Old 04-12-2011, 06:47 PM   #7381
Jerry P's Avatar
Trader Rating: 44 (100%+)
Originally Posted by hanulec View Post
Lipo chassis -- hope to make the race... and pop my Reedy cherry
That's the only cherry you have left.
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 04-12-2011, 07:11 PM   #7382
hanulec's Avatar
Trader Rating: 27 (100%+)
Originally Posted by stiltskin View Post
You beat me to it Mike.
The only part I'd say that really helps the car on carpet is the XRay ECS.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 04-12-2011, 07:14 PM   #7383
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
I'm working on it ,.......thanks mike
OVA is offline   Reply With Quote
Old 04-12-2011, 10:03 PM   #7384
pakk's Avatar
Trader Rating: 79 (100%+)
How does adding shims to the camber links affect handling?
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 04-12-2011, 10:57 PM   #7385
vabroom's Avatar
It's probably old news, but I see that Mike at Exotek is working on a narrow lipo chassis for the Photon.
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is online now   Reply With Quote
Old 04-13-2011, 03:17 AM   #7386
stiltskin's Avatar
Trader Rating: 102 (100%+)
Don't forget the Mira outdrives from Side Piece Racing.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 04-13-2011, 03:29 AM   #7387
hanulec's Avatar
They change the roll center. Shims can go either at the bulkhead or hubs. Please consult a setup book on the effect of the changes and just "play" with it.. as that is the only way to learn.
The fact that you can use shims at the bulkhead is one of the reasons I like the Photon as compared to my previous TC (Xray).. but even they have seen the light too -- it will just cost a small fortune to m
ake that upgrade
Old 04-13-2011, 06:15 AM   #7388
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
ake that upgrade
It also changes camber gain.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 04-13-2011, 06:27 AM   #7389
anyone know a way to add bump steer ? normally with the links to the steering arms underneath we'd add shims...
CPD Racing
chris_dono is offline   Reply With Quote
Old 04-13-2011, 06:28 AM   #7390
Why cant you do that still?
Old 04-13-2011, 06:30 AM   #7391
MikeXray's Avatar
Trader Rating: 73 (100%+)
Use a longer set screw on the knuckle and put shims under the ball end?
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 04-13-2011, 06:36 AM   #7392
OVA
OVA's Avatar
that's awesome
Old 04-13-2011, 07:02 AM   #7393
This is what I was suggesting sort of. I actually use a buttonhead screw from the bottom here so it cant rip out of the steering block.
Old 04-13-2011, 09:34 AM   #7394
pakk's Avatar
ake that upgrade
Thanks guys. I was actually wondering how they affect camber gain and roll center. I wanted confirmation on what I think happens.
Here is what I think I know.
Shortening the links increases camber gain.
Lenthening descreases camber gain.
Lowering the inside position increases camber gain.
Raising the inside position decreases camber gain.
Raising the outside position decreases camber gain.
Lowering the outside position increases the camber gain.
I'm not sure how roll center is affected.
Also, keeping the camber rods the same length, how does moving them from the inside position to the outside position affect camber gain and roll center. This is only adjustable in the rear.
*Photon* *SC10 4x4*
RCRD
Old 04-17-2011, 04:55 AM   #7395
Luppi Stefano's Avatar
I tried u-pro spool...
delrin cup, after only ONE race, have a little break...
there are steel cup, compatible with u-pro spool?
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
