Old 03-31-2011, 05:26 PM   #7336
hanulec's Avatar
Trader Rating: 27 (100%+)
For low grip why don't u play with your shock/spring package instead of making a flexible flyer.... just a thought. I'd run the 289 rear springs/30wt and 324 fronts/40wt to start.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 04-01-2011, 06:39 AM   #7337
Default Setup Steven Weiss TCM 2011
Hi,
here I have the original setup by Steven Weiss from the LRP Touring car masters.
The second pdf is what Steven changed on the original Photon with stiff lipo chassis
File Type: pdf Notes to setup Steven Weiss 27.03.2011.2011.pdf (7.1 KB, 194 views)
Lutz is offline   Reply With Quote
Old 04-01-2011, 08:45 AM   #7338
GONZO-Racing's Avatar
Originally Posted by Lutz View Post
Hi,
Hi
In cooperation with Mechanics GONZO-Racing.com
Gruss Daniel "GONZO" Ghirlanda
www.gonzo-racing.com
GONZO-Racing is offline   Reply With Quote
Old 04-01-2011, 10:44 AM   #7339
oh yes of course...
sorry I forgot that...
Old 04-04-2011, 05:04 PM   #7340
bkspeedo's Avatar
I noticed TOP USA site has not yet added a setup sheet area. Aside from posting on RCTech has anyone created a site for pro's and other racers to post setups?
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 04-04-2011, 05:08 PM   #7341
hanulec's Avatar
Racerlog.com ... check the wiki link in my sig
http://www.racerlog.com/wiki/T.O.P._Photon#Setups
Old 04-04-2011, 07:13 PM   #7342
shoei's Avatar
Send a message via ICQ to shoei
Petit rc has links to quite a few setups.
http://www.petitrc.com/reglages/top/...TOPPhoton.html
shoei is offline   Reply With Quote
Old 04-05-2011, 02:31 AM   #7343
Professor's Avatar
Default screw length
can onyone using the 1 screw method in the layshaft tell me what length screw is used as im going to change to the 1 screw method & need to buy some
thanks
graham
VBC RACING AUS--HOBBYWING--MAD GRAPHICS--BITTY DESIGN
Professor is offline   Reply With Quote
Old 04-05-2011, 02:39 AM   #7344
thanks
graham
Graham,
From what i read on various posts, its literally taking one screw out, no need to change anything else.
All i would suggest is using a proper steel screw, not the hardened cheese top ones. On my car, and the one i built matt, i just used a regular 12ish mm screw.
I was quite shocked how much better the car felt in the prac run that i tried it. Too bad i didnt get to race on the weekend,
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 04-05-2011, 04:34 AM   #7345
hanulec's Avatar
thanks
graham
A lot of are using lunsford "fat boy" motor screws on just the right layshaft mount. It has a 2.5mm head so you can really wrench down on them. I think we are using the long versions that are about 9mm long. This screw is commonly used in 1/12 or with other TC brands but it cannot be used on the top photon motor mount.
Old 04-05-2011, 05:39 AM   #7346
Professor's Avatar
when you say the right layshaft mount do you mean the battery side or the motor side ??
thanks brad & hanulec for you responses
Old 04-05-2011, 05:52 AM   #7347
hanulec's Avatar
Battery side . My motor side is blocked by a fan.
Make sure you are using the steel layshaft. The end with the flat piece sticking up is on the screw side (battery side). Use a small screw driver to hold the layshaft from spinning while u wrench down on that single screw.
Old 04-05-2011, 11:15 AM   #7348
Are these it?
http://www3.towerhobbies.com/cgi-bin...?&I=LXY801&P=7
JETT is offline   Reply With Quote
Old 04-05-2011, 11:20 AM   #7349
hello
nata1007 is offline   Reply With Quote
Old 04-05-2011, 05:13 PM   #7350
Jerry P's Avatar
Trader Rating: 44 (100%+)
Originally Posted by JETT View Post
Yes they are. They look nice too.
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
