05-23-2011, 12:16 AM   #7585
td-civ's Avatar
Trader Rating: 18 (95%+)
hey guys i want to trade my photon for a team magic e4rs if you know anyone that want to trade let me know please
it has lots of upgrades on it
trade roller for roller
td-civ is offline   Reply With Quote
Old 05-23-2011, 07:28 AM   #7586
TAMAK's Avatar
Trader Rating: 28 (100%+)
I have a Cyrul chassis. I noticed that it did not work for me. I switched back to the six cell and now it works.... .
PM me with a offer if you want to buy one. As I may stick with the six cell.
TAMAK is offline   Reply With Quote
Old 05-23-2011, 09:43 AM   #7587
gruman28's Avatar
Trader Rating: 16 (100%+)
Does anyone have trouble getting enough steering out of the car?
Everything was okay until we changed to a more technical track. I couldnt get enough right steering. I was told by another Top driver that my tie rod between the servo and the crank was too long.
Every other car I ever had always had too much steering. Currently I am at 100% Dual rate and 150% right travel.
I am going to go through the car tonight to see if I can find any reason this is happening.
Any insight on where to start would be great,
Chris
gruman28 is offline   Reply With Quote
Old 05-23-2011, 10:01 AM   #7588
Bishop's Avatar
Chris
I had some simular issues, then when fitting a new low profile digital servo, I made a real effort to sort it out, in the end it comes down to position of the servo horn (look carefully how the manual shows it), and getting that linkage the right length etc.
Tweaked mine also in a setup station once done, and now I have perfect steering throw left to right (with no real tweaks needed on the radio), and generally more steering than I need at any time, I'll just dial my DR knob on the fly to suit track conditions and how much steering I need on the day.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 05-23-2011, 10:10 AM   #7589
MikeXray's Avatar
Chris
Do you have the kingzhead bellcrank? it helps to dremel the bulkhead where the arm can hit it, you can get some extra throw, that in addition to making sure the link isn't binding up on your servo saver preventing the arm from moving all the way.
Old 05-23-2011, 10:18 AM   #7590
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
Lol must be running asfault. I had same problem . I am running the newer lipo chassis. Running med/low role centers on all corners. Front shocks 324 out 1 hole. Narrow as possible in front and no sway bar.
In rear I have 1mm shim in front and 3.5mm in rear for toe. Shocks r in 2 holes with 306 springs and no sway bar. I'm running the #11 akerman insert out 1 mark . Out side links r in inner hole of nuckle. Run-in #2 on all 4 camber plates. Also I have the newest lipo topdeck with only 4 outer screws in it. After balancing my car I added 1/2oz under belt as far to rear as I could.(right front of pinion) . It went from pushing like a doze to being on the edge of loose with this setting. 2 other photon drivers using same set up now and we all love it . But I will say still don't have turn around radius of T3. But more than enough for 10'-14' lanes outdoor tracks
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
