Old 04-28-2011, 08:20 AM   #7471
Kail's Avatar
Hi Larry, I am trying to reduce the turning radius of my car. The biggest difference my T3 11 and TOP is the steering throw and i was guessing that the drastic difference in turning radius is most probably because of the turning radius.
Kail is offline   Reply With Quote
Old 04-28-2011, 09:40 AM   #7472
Luppi Stefano's Avatar
Originally Posted by TAMAK View Post
Any word on the Exotek lipo chassis?
wait and see ...
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 04-28-2011, 05:34 PM   #7473
hanulec's Avatar
Trader Rating: 23 (100%+)
i'd say if your using full lock, you should probably look at another setup component. i only use it when traction is low / track is cold.
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 04-29-2011, 02:01 PM   #7474
gruman28's Avatar
Trader Rating: 16 (100%+)
Noob Question.... How much push should I expect running a spool? Especially in the sweeper? I was told that my car pushes hard in the sweeper because I am driving too hard into the corner and I cant drive that way with a spool.
Any advice about running with a spool would be appreciated...
thanks
Chris
gruman28 is offline   Reply With Quote
Old 04-29-2011, 04:09 PM   #7475
hanulec's Avatar
thanks
Chris
spools are great! tell us more about the surface you're racing on, your motor class, and post your setup if you like --- we need that sort of stuff to help.
generally -- you have to lift when entering a sweeper (or find the outside board - it is your choice).
Old 04-29-2011, 05:12 PM   #7476
gruman28's Avatar
Parking Lot (med/ low traction), 17.5 spec (blinky),
I think its me. I just need to lift before the sweeper. Just not used to doing that. I am getting quite acquainted with the outside board. lol
Thanks as always,
Chris
Old 04-29-2011, 05:27 PM   #7477
hanulec's Avatar
Thanks as always,
Chris
another thing to look into -- what are others at the same tracking doing? are they lifting there? you can tell this by either talking w/ folks ... or just watching their cars travel around the track.
Old 04-30-2011, 07:13 PM   #7478
ewashburnaf's Avatar
Trader Rating: 14 (100%+)
Thanks as always,
Chris
I smell what your stepping in...
Fishhook
ewashburnaf is offline   Reply With Quote
Old 05-01-2011, 10:18 AM   #7479
gruman28's Avatar
Today was better.... We put down some grape soda for traction, but the pollen was horrible and temp was low. But the sweeper was the least of my worries.
Thanks for all the help,
Chris
Old 05-01-2011, 12:20 PM   #7480
hanulec's Avatar
Chris
A 50/50 mix of grape soda and water is the way to go but it helps greatly to blow the track off first. Pollen is a big traction reducer and hard to work around. We haven't been hit by it yet at Jackson but I know its coming...
Old 05-01-2011, 12:45 PM   #7481
hanulec's Avatar
I just want to thank Larry and The GOAT for their help yesterday at Jackson. The three of us were close to sweeping all of the TC classes yesterday.
I'm truly excited about running the Photon outdoors. I'm mostly shocked as to how good Larry's base indoor setup worked outdoors by only changing front springs and adding a rear gear diff.
Old 05-01-2011, 12:59 PM   #7482
L.Fairtrace's Avatar
Send a message via AIM to L.Fairtrace
Good Run yesterday FJ, Goat also ran well.
My car was getting better as Traction started to come up. It was a fun day yesterday. Mod is quite fast at night.
Racing was tight in all classes yesterday and Until problems beyond my control Haynes and I had quite a race going on as well.
Its going to be a great season at Jackson.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 05-01-2011, 01:40 PM   #7483
Jerry P's Avatar
Trader Rating: 44 (100%+)
As always the Top Boys are a big help at Jackson. The Spring change sure helped me out too.
Congrats to FJ on the W yesterday. It was only a club race but it sure didnt seem like it. LOL
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 05-01-2011, 09:17 PM   #7484
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
which of the larry carpet setup was used? and what weight oil was in the rear gear diff?
OVA is offline   Reply With Quote
Old 05-02-2011, 03:40 AM   #7485
hanulec's Avatar
Nov 2010 high bite carpet. This is similar to the latest setup i posted. from the Cs.
http://racerlog.com/wiki/T.O.P._Photon#Setups
Xray 150cst/15wt in a Yokoko gear diff.
