Old 05-14-2011, 08:37 PM   #7546
hanulec's Avatar
Trader Rating: 27 (100%+)
Originally Posted by Bishop View Post
Can anyone let me know what spacers/washers/shims I need to run the Yoko gear diff?, I know someone said but I can't seem to find the post now, and I forgot to write it down, really need a better gear diff now as the micro chewed on it's third outing in 10.5T, and I don't really want to go back to a ball diff.
You need 10x12 shims - thd pn is in my wiki
Originally Posted by vabroom View Post
Hanulec, have you try Xray's steering blocks with the ECS/Mira combo? I found a couple of them from my old/gone 007. They seem to have the same dimensions as Photon's.
I run xray chubs and steering blocks most times. There are a few types of steering blvks. The ones from the t3 have the most throw
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 05-14-2011, 10:25 PM   #7547
vabroom's Avatar
thank you, Hanulec
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 05-14-2011, 11:36 PM   #7548
Bishop's Avatar
Originally Posted by chris_dono View Post
Just use the red shim from the micro-pro one, it's the right size
I wondered about using those.
Hmm, looks like no one I buy from has the TOP part number, there is a 3racing and Tamiya shim set though, the 3racing one says it has like 10 of .1/.2/.3 steel shims.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 05-15-2011, 12:12 AM   #7549
vabroom's Avatar
I don't think it matters which one you use, but TOP shim number is PA-101012 and I think it has 10 of each .1, .2 and .3.
Old 05-15-2011, 01:01 AM   #7550
Bishop's Avatar
Cool, by the sounds of it all the 10mm shim kits come with almost the same set of shims then, which means I'll likely be good whatever kit I buy when I get the new yoko diff.
Looking forward to the stronger gear diff, the micro one feels great till it chunks, though I'm keeping the micro up front, it holds up fine with 100k+ in it, gives me fantastic corner entry speeds.
QRCCRA
www.qrccra.org.au
Old 05-15-2011, 01:08 PM   #7551
Trader Rating: 65 (100%+)
What motor are you running the 100k with. Will this work up front in a 17.5 non ramping car?
goose510 is offline   Reply With Quote
Old 05-15-2011, 03:59 PM   #7552
where can i find a pdf of the manual ?? ran a search and googled and nothing with a valid link seems to come up......
thanks
The Hobby Shop,The Ohio RC Factory
T.O.P. Photon CRC XTI, XRAY T4 15 xray xb4 xb8e losi sct 2.0
insanity takes it's toll...please have exact change
bpalmer is offline   Reply With Quote
Old 05-15-2011, 04:25 PM   #7553
hanulec's Avatar
http://www.racerlog.com/wiki/T.O.P._Photon#Manual
thanks
Old 05-15-2011, 04:42 PM   #7554
thank you hanulec
Old 05-15-2011, 10:33 PM   #7555
Bishop's Avatar
10.5T with no timing, not sure about 17.5T as it may not need it (speed and power wise if your going slower it may not be noticed as much).
I have said it previously, but the gear diff up front is likely working for me cause it's a track with bumpy corners, and medium to low traction, I can go harder into the corners now, a lot harder in fact, downside is maybe I loose a little drive coming out of the corner, also I noticed it will want to come out wide compared to a spool which gives more steering out of a corner (diff gives more steering into the corner).
It's a try it and see if you like it type of thing, right now I just love because it makes the car easy to drive, I like anything that makes the cars easier to drive.
QRCCRA
www.qrccra.org.au
Old 05-15-2011, 10:46 PM   #7556
OVA
OVA's Avatar
Trader Rating: 77 (100%+)
I did some testing with two gear diffs. and my laps time is much faster with the spool...just my 02cent
OVA is offline   Reply With Quote
Old 05-19-2011, 01:02 PM   #7557
Is this car still in production? It is out of stock in any shop like
Amainhobbies and rc-mushroom.
electric_only is offline   Reply With Quote
Old 05-19-2011, 01:38 PM   #7558
RaceAce701's Avatar
Trader Rating: 84 (99%+)
quick question
what length are the steel front drive shafts
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 05-19-2011, 01:53 PM   #7559
locked's Avatar
Originally Posted by RaceAce701 View Post
quick question
Front dogbones are 46mm
Rears are 44.5mm
I assume that's what you mean.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 05-19-2011, 02:03 PM   #7560
RaceAce701's Avatar
yep thanks a bunch
Alex "ACE" Kubilus
ACE design works
