Old 04-07-2011, 06:29 AM   #7366
Bishop's Avatar
Originally Posted by Mr. Bubby View Post
Yup, I read somewhere that ALL spur gears are not completely round, so I either do it the aforementioned way. Or, and this ALWAYS WORKS for any pitch gear, take one tooth bigger-snug it up all the way, tighten motor. Then take that pinion off and put on 1 tooth smaller---perfect mesh every single time.
Am I the only one who uses the layshaft adjustment to set mesh?, it's so easy, fit gears, push together and tighten motor, back off and lift layshaft, perfect easy mesh every time, often allows you to go up one without touching motor screws.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 04-08-2011, 10:29 AM   #7367
bkspeedo's Avatar
Anyone been in contact with EJ or Michael at TOP USA lately? Iíve been trying to get a hold of either one with no luck.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 04-08-2011, 02:46 PM   #7368
bkspeedo's Avatar
Found them. Missing in action for a short while all is back to normal.
Brent Klingforth
Old 04-08-2011, 06:41 PM   #7369
rcfiend's Avatar
Trader Rating: 29 (100%+)
Couple of questions.
I've heard that the Tamiya 417 rear shock tower will work on the photon, is this true.
Is everyone running the 46 bones in the front and the 44.5 in the rear? If not can u explain the benefits of running different length bones.
rcfiend is offline   Reply With Quote
Old 04-11-2011, 07:10 PM   #7370
gruman28's Avatar
Trader Rating: 16 (100%+)
Besides Amain, is there anywhere else I can get a gear diff from? Would like to have it by the weekend, not sure if Amain will get it to me in time on the east coast.
Thanks,
Chris
gruman28 is offline   Reply With Quote
Old 04-11-2011, 07:24 PM   #7371
Travis S's Avatar
Trader Rating: 46 (100%+)
Thanks,
Chris
Order from top racing USA. I know they have the u-pro difs, but not sure on the any other types. Call them and see when they can send it out. Phone: (650) 583-8898
topracingusa@yahoo.com
I have gotten stuff fast from them. (3 days and they are in CA and I am in Chicago.)
Travis S is offline   Reply With Quote
Old 04-11-2011, 07:38 PM   #7372
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Wrong. The correct statement would be -all MOLDED spur gears aren't perfectly round-
Machined gears like PRS and Xray spurs are within acceptable tolerances of being perfectly round.
Also keep in mind you can have a slightly bent layshaft, motor shaft, or pinion gear that isn't cut dead center. Some pinions out there are very cheaply made....
BTW- not bustin your ballz, just sharing a little knowledge and havin fun.
BigDogRacing is offline   Reply With Quote
Old 04-12-2011, 12:48 AM   #7373
RC MARKET's Avatar
TOP had Spur gear
http://rcmarket.com.hk/index.php?cPath=51_98_249
RC MARKET is offline   Reply With Quote
Old 04-12-2011, 05:59 AM   #7374
Mr. Bubby's Avatar
Note taken.
Schumacher MI6 (SMC Powered) Touring Car
Schumacher KC (SMC Powered) Stock Buggy
No 1/12 scale till they run with rubber tires!!!
Mr. Bubby is offline   Reply With Quote
Old 04-12-2011, 05:18 PM   #7375
99problems's Avatar
Pretty close to purchasing this car. Wanted to know if its still relevant meaning will a Photon 2 be out soon and two what extra parts do I need to buy? I've seen a bunch of interesting set-ups for the car and I'm turning to the RC people for a little help.
Don't be a "CYBER BULLY" bring it to the TRACK!!
POINT and PULL!!
99problems is offline   Reply With Quote
Old 04-12-2011, 05:25 PM   #7376
hanulec's Avatar
Trader Rating: 27 (100%+)
There have been a bunch of changes to the Photon since its introduction in summer 2009 -- but as far as I know there isn't anything major coming. The nice thing about TOP is that they don't wait for their '10 or '11 car to bring changes/upgrades. The changes come along whenever they are available.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 04-12-2011, 05:27 PM   #7377
stiltskin's Avatar
Trader Rating: 102 (100%+)
The car is still very relevant. There is a new narrow chassis in the works but not expected for release anytime soon. I would recommend an upgraded steering bellcrank from TOP or KingHeadz. The axle pin covers are also a very good option. There are lots of options if you choose to Bling it out, but none are necessary. Good luck with the purchase. If you have any questions about the build or setup, hit us up.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 04-12-2011, 05:29 PM   #7378
stiltskin's Avatar
You beat me to it Mike.
Tony Rumple
Old 04-12-2011, 05:39 PM   #7379
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
The Reedy Race coming real soon...I like to know most you photon owner using the stiff lipo or 6 cell batteries chassis for this race?
who got the Reedy race 17.5 set up from last year or this year?
OVA is offline   Reply With Quote
Old 04-12-2011, 06:13 PM   #7380
hanulec's Avatar
Lipo chassis -- hope to make the race... and pop my Reedy cherry
