Old 05-02-2011, 09:38 AM   #7486
vabroom's Avatar
Originally Posted by hanulec View Post
Nov 2010 high bite carpet. This is similar to the latest setup i posted. from the Cs.
http://racerlog.com/wiki/T.O.P._Photon#Setups
Xray 150cst/15wt in a Yokoko gear diff.
150cst? Is this because the Yokomo gear diff has a larger volume that you don't need 1000+cst?
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 05-02-2011, 10:27 AM   #7487
hanulec's Avatar
Trader Rating: 25 (100%+)
The spec-r and yokomo diffs are very similar in feel. Last year I ran 350cst within the spec-r outdoors and 2k indoors (but it never felt on carpet).
The lighter the oil, the more steering but there is less stability ..
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 05-02-2011, 11:58 AM   #7488
defcone's Avatar
Trader Rating: 15 (100%+)
Did it leak when u ran that light?
defcone is offline   Reply With Quote
Old 05-02-2011, 12:52 PM   #7489
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
I have two R-Spec gear diff ..non of them leak..1000 and 500000 wt...
OVA is offline   Reply With Quote
Old 05-02-2011, 02:05 PM   #7490
hanulec's Avatar
Yokomo diff - leaked a bit, but nothing like spec-r
Don't care if it leaks .. only needs to be the fast setup and reliable ...
Old 05-02-2011, 05:40 PM   #7491
OVA
OVA's Avatar
Hey Mike
question : what made you decided to use the gear diff?
Old 05-02-2011, 06:12 PM   #7492
hanulec's Avatar
Originally Posted by OVA View Post
Hey Mike
well we all started running them last outdoor season. at the time i was sponsored by Atomic/Spec-R and running XRays. They came out w/ a gear diff at the time so I said I'd give it a try -- it was free . running a gear diff is very similar to running a loose ball diff ... but if you do that in any class other than 17.5 blinky you'll need to rebuild your ball diff very often. when i started running a gear diff it took my 'pushy' XRay T3 and made it rotate, especially through 180s, where it would usually push. and when you jumped on the power the car would just hook-up.. no slipping, just lot of acceleration.
also -- i don't know if everyone remembers or not.. but the Worlds occurred last summer and the Spec-R gear diffs were "very" popular because of the win from Marc R.
Old 05-02-2011, 07:11 PM   #7493
OVA
OVA's Avatar
good report..thanks
Old 05-03-2011, 10:25 AM   #7494
Kail's Avatar
I tried the yokomo gear diff with 700wt oil. The car feels great, still a little understeer though.
Next I changed my bodyshell to the Ride Legacy B4. That sort of gave me a "1/12 feel". It took some adaptation but now works great.
The only thing I noticed is my rear belt(the black one) wears really fast. I have worn a new rear belt in just about 15 packs of Mod. What is the tension level you guys set when using the gear diff? I find that if I set it loose like on normal gear diffs, after about 5 packs, the car gives off a strange sound upon hard acceleration, as if there is belt slipping. I then tightened the belt a notch and my belt's wear rate became unreasonably high.
Kail is offline   Reply With Quote
Old 05-03-2011, 11:22 AM   #7495
MikeXray's Avatar
Trader Rating: 73 (100%+)
how much play is there in your layshaft and diff setup? the geardiff require some extra shims to take out the side to side play, Maybe the belt is pulling at an angle under power?
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 05-03-2011, 11:23 AM   #7496
XxRONNxX's Avatar
Next I changed my bodyshell to the Ride Legacy B4. That sort of gave me a "1/12 feel". It took some adaptation but nowp works great.
You shim the yokomo gear diff?
Ron D.
XxRONNxX is offline   Reply With Quote
Old 05-03-2011, 09:13 PM   #7497
Kail's Avatar
Ya. I placed shims equally on both sides of the gear diff
Old 05-03-2011, 10:00 PM   #7498
David Galdo's Avatar
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
What is the part number for the 46MM steel dog bones??
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 05-03-2011, 10:35 PM   #7499
locked's Avatar
PO-SDT008
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 05-04-2011, 03:51 AM   #7500
hanulec's Avatar
You might not want to shim it equally. Make sure the pulley edge isn't hitting your chassis.
I haven't seen belt wear like your talking about. I'd say u should just continue to tighten the belt as it should be allowed to slip (that is What that noise is)
