Old 04-26-2011, 06:19 PM   #7456
smilekt's Avatar
Originally Posted by TeamWTF View Post
Hows your weight distribution Left/Right?
yes it same balance left & right ...
Kuala Terengganu Rc Club Facebook
http://www.facebook.com/group.php?v=wall&gid=357083332025
smilekt is offline   Reply With Quote
Old 04-26-2011, 06:20 PM   #7457
smilekt's Avatar
Originally Posted by mazmo View Post
Brad,
I have been using the low diff positions front & rear. Agree car feels better, seems to improve grip.
Have also been using the shorter top links together with lower Low RC blocks / high position. Also using 1.3mm sway bars. Seems good balance between grip & responsiveness.
Alan
Sorry .. may i know how to setup low diff position front & rear?
Old 04-26-2011, 06:31 PM   #7458
mazmo's Avatar
To lower the diff, just rotate the bearing cam so that the mark is at the top.
To raise the diff, rotate so mark is at the bottom.
Alan
Team TOP Australia www.topracing.net.au
TOP Photon EX 17.5 + TOP Photon EX 21.5 + TOP Rebel F1 21.5
ORCA | Tekin RS Pro | Tekin Gen 2 RPM | Ko Pro-Po | EPIC Trinity
mazmo is offline   Reply With Quote
Old 04-26-2011, 07:35 PM   #7459
smilekt's Avatar
Alan
thanks mazmo
Old 04-27-2011, 11:50 AM   #7460
OVA
OVA's Avatar
Trader Rating: 77 (100%+)
Default Gear Diff
Reedy races coming up soon...Which's, the Gear or Ball diff would be recommended for 17.5 spec stock @ North Cal race track?
OVA is offline   Reply With Quote
Old 04-27-2011, 11:59 AM   #7461
XxRONNxX's Avatar
When I ran 17.5 NR at norcal, I ran the standard ball diff with ceramic balls. I inspected my diff after every run. The car handled fine. I'm running the Yokomo gear diff now in mod. Never tried it in 17.5 NR.
Ron D.
XxRONNxX is offline   Reply With Quote
Old 04-27-2011, 12:17 PM   #7462
OVA
OVA's Avatar
What was you FDR for 17.5 NR?
Old 04-27-2011, 01:23 PM   #7463
XxRONNxX's Avatar
It depends. I'd start around 4.0 and compare my straight away speed with other 17.5 NR. If its too slow, I'd gear up. I also check my temps. I try to keep it between 125-150 degrees. I also run a motor heatsink and fan. Hot weather plays a factor on motor temps too. However, for a big race, I'll run the motor hotter than 150 and gear it to the moon.
Ron D.
Old 04-27-2011, 04:15 PM   #7464
OVA
OVA's Avatar
Old 04-27-2011, 04:45 PM   #7465
TAMAK's Avatar
Trader Rating: 28 (100%+)
Any word on the Exotek lipo chassis?
TAMAK is offline   Reply With Quote
Old 04-27-2011, 10:02 PM   #7466
Kail's Avatar
Originally Posted by Kail View Post
Hi guys, I filed away the "nub" on the steering block. However, my steering throw is still limited to 25 degrees. Does changing to Xray hub carrier allow a greater steering lock?
Also, any other recommendations to reduce steering radius without inducing a v loose rear?
Anyone can help me with this?
Kail is offline   Reply With Quote
Old 04-28-2011, 04:31 AM   #7467
hanulec's Avatar
Trader Rating: 27 (100%+)
When your steering is turned to full lock is the inside steering block (now w/ the nub removed) touching the arm?
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 04-28-2011, 06:24 AM   #7468
MikeXray's Avatar
Trader Rating: 73 (100%+)
Chances are the bellcrank arm is hitting the bulkhead first, also if you changed the button head screw in the bellcrank length adjustment, make sure its not too long and hitting the wings.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 04-28-2011, 06:28 AM   #7469
Kail's Avatar
Well, it seems like my steering block can only steer till it hits the c hub. Whatever I do, it is limited by the c hub. What are ur maximum steering angles?
Old 04-28-2011, 07:22 AM   #7470
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Yeah thats about right? Why are you looking for more physical throw?
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
